Upgrade to Premium
Photography & Video All things Camera & Video
Reply
  #1
Old 11-23-2016, 12:04 AM
christopher's Avatar
christopher christopher is offline
Currently: Husky Powered, Woof Woof
christopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond repute
Garage
Default HOW to mount a Pelican Case for Phantom 4 Drone ??
OK
Anyone have any insight on HOW to mount a Pelican Case to your tunnel?
http://www.phantom-four.com/review-d...its-phantom-3/
__________________
Rate this post: Yes | No
  #2
Old 11-23-2016, 07:50 AM
NorthMNSledder's Avatar
NorthMNSledder NorthMNSledder is offline
Currently: The person Elky looks up too.
NorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond repute
Default
Your going to love me for this but.......
We have this search feature here on Snowest and this entire "Ski-Doo" Section......
//www.snowest.com/forum/showthr...highlight=linq
Sorry buddy I had too. On a serious note if you search "Linq" there are a bunch of threads about different ways to mount things into your Linq system which is what you want to do I bet.
3 out of 3 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to NorthMNSledder For This Useful Post:
christopher (11-23-2016), Scott (11-23-2016)
  #3
Old 11-23-2016, 11:50 AM
Garage
Default
GRRRRRRRRRRRR
When the freaking Site Admin can't even find a thread you KNOW the search engine SUCKS!!
__________________
The Following User Says Thank You to christopher For This Useful Post:
NorthMNSledder (11-23-2016)
  #4
Old 11-23-2016, 12:57 PM
Default
I have found the best searching here is still done if you go into the specific forum. i.e. "Ski-Doo XM" and use the search this forum box. I seem to get much better results.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to NorthMNSledder For This Useful Post:
  #5
Old 11-23-2016, 02:09 PM
Garage
Default
Truth.
But it REALLY burns me that there is NO good after market module we can buy built just for SEARCHING this massive database we have created.
Its an inherent fault/shortcoming in the vBulliten code base.
__________________
  #6
Old 11-25-2016, 08:40 AM
goridedoo's Avatar
goridedoo goridedoo is online now
Currently: Not set.
goridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond repute
Default
My buddy and I both did them on our Axys' this year. I used an IM2600 and mounted it length wise. Used 4 countersunk bolts to mount the case to a set of rails from craiggerbuilt and then mounted the rails to the tunnel t-slots with carriage bolts.
Buddy used the IM2450 case with Mountain Addiction rails and just used longer bolts through the rail mount holes and up through the case, with large flat washers and a lock nut inside. I like this design better as it cant be taken off of the tunnel if you lock the case. Mine could be taken (though I like to think sledders are better than that) but if you have your sled locked up at night it wont be an issue.
Ill post a picture of mine, and try to get one of his later. Not sure what there will be available for the G4 for rails beings the coolers have changed.
Click image for larger version
The Following User Says Thank You to goridedoo For This Useful Post:
christopher (10-23-2017)
  #7
Old 11-25-2016, 08:41 AM
goridedoo's Avatar
Currently: Not set.
Default
  #8
Old 12-18-2016, 08:56 AM
volcano buster volcano buster is online now
Currently: Not set.
volcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond repute
Default
I think my SeaHorse box is a little smaller.
I wanted to be able to remove the box easily so I made some retainer blocks out of UHMW.
The Following User Says Thank You to volcano buster For This Useful Post:
christopher (12-18-2016)
  #9
Old 10-23-2017, 12:57 PM
skicopper's Avatar
skicopper skicopper is offline
Currently: waiting for snow
skicopper has a reputation beyond reputeskicopper has a reputation beyond reputeskicopper has a reputation beyond reputeskicopper has a reputation beyond reputeskicopper has a reputation beyond reputeskicopper has a reputation beyond reputeskicopper has a reputation beyond reputeskicopper has a reputation beyond reputeskicopper has a reputation beyond reputeskicopper has a reputation beyond reputeskicopper has a reputation beyond repute
Default
I was weary of placing my phantom on the tunnel where it would constantly be bouncing up and down. So I went with the backpack carrier. Just a thought.
__________________
  #10
Old 10-31-2017, 05:25 PM
RanOutofTalent RanOutofTalent is offline
Currently: Wondering what your can sounds like
RanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond repute
The Following User Says Thank You to RanOutofTalent For This Useful Post:
christopher (10-31-2017)
  #11
Old 10-31-2017, 05:31 PM
Garage
Click Here to Register
  #12
Old 10-31-2017, 08:39 PM
Dunatic's Avatar
Dunatic Dunatic is offline
Currently: Not set.
MODERATOR: Paid Premium Member
Dunatic has a reputation beyond reputeDunatic has a reputation beyond reputeDunatic has a reputation beyond reputeDunatic has a reputation beyond reputeDunatic has a reputation beyond reputeDunatic has a reputation beyond reputeDunatic has a reputation beyond reputeDunatic has a reputation beyond reputeDunatic has a reputation beyond reputeDunatic has a reputation beyond reputeDunatic has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — DJI Phantom 4 Pro + Drone Thread Starter — christopher Forum — Photography & Video Replies — 28 Last Post — 01-25-2018 05:54 PM
Thread — Mounting pelican case on tunnel Thread Starter — goridedoo Forum — Polaris: AXYS Replies — 43 Last Post — 10-12-2017 10:52 AM
Thread — F/s : DJI Phantom 3 Professional RC Drone QuadCopter 2 Battery COMBO...$850 USD Thread Starter — vinames47 Forum — Ski-Doo Replies — 0 Last Post — 02-23-2016 11:53 AM
Thread — Pelican Hard Case Thread Starter — owenbstory Forum — Polaris: Pro-Ride Replies — 18 Last Post — 10-22-2012 08:25 PM
Thread — Mount Pelican camera case on tunnel? Thread Starter — sledaddict82 Forum — General Snowmobiling Replies — 6 Last Post — 11-29-2010 01:58 PM
no new posts
