Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 11-14-2016, 11:35 PM
shattuck shattuck is online now
Currently: Not set.
shattuck has a reputation beyond reputeshattuck has a reputation beyond reputeshattuck has a reputation beyond reputeshattuck has a reputation beyond reputeshattuck has a reputation beyond reputeshattuck has a reputation beyond reputeshattuck has a reputation beyond reputeshattuck has a reputation beyond reputeshattuck has a reputation beyond reputeshattuck has a reputation beyond reputeshattuck has a reputation beyond repute
Default AXYS Quick Drive Bolts
Are you guys still changing out the quick drive bolts on the AXYS? I have one without about 1,000 miles and was wondering if the bolts were still an issue.
Rate this post: Yes | No
  #2
Old 11-15-2016, 04:08 AM
Indy_500's Avatar
Indy_500 Indy_500 is online now
Currently: Going Left!
Indy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond repute
Garage
Default
I have these on my axys, but have not heard of a broken axys stock bolt yet. http://www.zollingerracingproducts.c...-upgrade-bolts
__________________
-2016 Polaris Pro RMK 800 LE 155" x 2.6"
~Raptor Shocks, 37" Raptor Front End, Zollinger Billet Spindles, Bikeman Pipe, HPS Can, and then some
-2004 Polaris Pro X2 600
-2003 Polaris Pro X 600
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to Indy_500 For This Useful Post:
shattuck (11-15-2016), ZRP Engineering (11-15-2016)
  #3
Old 11-15-2016, 06:31 AM
Teth-Air's Avatar
Teth-Air Teth-Air is offline
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
Default
Some driveshafts have good splines and others are sloppy. Here is a link to a video of my buddy's 2017. It is too sloppy for a sled with zero miles. You have to remember that the bolt must preload the gear against the bearing. As you accelerate and brake, the gear rotates on the shaft slightly under the bolt head. How many times do you think it takes for that gear to rock back and forth under the bolt head to wear away enough material before it loosens up? Once loose, the gear wobbles due to the belt load being outboard of the end of the shaft, and this works on the bolt, bending it under the head in a rotational manor until the bolt fatigues and the bolt head pops off.
This is not on all sleds. My 2014 was good, my 15 terrible, my 16 good and this 17 poor again.
If yours is bad, upgrade the bolt and use Loctite 660 on the shaft. This will make removing the gear a bitch but we run the TKI belt drives so changing belts is not a concern.
I hope the link works
https://www.dropbox.com/s/pvpd4haogj...39.53.mov?dl=0
Chris
__________________
Home of the "Cordless Teth-Air" and NEW "Phantom Teth-Air"
http://www.sourceinnovations.ca
We also have TKI Belt Drives, Arm Candy A-Arm Braces, Oil Tank Inserts, Reversible Scratchers, Polaris Suspension Couplers, Track Clips, Clutching and more.
4 out of 4 members found this post helpful. Rate this post: Yes | No
The Following 3 Users Say Thank You to Teth-Air For This Useful Post:
jhurkot (11-22-2016), mountainhorse (08-07-2018), shattuck (11-15-2016)
  #4
Old 11-15-2016, 09:22 AM
Sage Crusher's Avatar
Sage Crusher Sage Crusher is online now
Currently: Power Clawing the Axys....
Sage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond repute
Default
Quote:
Chris
Seems like we get the loose splines
My 14 good- 15-16 really bad./ Ordered new lower gears from Tom @ TKI and put the ARP bolts on top& Bottom.. Didn't miss a beat last year on all 3 sleds.... Annually I change out the bolt's now and chase the threads on the shafts with a tap and re-do...
Just something for a piece of mind, and pre-season activity now..
__________________
Dealers for:
Silber Turbos.
GGB Exhaust.
TKI.
F-N-I.
K-Mod.
2016 Axys 3" 162 P/C Track W/Silber Turbo/K-Mod Gen III/TKI
The Following User Says Thank You to Sage Crusher For This Useful Post:
Teth-Air (11-22-2016)
  #5
Old 11-15-2016, 11:19 AM
Dirty Steve's Avatar
Dirty Steve Dirty Steve is offline
Currently: Disappointed in the FLICKABILITY of my lawnmower.
Dirty Steve has a reputation beyond reputeDirty Steve has a reputation beyond reputeDirty Steve has a reputation beyond reputeDirty Steve has a reputation beyond reputeDirty Steve has a reputation beyond reputeDirty Steve has a reputation beyond reputeDirty Steve has a reputation beyond reputeDirty Steve has a reputation beyond reputeDirty Steve has a reputation beyond reputeDirty Steve has a reputation beyond reputeDirty Steve has a reputation beyond repute
Default
I rode with a guy last year who broke his bottom bolt second ride on a 16' Axys. He did have a turbo. The bottom bolt broke less than a mile from the truck as we were just cruising down the trail. He was able to work the belt and pulley back into position and limp back to the trailer.
If I had the stock belt drive, I would replace the bolt, just for cheap insurance.
Or TKI, FTW!
The Following User Says Thank You to Dirty Steve For This Useful Post:
  #6
Old 11-15-2016, 01:13 PM
SRXSRULE SRXSRULE is online now
Currently: Not set.
SRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond repute
Default
Has anyone installed a stud and nut instead of a bolt? Eric
  #7
Old 11-15-2016, 04:24 PM
ullose272 ullose272 is offline
Currently: workin for the weekend
ullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond repute
Default
I put in ARP bolts. But just because i had them
Sent from my SM-G900V using Tapatalk
  #8
Old 11-16-2016, 01:11 PM
Teth-Air's Avatar
Default
Quote:
Yes, I did this on my 2015. Actually drilled and tapped it out to a larger size first and used 2 nuts to lock in place. Also use Loctite 660. Had to drill the washer hole larger too.
__________________
The Following User Says Thank You to Teth-Air For This Useful Post:
Sage Crusher (11-16-2016)
  #9
Old 11-21-2016, 07:20 AM
dexter dexter is offline
Currently: Not set.
dexter has a reputation beyond reputedexter has a reputation beyond reputedexter has a reputation beyond reputedexter has a reputation beyond reputedexter has a reputation beyond reputedexter has a reputation beyond reputedexter has a reputation beyond reputedexter has a reputation beyond reputedexter has a reputation beyond reputedexter has a reputation beyond reputedexter has a reputation beyond repute
Default
Anybody know the ARP bolt part number for the bottom gear on the axys?
  #10
Old 11-22-2016, 05:14 AM
Maxsnow Maxsnow is offline
Currently: Not set.
Basic Member
Maxsnow has a reputation beyond reputeMaxsnow has a reputation beyond reputeMaxsnow has a reputation beyond reputeMaxsnow has a reputation beyond reputeMaxsnow has a reputation beyond reputeMaxsnow has a reputation beyond reputeMaxsnow has a reputation beyond reputeMaxsnow has a reputation beyond reputeMaxsnow has a reputation beyond reputeMaxsnow has a reputation beyond reputeMaxsnow has a reputation beyond repute
Default
The top gear bolt and the bottom gear bolt of the quick drive strape are graded at 8.8 ... The same grade that was on the pro rmk ... I don't want to take any chances and i'm gonna change it for some 10.9 grade bolts ... Maybe those 8.8 bolts are going to stay in place and not broke but when you broke in the trail , close of the truck that not that worst but in the wood in tree ride .... Oufff i don't wanna think about it so for the price it cost... I DON'T TAKE ANY CHANCES
  #11
Old 11-22-2016, 09:04 AM
jhurkot jhurkot is online now
Currently: Not set.
jhurkot has a reputation beyond reputejhurkot has a reputation beyond reputejhurkot has a reputation beyond reputejhurkot has a reputation beyond reputejhurkot has a reputation beyond reputejhurkot has a reputation beyond reputejhurkot has a reputation beyond reputejhurkot has a reputation beyond reputejhurkot has a reputation beyond reputejhurkot has a reputation beyond reputejhurkot has a reputation beyond repute
Click Here to Register
The Following User Says Thank You to jhurkot For This Useful Post:
  #12
Old 11-22-2016, 03:19 PM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
The Following User Says Thank You to mountainhorse For This Useful Post:
B&M Fabrications (11-22-2016)
  #13
Old 07-07-2018, 03:07 PM
  #14
Old 07-09-2018, 11:34 AM
mountainhorse (07-10-2018)
  #15
Old 08-06-2018, 05:40 AM
  #16
Old 08-06-2018, 10:04 AM
richracer1's Avatar
richracer1 richracer1 is online now
Currently: Loving my BMP 860
richracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond repute
The Following User Says Thank You to richracer1 For This Useful Post:
Sage Crusher (08-06-2018)
  #17
Old 08-06-2018, 10:09 AM
damx damx is online now
Currently: Not set.
damx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond repute
  #18
Old 08-06-2018, 04:11 PM
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — F/S Polaris 800's Pro & Axy quick sell in Wa. Thread Starter — Rabbit Forum — Polaris (Swapmeet) Replies — 2 Last Post — 10-14-2016 05:39 PM
Thread — quick drive bolts Thread Starter — randy542 Forum — Polaris: AXYS Replies — 5 Last Post — 04-02-2016 08:10 PM
Thread — ARP Quick Drive bolts and Nord-Lock Washers Thread Starter — Dirty Steve Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 3 Last Post — 12-21-2015 07:12 PM
Thread — Quick Drive Bolts Thread Starter — TheBreeze Forum — Polaris: AXYS Replies — 44 Last Post — 11-27-2015 01:12 PM
Thread — Quick clicker bolts Thread Starter — WIS.REV Forum — Ski-Doo: XP Sleds Replies — 4 Last Post — 11-17-2011 10:42 PM
no new posts
