Upgrade to Premium
Yamaha: 2-stroke Includes all Yamaha 2-strokes, Viper, Mountain Max, etc
Reply
  #1
Old 11-08-2016, 07:53 PM
Iowa_assault Iowa_assault is offline
Currently: Trying to head west!
Iowa_assault has a reputation beyond reputeIowa_assault has a reputation beyond reputeIowa_assault has a reputation beyond reputeIowa_assault has a reputation beyond reputeIowa_assault has a reputation beyond reputeIowa_assault has a reputation beyond reputeIowa_assault has a reputation beyond reputeIowa_assault has a reputation beyond reputeIowa_assault has a reputation beyond reputeIowa_assault has a reputation beyond reputeIowa_assault has a reputation beyond repute
Default 1987 exciter 570 bog issues
I've had issues with bogging under weight. I don't think it's carb problems. It will do 105 mph on the stand. Under weight it will top out at 50 mph and I only weigh 12o lbs. I think it's in the clutching. Worn out weights/ramps/rollers
But then again I also sometimes think it's in the carb because if it doesn't start first 3 pulls you have to pull it for another 5 minutes until it starts
Sometimes if you aren't riding it hard it will bog down and shut off. And then won't start back up again until you either let it cool down or clean the plugs off or pull it 95 million times.
Whats your guy's input?
Rate this post: Yes | No
  #2
Old 11-08-2016, 08:40 PM
gonehuntnpowder gonehuntnpowder is online now
Currently: Not set.
gonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond repute
Default
Those had a carb recall. They switched them to rounds slides from the butterfly's as I remember. Has the new carbs?
  #3
Old 11-08-2016, 08:48 PM
Default
It does not have the new carbs... They are the butterfly ones
  #4
Old 11-11-2016, 11:30 AM
Anylizer Anylizer is offline
Currently: People are idiots... period!!
Anylizer has a reputation beyond reputeAnylizer has a reputation beyond reputeAnylizer has a reputation beyond reputeAnylizer has a reputation beyond reputeAnylizer has a reputation beyond reputeAnylizer has a reputation beyond reputeAnylizer has a reputation beyond reputeAnylizer has a reputation beyond reputeAnylizer has a reputation beyond reputeAnylizer has a reputation beyond reputeAnylizer has a reputation beyond repute
Default
the butterfly carbs work much better if tuned properly. Way less prone to flooding , and throttle response is significantly better.
There are 2 rubber plugs inside the bowl of each carb. the fuel makes them hard, and they dont seal properly.
# 8V0-14118-00-00 get 4 of them, and replace them. Also pay close attention to where they are located. the can be put in the wrong hole and cause problems.
I would find a manual and verify that they are in fact in the correct location.
__________________
My good judgement is a result of my experience...
although my experience is the result of my bad decisions...
  #5
Old 11-13-2016, 02:07 PM
eddy's Avatar
eddy eddy is offline
Currently: Dirt Bike Season!
eddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond repute
Default Fuel Pump
Even though you get the same symptoms with the butterfly: Do not overlook the fuel pump being weak. Rebuild or replace and make sure the pulse line is good.
  #6
Old 12-08-2016, 07:20 PM
Default
Installing new carbs and a fuel pump this weekend. I will let you guys know what happens from there
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — 1987 Yamaha Exciter 570 Carb Thread Starter — Iowa_assault Forum — Yamaha (Swapmeet) Replies — 0 Last Post — 11-02-2015 09:52 AM
Thread — 570 Exciter MOD? Thread Starter — turbolq4 Forum — Yamaha: 2-stroke Replies — 13 Last Post — 10-10-2010 09:13 AM
Thread — 1987 Yamaha Exciter Cylinders Thread Starter — Rollerover Forum — WTB (Swapmeet) Replies — 2 Last Post — 12-01-2009 08:16 PM
Thread — 1987 yamaha exciter Thread Starter — dubs Forum — Yamaha (Swapmeet) Replies — 6 Last Post — 10-12-2009 03:36 PM
Thread — Help- Cant get spark - Exciter 570 Thread Starter — harley sled Forum — Yamaha Replies — 5 Last Post — 12-08-2008 08:48 PM
no new posts
