Upgrade to Premium
Reply
  #1
Old 11-08-2016, 01:07 PM
Raze Taylor Raze Taylor is offline
Currently: Not set.
Raze Taylor has a reputation beyond reputeRaze Taylor has a reputation beyond reputeRaze Taylor has a reputation beyond reputeRaze Taylor has a reputation beyond reputeRaze Taylor has a reputation beyond reputeRaze Taylor has a reputation beyond reputeRaze Taylor has a reputation beyond reputeRaze Taylor has a reputation beyond reputeRaze Taylor has a reputation beyond reputeRaze Taylor has a reputation beyond reputeRaze Taylor has a reputation beyond repute
Default Liquid Heated Handlebars
Keep Your Hands Warm, while Maintaining Consistent Engine Temperature
We have been running these bars on our snowmobiles for a long time. They rock.
The Thermostat is the Key.
One of the root ​problem​s​ ​are most dirt bikes being converted to snow bikes don’t have a thermostat. Dirt bikes were originally designed to be run in hot environments where you need maximum cooling without restriction. When being used as a snow bike the coolant system overpowers the BTU output of the engine, resulting in a cold engine. The OEM ECU monitors the engine coolant temperature and bases many aspects of the engine calibrations on it.
W​hen the fuel and intake track are very cold, the atomization of the fuel is not as efficient. Fuel droplets pool in the intake track or on top of the piston. This negatively effects the efficiency of the combustion chamber. Not only does the engine coolant temperature need to maintain its target temperature, but so does the engine oil. In all gasoline engines a small amount of fuel gets past the piston rings and ends up in the engine oil — especially in stock snow bikes run for long periods with cold coolant and oil. When the engine oil temperature is at proper operating temperature, the oil flashes off any fuel found in the oil. If the oil isn’t at operating temperature the crankcase will slowly fill with fuel, and over long runs — like those in the cold mountains — the engine​ can​ hydro lock. Some snow bikers have already experienced this situation. This problem gets exaggerated because the ECU commands a richer fuel mixture when it sees a cold coolant reading. ​The OEM ECU does this for many reasons, such as combating 4-point seizures on the piston from not letting the engine warm up.​
So when riding a stock snow bike without a thermostat, in typical cold conditions, you will have an extremely rich air/fuel ratio — causing horrible fuel consumption, calibration tables limiting maximum horsepower, and risk severe engine failure from fuel thinning out the engine oil. Or a seizure.
Our fix: Install a thermostat and maintain a consistent target engine temp.
How a Thermostat Works — The type of thermostat we are talking about is a mechanical auto adjusting valve that restricts the flow of the coolant system. A properly selected thermostat is what controls and maintains a liquid cooled combustion engine’s operating temperature. When the engine coolant is cold, the valve is closed. Once the engine gets up to operating temperature, the valve opens a little, and starts to allow coolant to flow to the radiator. When the engine is hot the valve opens more, allowing the coolant to flow through the radiator to dissipate excess heat. As the engine heats up or cools off, due to environment or work load, the valve self-adjusts to maintain a targeted 180°F, the proper engine temperature.
The Heated Handlebars
Dirtbike engines do not have enough power output to power coil style grip heaters. Even on the electric start bikes the battery gets drained completely and will not start in the middle of the mountains.
With our patented system, engine coolant is routed through the bars which takes no electricity and sets a perfect temperature. The high-pressure side to the bars is routed from the back side of the thermostat so you have warm bars in less than 30 seconds of starting of the engine. Since the bars are the highest point on the cooling system, the bars stay warm for up to 15 minutes after you shut the engine off, due to a natural thermo-siphon.
The throttle side runs the same temperature as the clutch side. It is designed to work with thread-in insert hand guards.
Heated Handlebar Kit Customization
These bars can easily be mounted onto a snowmobile with a 7/8” to 1 1/8” bar adapter which we have in stock. We are more than happy to build you a custom kit for you snowmobile application with everything needed for the same cost to you as advertised, we will just need the following information: 1) Low-Pressure Coolant Line Diameter. 2) High-Pressure Coolant Line Diameter. 3) Length of Low-Pressure handlebar coolant line. 4) Length of High-Pressure handlebar coolant line.
Raze Liquid Heated Handlebars Feature
Billet Inline Thermostat — provides consistent engine temperature for better power, fuel consumption, and it protects your engine from the perils of running a cold engine.
ProTaper Henry/Reed Bars — These oversize diameter, impact absorbing handlebars have Raze’s patent-pending system inside, and are threaded to attach the coolant lines to.
PTFE Black Lines, and AN Fittings — All parts needed for installation are included.
Temperature Control Valve — Before we had the control valve, we were roasting our hands on spring condition days. Now you can control the bar temp with the valve.
Hand Guard Compatible — Works with all hand guards including thread-in insert guards
No Electricity Needed — No dead batteries, no stressing insufficient charging systems, and no delicate pain-in-the-*** hand warmer coils.
Easy Install — If you can turn a wrench, you can install these yourself.
Click image for larger version
Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Whats Up With Liquid Image? Thread Starter — Radar78 Forum — Electronics Replies — 6 Last Post — 09-20-2016 10:25 PM
Thread — Liquid poured out of Exhaust can Thread Starter — Rcowee Forum — Ski-Doo: REV Sleds Replies — 4 Last Post — 11-17-2014 05:24 PM
Thread — Liquid Snow... Thread Starter — concretebob Forum — Photography & Video Replies — 0 Last Post — 07-31-2014 07:09 PM
Thread — Need HELP with old 500 liquid Thread Starter — chevster12 Forum — Polaris Replies — 2 Last Post — 03-04-2009 08:33 AM
