Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 11-05-2016, 05:19 PM
FarmerTimBob's Avatar
FarmerTimBob FarmerTimBob is online now
Currently: Not set.
FarmerTimBob has a reputation beyond reputeFarmerTimBob has a reputation beyond reputeFarmerTimBob has a reputation beyond reputeFarmerTimBob has a reputation beyond reputeFarmerTimBob has a reputation beyond reputeFarmerTimBob has a reputation beyond reputeFarmerTimBob has a reputation beyond reputeFarmerTimBob has a reputation beyond reputeFarmerTimBob has a reputation beyond reputeFarmerTimBob has a reputation beyond reputeFarmerTimBob has a reputation beyond repute
Default Question about 06 M7
I got a 06 M7 4,000+ miles. Never been touched. When should a guy do a top end? And if I'm doing a top end is it worth it to go with a big bore?
Rate this post: Yes | No
  #2
Old 11-05-2016, 06:29 PM
jethrobodean jethrobodean is offline
Currently: ROCK ON !
Basic Member
jethrobodean has a reputation beyond reputejethrobodean has a reputation beyond reputejethrobodean has a reputation beyond reputejethrobodean has a reputation beyond reputejethrobodean has a reputation beyond reputejethrobodean has a reputation beyond reputejethrobodean has a reputation beyond reputejethrobodean has a reputation beyond reputejethrobodean has a reputation beyond reputejethrobodean has a reputation beyond reputejethrobodean has a reputation beyond repute
Default
If it where me, I would test the compression and if all is good keep running it. Those 700 lay down motors are good for 10k or more.
The Following User Says Thank You to jethrobodean For This Useful Post:
FarmerTimBob (11-05-2016)
  #3
Old 11-05-2016, 06:57 PM
Bedhead Bedhead is offline
Currently: Doing the snow dance
Bedhead has a reputation beyond reputeBedhead has a reputation beyond reputeBedhead has a reputation beyond reputeBedhead has a reputation beyond reputeBedhead has a reputation beyond reputeBedhead has a reputation beyond reputeBedhead has a reputation beyond reputeBedhead has a reputation beyond reputeBedhead has a reputation beyond reputeBedhead has a reputation beyond reputeBedhead has a reputation beyond repute
Default
I am just about to hit 4000 on my 06 M7 and was wondering the same thing. From what I read most guys would have done the top end already. Myself, I have checked compression, looked in the cylinders and had the Y pipe off and looked at the pistons with everything looking good. So armed with that I plan on waiting one more season, then do the top end with what ever I choose at that time. Probably keep it a 700 and give it to my son and buy a new one.
Bottom line is do some tests, make an informed decision.
  #4
Old 11-05-2016, 07:46 PM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
Quote:
This ^^^
  #5
Old 11-09-2016, 04:40 PM
1MEX 1MEX is offline
Currently: needing a new sled
1MEX has a reputation beyond repute1MEX has a reputation beyond repute1MEX has a reputation beyond repute1MEX has a reputation beyond repute1MEX has a reputation beyond repute1MEX has a reputation beyond repute1MEX has a reputation beyond repute1MEX has a reputation beyond repute1MEX has a reputation beyond repute1MEX has a reputation beyond repute1MEX has a reputation beyond repute
Garage
Thumbs up
I would change them now and not risk a tired piston to start cracking. It would be more to replace entire top end than just pistons. BB are always worth it if you have the money and the know how to tune.
  #6
Old 11-11-2016, 08:24 AM
CATSLEDMAN1 CATSLEDMAN1 is online now
Currently: one ski and a KTM
CATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond repute
Default good TOP END
THE BEST PART about going through the top end on the layddown is cleaning and matching up the power valves, carbon build up is often a big power loser, and while you are there put in new pistons rings top end bearing. Good to go, if you have the time, at least tear down one cyl and make sure its carbon free. 4000 trail miles will be different than 4000 miles cutting sidehills.
  #7
Old 11-16-2016, 01:40 PM
Rixster's Avatar
Rixster Rixster is offline
Currently: I love you El Nino
Rixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond repute
Garage
Default
I have seen that motor go 10k plus with nothing but fuel and oil. Check compression and if it is good spend that money on a new set of clutches. Do the new team primary and a 10.4 secondary.
__________________
Custom built sled decks contact me for details
A.K.A."Seth"
06 M7 CPC Dragoncat 1000 162
F350 crewcab
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, body thoroughly used up, totally worn out and Screaming "WOO" What a ride!
KCCO
  #8
Old 11-25-2016, 07:53 PM
sledtahoe sledtahoe is offline
Currently: waiting for the big dump!
Basic Member
sledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond repute
Default clutch
I would watch and keep the clutches clean the primary is what will go first. The pistons are good tell 5k easy. Ride the piss out of it.
  #9
Old 08-24-2018, 03:51 PM
Slotmachine Slotmachine is offline
Currently: Not set.
Basic Member
Slotmachine is an unknown quantity at this point
Garage
Default
I pulled my TE at 6000 just to give it to a buddy. It had 115/120. I had a very new spare TE and put it on. Great motor, I've been through both the primary and secondary clutches, it's now my spare sled, bought a new 2014 in '13, love it.
  #10
Old 08-24-2018, 06:56 PM
Daag44 Daag44 is online now
Currently: Not set.
Basic Member
Daag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Pg question Thread Starter — vans411 Forum — Arctic Cat: TURBO Replies — 12 Last Post — 01-09-2013 08:44 AM
Thread — Installation question of a BD race gas kit upgrade question.. Thread Starter — bigdogsummit800 Forum — Arctic Cat: TURBO Replies — 1 Last Post — 12-09-2012 07:34 PM
Thread — 5.1 Question Thread Starter — turbonium Forum — Polaris: Pro-Ride Replies — 19 Last Post — 10-04-2010 11:20 PM
Thread — XLT starting question & tempaflow question Thread Starter — olymon Forum — Polaris: GEN 1 and older Replies — 4 Last Post — 01-08-2010 02:44 PM
Thread — HPS XP can install question, and sound baffel question Thread Starter — Sledskisteeze Forum — Ski-Doo Replies — 2 Last Post — 11-16-2008 07:14 AM
no new posts
