Upgrade to Premium
Arctic Cat: 1M 2001-2005, all models in the Mountain Cat / 1M chassis
Reply
  #1
Old 10-29-2016, 05:11 PM
MT-BOONDOCKER MT-BOONDOCKER is offline
Currently: Not set.
Basic Member
MT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond reputeMT-BOONDOCKER has a reputation beyond repute
Default 03 mountain cat mods
I'm looking to do a 2.5 or 3inch on my sled next year and would like some info on how to make them fit. I have a limited budget
Rate this post: Yes | No
  #2
Old 10-29-2016, 05:44 PM
KMMAC KMMAC is offline
Currently: KEEP AN EYE OPEN WHILE YOU SLEEP
KMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond repute
Default
Get a 2.6 power claw it should fit.
The Following User Says Thank You to KMMAC For This Useful Post:
MT-BOONDOCKER (10-29-2016)
  #3
Old 10-29-2016, 09:50 PM
Idcatman3's Avatar
Idcatman3 Idcatman3 is offline
Currently: Not set.
MODERATOR: Premium Member
Idcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond repute
Garage
Default
Yeah, a 2.5 fits without any mods, other than the right drivers. 10 tooth with a 2.5" pitch, 8 tooth for 3" pitch.
The 2.6 Powerclaw fits also with no mods. A 3" should probably fit with just dropping a tooth on the drivers.
__________________
Arctic Cat 1M and PS Moderator
'04 1M 1500 162" Challenger Extreme, M8 rear suspension, Custom jetting, clutching and gearing
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to Idcatman3 For This Useful Post:
  #4
Old 10-29-2016, 10:24 PM
Currently: Not set.
Basic Member
Default
What is a good website to get the drivers
  #5
Old 10-30-2016, 12:14 AM
paulharris paulharris is offline
Currently: want pow
paulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond repute
Default
i'll assume you have a 159 now. do the 2.5" 16 wide camo 162. just get a stock king cat driveshaft/drivers (3" pitch) and it fits in there and works awesome on that sled, you might be able to find a used track camo 9944 as i recall. if you ride wet snow like pacific northwest the attack 20 in the hillclimb position is quite a fun track to ride. forget it in light dry power though. also, i am personally NOT a fan of the powerclaw on that sled.
slp cold air intake airbox top.
speedwerx single pipe and can. or some twins if you can find them.
I might have a king cat driveshaft with drivers if you need one i'd sell you.
  #6
Old 10-30-2016, 09:05 AM
Currently: Not set.
Basic Member
Default
My mountan cat is a 151. I wish I had the 159 .
  #7
Old 10-30-2016, 02:52 PM
Idcatman3's Avatar
Currently: Not set.
Garage
Default
Quote:
You can get a 156 x 2.5" With the King Cat shaft and drivers, and 153" rails. There's enough adjustment to make it work.
__________________
  #8
Old 10-31-2016, 09:44 AM
greencat900 greencat900 is offline
Currently: Not set.
Basic Member
greencat900 has a reputation beyond reputegreencat900 has a reputation beyond reputegreencat900 has a reputation beyond reputegreencat900 has a reputation beyond reputegreencat900 has a reputation beyond reputegreencat900 has a reputation beyond reputegreencat900 has a reputation beyond reputegreencat900 has a reputation beyond reputegreencat900 has a reputation beyond reputegreencat900 has a reputation beyond reputegreencat900 has a reputation beyond repute
Default important detail
One important thing is the coolers. Does your sled have the coolers running down middle of the tunnel or the edges?
If they are running down the edges then you can probably fit a 3" with the stock king cat drivers. my brother has an X3 on his with the stock drivers.
I will be putting a 3" on mine with the stock drivers. The 3" is a little tight but not too bad. A 2.5" would do better than the stock track.
  #9
Old 10-31-2016, 10:44 AM
Currently: Not set.
Basic Member
Default
My coolers run down the middle
  #10
Old 11-02-2016, 09:55 AM
Idcatman3's Avatar
Currently: Not set.
Garage
  #11
Old 11-10-2016, 10:37 AM
Currently: Not set.
Basic Member
Click Here to Register
  #12
Old 11-11-2016, 11:06 AM
Idcatman3's Avatar
Currently: Not set.
Garage
  #13
Old 11-11-2016, 01:30 PM
Currently: Not set.
Basic Member
  #14
Old 11-11-2016, 03:21 PM
Idcatman3's Avatar
Currently: Not set.
Garage
mtncat1 (11-11-2016)
  #15
Old 11-11-2016, 07:59 PM
mtncat1's Avatar
mtncat1 mtncat1 is offline
Currently: waiting for snow
mtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Best mods to a 02 Mountain Cat Thread Starter — 570MC Forum — Arctic Cat: 1M Replies — 23 Last Post — 12-27-2009 09:08 PM
Thread — Mountain Cat Mods Thread Starter — 570MC Forum — Performance/Modified Replies — 3 Last Post — 11-20-2008 08:28 AM
Thread — Mods on a 02 Mountain Cat 570????? Thread Starter — 570MC Forum — Arctic Cat: 1M Replies — 4 Last Post — 05-15-2008 08:38 PM
Thread — 2001 Mountain Cat 800 w/Mods Thread Starter — 06XF7 Forum — Arctic Cat (Swapmeet) Replies — 4 Last Post — 03-07-2008 09:31 AM
Thread — Mods on 2002 mountain cat 570 & 800 also king cat Thread Starter — 570MC Forum — Arctic Cat: 1M Replies — 6 Last Post — 01-26-2008 06:48 PM
