Upgrade to Premium
Arctic Cat: Powder Special and older 2000 and older, all models in the Powder Special chassis and older chassis models
Reply
  #1
Old 10-23-2016, 01:47 PM
ponchonutty ponchonutty is offline
Currently: Not set.
Basic Member
ponchonutty is an unknown quantity at this point
Default 93 jag 440 f/c mikuni carb question
It appears as if I have a carb problem on my sled. This ca has been in improper storage for a while and I think the carb is junk. I had to pry the choke plunger out of it because it looked like it got wet and corroded into place. I tried cleaning it all out the best I could. I can get the sled to start but barely runs above idle speed while wide open. The plugs get saturated with fuel. I think I may just try to find a good replacement. On the side it says 32-119. Anybody have an idea what that means?
Rate this post: Yes | No
  #2
Old 10-24-2016, 08:31 AM
Sickbuild Sickbuild is offline
Currently: Not set.
Basic Member
Sickbuild has a reputation beyond reputeSickbuild has a reputation beyond reputeSickbuild has a reputation beyond reputeSickbuild has a reputation beyond reputeSickbuild has a reputation beyond reputeSickbuild has a reputation beyond reputeSickbuild has a reputation beyond reputeSickbuild has a reputation beyond reputeSickbuild has a reputation beyond reputeSickbuild has a reputation beyond reputeSickbuild has a reputation beyond repute
Default
Have you taken the bottom of the carb off? Clean your jets out / adjust cable to get slide height right. Adjust idle screw. Turn idle mix screw on side(the tiny one)go right till it is snug then back off 1- 1-1/2left.
  #3
Old 10-25-2016, 01:49 AM
Currently: Not set.
Basic Member
Default
Yes I tore it apart. It was pretty crude looking. Got it farely cleaned but didn't change anything. Still don't think it's the right carb anyways so I ordered a NOS unit to try out. Will report back how this works out
  #4
Old 10-30-2016, 11:03 PM
Currently: Not set.
Basic Member
Default
Quote:
Ended up buying a NOS carb that is the correct size. 4th pull started right up!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 40mm mikuni rack carb, 1 carb only! Thread Starter — flying pig Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 02-05-2012 09:26 AM
Thread — carb parts for jag Thread Starter — ullose272 Forum — Arctic Cat: Powder Special and older Replies — 2 Last Post — 12-02-2009 11:45 AM
Thread — 92 JAG 440 Carb Thread Starter — Garret_Volden Forum — Arctic Cat Replies — 2 Last Post — 02-10-2009 03:41 PM
Thread — WYB carb for 89 jag 440 fan Thread Starter — zx800x Forum — WTB (Swapmeet) Replies — 0 Last Post — 11-17-2008 12:32 PM
Thread — Polaris edge rmk 800 ves....mikuni carb question? Thread Starter — cbr_shawn Forum — Performance/Modified Replies — 6 Last Post — 10-29-2008 11:59 PM
no new posts
