Upgrade to Premium
Reply
  #1
Old 10-19-2016, 05:51 PM
Raze Moto's Avatar
Raze Moto Raze Moto is offline
Currently: Hay Days
Raze Moto has a reputation beyond reputeRaze Moto has a reputation beyond reputeRaze Moto has a reputation beyond reputeRaze Moto has a reputation beyond reputeRaze Moto has a reputation beyond reputeRaze Moto has a reputation beyond reputeRaze Moto has a reputation beyond reputeRaze Moto has a reputation beyond reputeRaze Moto has a reputation beyond reputeRaze Moto has a reputation beyond reputeRaze Moto has a reputation beyond repute
Garage
Default Raze King Kong!
So now that the King Kong kit is out there let me start answering a few of your questions.
How does it work?
It all starts off with our Wingman kit from RAZE. The Wingman is our stand alone plug and play ECU that replaces your stock ECU. Using the stock sensors, and a barometric pressure sensor that is on the ECU it fully altitude and temperature compensates as you ride. It also has a strategy that is designed to run the bike as snike, not a dirt bike. We apply maximum timing at all times producing more usable power while watching the crank for any hesitation. If we see a variation in the crank speed, we know we are about to have a knock, once we see this we back the timing off a touch and hold RPM's. This way you never feel the rev limiter. This is technology that no one else in the industry utilizes. Our Thermostat is included with the Wingman. This thermostat can completely shut off the flow of coolant quickly bringing the engine up to operating temp, and is a vital part of the snikes ECU built in strategy. It also has a port for our liquid heated handlebars. see Razemotorsports.com. The Raze ECU has full control over the Pro Charger as well. We utilize a re-circulation valve. This technology is used on many modern super cars. The computer commands through the use of an air actuator a spring that controls the blow off valve. Having control of the blow off valve allows us to command boost. With this control we can command any boost value we choose. The King Kong Procharged kit will work at 10,000ft as well as it does at 1000ft. At low elevations we can bleed a lot of boost off so we don't endanger the engine, high elevation the King Kong will build up to 17lbs of boost and keep the bike running at the desired 90 HP.
This is a pre-production King Kong. Those of you that saw it at the Edmonton Snow Show were STOKED, but noticed a few small issues we were already working on. Some noticed how close the shifter is to the belt case. This is a small issue we are dealing with. We have two fixes, just need to test them. We will either need to run the kit with a Rekluse or some sort of pneumatic shifting. We understand that some of you love the Rekluse, some hate it. So we are working on the right answer. Another option would be to go with smaller wheels inside the case, which will allow us to have a smaller case and still build the same amount of boost and allow for full use of the shifter. Second, the air intake is for sure something we are working on. At the minimum, it will have some sort of helmet and utilize Frog Skin or a like material to keep snow away. We have considered running the intake above the front fender but this creates other issues. The biggest perhaps being noise for the rider. When the Supercharger barks it would be right by your head, not something I personally would enjoy. Third, we have a plate aluminum skid plate that will be included with the kit to protect the Pro Charger.
The King Kong is looking to turn heads everywhere it goes, oh yeah and it whistles on idol!!
Available in Janruary for 2015-2016 KTM 450's
Soon after for 2015-2016 Yamaha 450'S
Click image for larger version
__________________
Chris McKinney
President of Raze Motorsports, Inc.
Cell 763-219-7102
Office: 888-3Boost4
www.razemotorsports.com
Rate this post: Yes | No
The Following User Says Thank You to Raze Moto For This Useful Post:
800tundra (11-25-2017)
  #2
Old 03-08-2017, 07:28 PM
Gregoryosto Gregoryosto is offline
Currently: Not set.
Basic Member
Gregoryosto is an unknown quantity at this point
Default King Kong
Do you have any videos of the setup hill climbing? How has testing been going?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Raze King Kong! Thread Starter — Raze Moto Forum — Snow bikes Replies — 10 Last Post — 10-27-2016 08:04 PM
Thread — Raze Motorsports Inc Thread Starter — Tree rider Forum — Snow bikes Replies — 5 Last Post — 10-20-2016 08:51 AM
Thread — Raze motorsports Thread Starter — Sheetmetalfab Forum — Snow bikes Replies — 35 Last Post — 09-25-2016 06:51 PM
Thread — It's on like Donkey Kong! Fight nights a comin! Thread Starter — PJ-Hunter Forum — Fouled Plug Replies — 13 Last Post — 06-13-2011 06:38 AM
Thread — It's On Like Donkey Kong! (BDSO) Thread Starter — RIP N TEAR Forum — General Snowmobiling Replies — 49 Last Post — 02-21-2010 08:50 PM
