Upgrade to Premium
Reply
  #1
Old 10-19-2016, 05:46 PM
Raze Moto's Avatar
Raze Moto Raze Moto is offline
Currently: Hay Days
Raze Moto has a reputation beyond reputeRaze Moto has a reputation beyond reputeRaze Moto has a reputation beyond reputeRaze Moto has a reputation beyond reputeRaze Moto has a reputation beyond reputeRaze Moto has a reputation beyond reputeRaze Moto has a reputation beyond reputeRaze Moto has a reputation beyond reputeRaze Moto has a reputation beyond reputeRaze Moto has a reputation beyond reputeRaze Moto has a reputation beyond repute
Garage
Default Raze King Kong!
So now that the King Kong kit is out there let me start answering a few of your questions.
How does it work?
It all starts off with our Wingman kit from RAZE. The Wingman is our stand alone plug and play ECU that replaces your stock ECU. Using the stock sensors, and a barometric pressure sensor that is on the ECU it fully altitude and temperature compensates as you ride. It also has a strategy that is designed to run the bike as snike, not a dirt bike. We apply maximum timing at all times producing more usable power while watching the crank for any hesitation. If we see a variation in the crank speed, we know we are about to have a knock, once we see this we back the timing off a touch and hold RPM's. This way you never feel the rev limiter. This is technology that no one else in the industry utilizes. Our Thermostat is included with the Wingman. This thermostat can completely shut off the flow of coolant quickly bringing the engine up to operating temp, and is a vital part of the snikes ECU built in strategy. It also has a port for our liquid heated handlebars. see Razemotorsports.com. The Raze ECU has full control over the Pro Charger as well. We utilize a re-circulation valve. This technology is used on many modern super cars. The computer commands through the use of an air actuator a spring that controls the blow off valve. Having control of the blow off valve allows us to command boost. With this control we can command any boost value we choose. The King Kong Procharged kit will work at 10,000ft as well as it does at 1000ft. At low elevations we can bleed a lot of boost off so we don't endanger the engine, high elevation the King Kong will build up to 17lbs of boost and keep the bike running at the desired 90 HP.
This is a pre-production King Kong. Those of you that saw it at the Edmonton Snow Show were STOKED, but noticed a few small issues we were already working on. Some noticed how close the shifter is to the belt case. This is a small issue we are dealing with. We have two fixes, just need to test them. We will either need to run the kit with a Rekluse or some sort of pneumatic shifting. We understand that some of you love the Rekluse, some hate it. So we are working on the right answer. Another option would be to go with smaller wheels inside the case, which will allow us to have a smaller case and still build the same amount of boost and allow for full use of the shifter. Second, the air intake is for sure something we are working on. At the minimum, it will have some sort of helmet and utilize Frog Skin or a like material to keep snow away. We have considered running the intake above the front fender but this creates other issues. The biggest perhaps being noise for the rider. When the Supercharger barks it would be right by your head, not something I personally would enjoy. Third, we have a plate aluminum skid plate that will be included with the kit to protect the Pro Charger.
The King Kong is looking to turn heads everywhere it goes, oh yeah and it whistles on idol!!
Available in Janruary for 2015-2016 KTM 450's
Soon after for 2015-2016 Yamaha 450'S
Click image for larger version
__________________
Chris McKinney
President of Raze Motorsports, Inc.
Cell 763-219-7102
Office: 888-3Boost4
www.razemotorsports.com
6 out of 6 members found this post helpful. Rate this post: Yes | No
The Following 4 Users Say Thank You to Raze Moto For This Useful Post:
007 (10-19-2016), boondocker97 (10-20-2016), pat84 (10-19-2016), Yetiman (10-20-2016)
  #2
Old 10-19-2016, 07:44 PM
byeatts byeatts is online now
Currently: Not set.
byeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond repute
Default
Quote:
How does it work?
I will be waiting for this system for our shop build CMX! love the supercharge concept, well done. Mod Shop
The Following User Says Thank You to byeatts For This Useful Post:
screech (10-19-2016)
  #3
Old 10-20-2016, 06:24 AM
broke'n'nuts broke'n'nuts is offline
Currently: Not set.
Basic Member
broke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud of
Default
Ball park cost?
  #4
Old 10-20-2016, 09:24 AM
Raze Moto's Avatar
Currently: Hay Days
Garage
Default
We are looking at $5900.00 US Depending on what the answer is for the clutch.
__________________
Chris McKinney
Cell 763-219-7102
Office: 888-3Boost4
The Following User Says Thank You to Raze Moto For This Useful Post:
broke'n'nuts (10-20-2016)
  #5
Old 10-20-2016, 11:14 AM
boondocker97 boondocker97 is offline
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
Default
Is there still an actual rev limiter programmed in to protect the valve train if you are getting too high in the RPM range without it knocking?
__________________
Current Sleds:
2014-2018ish BDX Pro-Lite 900, 2005 M7 with upgrades - Ol' Reliable, 1974 Cheetah
Still in the Family:
2009 M1300, 2001 Mountain Cat 800 LE, 1972 Kitty Cat
Gone but not Forgotten:
1999 Powder Special 600 LE, 1998 Powder Special 600, 1993 EXT 550, 1980 JAG 340
  #6
Old 10-20-2016, 12:31 PM
barefooter barefooter is offline
Currently: Not set.
barefooter has a reputation beyond reputebarefooter has a reputation beyond reputebarefooter has a reputation beyond reputebarefooter has a reputation beyond reputebarefooter has a reputation beyond reputebarefooter has a reputation beyond reputebarefooter has a reputation beyond reputebarefooter has a reputation beyond reputebarefooter has a reputation beyond reputebarefooter has a reputation beyond reputebarefooter has a reputation beyond repute
Default
I'll be the idiot. What's a snike?
  #7
Old 10-20-2016, 12:33 PM
NEWDUCK NEWDUCK is offline
Currently: one ski dreams
Basic Member
NEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond repute
Default
Quote:
s(nowb)ike
  #8
Old 10-20-2016, 01:05 PM
screech screech is offline
Currently: cant wait for snow just like everyone else.
screech has a reputation beyond reputescreech has a reputation beyond reputescreech has a reputation beyond reputescreech has a reputation beyond reputescreech has a reputation beyond reputescreech has a reputation beyond reputescreech has a reputation beyond reputescreech has a reputation beyond reputescreech has a reputation beyond reputescreech has a reputation beyond reputescreech has a reputation beyond repute
Default
Sn(owb)ike
  #9
Old 10-20-2016, 05:21 PM
needpowder's Avatar
needpowder needpowder is online now
Currently: dreaming of global cooling
needpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond repute
Default
A terrible name for a snow bike.
Sweet supercharger though!
__________________
2016 YZ450fx w/16 TS LT
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following 4 Users Say Thank You to needpowder For This Useful Post:
Corban_White (10-27-2016), Sheetmetalfab (10-20-2016), wwillf01 (10-21-2016), yooper01 (10-21-2016)
  #10
Old 10-21-2016, 04:50 AM
nilsmountain nilsmountain is online now
Currently: Not set.
nilsmountain has a reputation beyond reputenilsmountain has a reputation beyond reputenilsmountain has a reputation beyond reputenilsmountain has a reputation beyond reputenilsmountain has a reputation beyond reputenilsmountain has a reputation beyond reputenilsmountain has a reputation beyond reputenilsmountain has a reputation beyond reputenilsmountain has a reputation beyond reputenilsmountain has a reputation beyond reputenilsmountain has a reputation beyond repute
  #11
Old 10-27-2016, 08:04 PM
Raze Moto's Avatar
Currently: Hay Days
Garage
Click Here to Register
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Raze Motorsports Inc Thread Starter — Tree rider Forum — Snow bikes Replies — 5 Last Post — 10-20-2016 08:51 AM
Thread — Raze motorsports Thread Starter — Sheetmetalfab Forum — Snow bikes Replies — 35 Last Post — 09-25-2016 06:51 PM
Thread — It's on like Donkey Kong! Fight nights a comin! Thread Starter — PJ-Hunter Forum — Fouled Plug Replies — 13 Last Post — 06-13-2011 06:38 AM
Thread — It's On Like Donkey Kong! (BDSO) Thread Starter — RIP N TEAR Forum — General Snowmobiling Replies — 49 Last Post — 02-21-2010 08:50 PM
no new posts
