Upgrade to Premium
Arctic Cat: Powder Special and older 2000 and older, all models in the Powder Special chassis and older chassis models
Reply
  #1
Old 10-18-2016, 09:56 PM
ponchonutty ponchonutty is offline
Currently: Not set.
Basic Member
ponchonutty is an unknown quantity at this point
Default 1993 Jag extra crispy
Hi guys. It's been a little while since I've been here. I bought a new project sled. Previous owner decided to use either instead of fixing the choke and used a little too much one time. It backfired and caught it on fire. How he didn't lose it I will never know. Slowly I am obtaining parts and will keep this updated as things go
Click image for larger version
ID:	273785   Click image for larger version
ID:	273786   Click image for larger version
Rate this post: Yes | No
  #2
Old 10-27-2016, 11:02 AM
salidadan salidadan is offline
Currently: Not set.
Basic Member
salidadan is an unknown quantity at this point
Default
I have two 89 Jags.... looking forward to see your progress
  #3
Old 10-29-2016, 05:28 PM
Currently: Not set.
Basic Member
Default
Thanks. It's been a little slow going so far. Found out the carb on it is junk and appears as if it's not the correct one. It is a 32mm while the book calls for 34mm. I lucked on a NOS for $50 so we will see if I can get it running. Finally got what I feel is the correct harness. Hopefully this weekend I can get the time to play with it.
  #4
Old 10-30-2016, 11:34 PM
Currently: Not set.
Basic Member
Default
Got the NOS carb that's correct for the sled mounted over the weekend. Within 4-5 pulls started right up!!! I have to clean out the tank yet. Don't think fuel should look like orange juice
ID:	274450   Click image for larger version
ID:	274451   Click image for larger version
  #5
Old 01-24-2017, 12:11 AM
Currently: Not set.
Basic Member
Default
Well now I'm at a roadblock. I can't for the life of me get this to run. It will fire if I dump fuel down the plug holes until it burns that off. Twice it seemed to run longer and I thought I was good to go only to have it stall and not restart. Here's the list of what I've done:
New NOS carb
New fuel lines
New fuel pump
New plugs
New fuel pickup or that weighted thing in the tank
New crank seals
I didn't replace line in tank because it was still real pliable and seemed fine. I did bypass the petcock and new inline filter. I plan to replace tje inside fuel line and also open up the carb even though it's brand new to check to see if the float is stuck or what. Any other ideas?
  #6
Old 01-24-2017, 09:38 AM
olymon's Avatar
olymon olymon is offline
Currently: project parts searching
olymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond repute
Default
Impulse line to the fuel pump pinched maybe? What is the compression?
Making JIS screws into junk
The Following User Says Thank You to olymon For This Useful Post:
89sandman (01-24-2017)
  #7
Old 01-26-2017, 02:04 AM
Currently: Not set.
Basic Member
Default
UPDATE!!! Appears that I have issues with the replacement lines I ran for fuel. When they get cold they are allowing air to seep in around the nipples they are slipped on. Bought better grade line and will replace them. The previous fuel lines I bought were at a farm place and the lines are suppose to be for lawn tractors. I didn't like them from the start because they are crazy stuff and were a pain to run.
  #8
Old 02-06-2017, 12:03 AM
Currently: Not set.
Basic Member
Default
Ok so I have this 98% back together. Was able to do a few yard runs and man, was I impressed!!!! Anyways, I need to know how the lights are wired up. I know I had them before and the brake light is on and working but no headlights. I also need to find out how to wire the factory heated grips too.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Do you have an extra sled? I have an extra car. Thread Starter — franced Forum — Colorado Replies — 1 Last Post — 10-25-2013 05:39 PM
Thread — Help with a jag Thread Starter — arcticat4eva Forum — Arctic Cat: Powder Special and older Replies — 1 Last Post — 01-03-2013 12:43 AM
Thread — ol jag Thread Starter — joshkoltes Forum — Vintage Replies — 2 Last Post — 06-15-2010 02:21 PM
Thread — extra lite/extra 10 Thread Starter — gogglefurnace Forum — Polaris: GEN 2 Replies — 12 Last Post — 01-08-2010 07:11 AM
Thread — 1993 artic cat JAG AFS 156" Thread Starter — Chuckr Forum — Sleds Replies — 0 Last Post — 06-16-2009 12:19 AM
