Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 10-17-2016, 03:37 PM
SnoDmon's Avatar
SnoDmon SnoDmon is offline
Currently: Avoid Power Addiction(PAR) like the plague!
SnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond repute
Question 1085 PSI Genesis - Pre-mix compatible or NOT???
I have a 1085 that I will start running this Winter. I am planning on going with Pre-mix fuel. I do not want to mess around with fabbing the chassis to allow the oil pump lever to clear nor do I want to add an oil reservoir, pump and lines.
My question is: HOW DO I KNOW IF THIS ENGINE IS PRE-MIX COMPATIBLE?
Were they all compatible? Is there something I should look into or an easy way to check? I'd like to NOT tear the engine down to confirm if possible.
When I got my hands on it, it did NOT have an oil pump or lines attached. It was otherwise complete. I only see the crank pulse port for the fuel pump and 2 check valves for oil ports, 1 on the MAG side and 1 on the PTO side. To me that doesn't seem like it would provide an adequate amount of oil to run oil injection alone. Hope to run this on strictly high octane/redline pre-mix!
__________________
>~*SnoDmon*~<
When in Doubt, Throttle it out!!!
'09 Polaris IQr 153"
'05 Polaris 900 RMK 174" - rollin' on 10"s
'96 Polaris Indy Ultra RMK - draggin asphalt!
Rate this post: Yes | No
  #2
Old 10-31-2016, 11:00 AM
SnoDmon's Avatar
Default
__________________
>~*SnoDmon*~<
  #3
Old 10-31-2016, 07:03 PM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
Default
Injection ports plugged?
If I remember correctly, there is a port within the case that should be open.
Wayde?
__________________
OEM parts from Free Agent
Ambassador for:
FB & IG: Scott Stiegler
Honestly, Honey!!! The shop paid for these mods. They sponsor me now. Really!
Check out these cool products:
  #4
Old 10-31-2016, 10:03 PM
Turbotater's Avatar
Turbotater Turbotater is offline
Currently: counting spuds
Turbotater has a reputation beyond reputeTurbotater has a reputation beyond reputeTurbotater has a reputation beyond reputeTurbotater has a reputation beyond reputeTurbotater has a reputation beyond reputeTurbotater has a reputation beyond reputeTurbotater has a reputation beyond reputeTurbotater has a reputation beyond reputeTurbotater has a reputation beyond reputeTurbotater has a reputation beyond reputeTurbotater has a reputation beyond repute
Default
I've never seen one that wasn't drilled for premix.
You can pull the reed valves, run the piston to the top and look inside to see if it's drilled.
  #5
Old 10-31-2016, 10:12 PM
Scott's Avatar
Garage
Default
I think that's what I was thinking of.
__________________
Ambassador for:
  #6
Old 11-07-2016, 02:44 PM
SnoDmon's Avatar
Default
Good strategy Tater. I was thinking I would have to tear it down to find out. I hope that will allow enough access. Thank you!
__________________
>~*SnoDmon*~<
  #7
Old 11-20-2016, 11:25 PM
peaceofwork peaceofwork is offline
Currently: Internet Rmkpro 800apprentiship
Basic Member
peaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond repute
Default
would the liberty 800 ports be the same ?one new to me 04 vertical escape 159 800 has no oiling system on it. when the jugs are off I can see on the right and left sides its drilled diagonaly to about the crank seal.?
  #8
Old 11-20-2016, 11:36 PM
Scott's Avatar
Garage
Default
I can't say exactly, but I know that they are NOT Polaris cylinders nor is it a Polaris case.
It's not a Polaris engine.
It's a full PSI engine design. These aren't bolt-on to end kits.
__________________
Ambassador for:
  #9
Old 11-22-2016, 01:29 AM
Goinboardin's Avatar
Goinboardin Goinboardin is online now
Currently: ..current
Goinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond repute
Default
Quote:
This sounds like it has been drilled. From Polaris, there were casting dimples there but no hole. If you're running premix, the holes need to be drilled to provide oil out to the outer bearings (both MAG and PTO). I used a 3/16" or 1/4" drill bit when I drilled mine. The drilled hole should intersect the factory, fitting fed hole, on the PTO side. Then that hole should be opened up towards the seal because the outermost PTO side bearing actually covers up part of that hole. If you go to Indy Specialty's website, and look at their Torque Master bottom ends, you'll get a better idea. Unfortunately I didn't take pictures when I did mine, or they were deleted at some point.
__________________
2013 XM 800 153
The Following User Says Thank You to Goinboardin For This Useful Post:
peaceofwork (12-29-2016)
  #10
Old 11-22-2016, 10:47 AM
Scott's Avatar
Garage
  #11
Old 12-04-2016, 04:47 PM
slash's Avatar
slash slash is offline
Currently: ahhh back to work
Parts Moderator & Chat Box Cop
slash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond repute
Garage
Click Here to Register
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Looking at a 1085 PSI Genesis, what do I need to know? Thread Starter — SnoDmon Forum — Polaris Replies — 2 Last Post — 12-27-2013 08:12 PM
Thread — Pre mix Thread Starter — moly may Forum — Polaris: Pro-Ride Replies — 2 Last Post — 04-10-2013 12:23 AM
Thread — WTB: Polaris PSI 1085/1155 top end & PSI crankcase Thread Starter — lake Forum — Engine/Engine Parts (Swapmeet) Replies — 3 Last Post — 03-05-2013 10:08 PM
Thread — pre mix Thread Starter — Snowedunder Forum — Performance/Modified Replies — 2 Last Post — 08-20-2009 09:48 PM
Thread — PSI Genesis 1085 w/ Cat mounts Thread Starter — pride0810 Forum — Engine/Engine Parts (Swapmeet) Replies — 5 Last Post — 01-22-2008 11:28 PM
no new posts
