Upgrade to Premium
Reply
  #1
Old 10-10-2016, 11:54 AM
TRACKS USA's Avatar
TRACKS USA TRACKS USA is offline
Currently: We Sell Tracks and Extensions
SnoWest Commercial Sponsor
TRACKS USA has a reputation beyond reputeTRACKS USA has a reputation beyond reputeTRACKS USA has a reputation beyond reputeTRACKS USA has a reputation beyond reputeTRACKS USA has a reputation beyond reputeTRACKS USA has a reputation beyond reputeTRACKS USA has a reputation beyond reputeTRACKS USA has a reputation beyond reputeTRACKS USA has a reputation beyond reputeTRACKS USA has a reputation beyond reputeTRACKS USA has a reputation beyond repute
Default 154" & 165" Conquer Tracks - Now In Stock - Specs too
We recently received our first shipment of 3.5" pitch Conquer tracks. These are the 154" and 165" lengths. According to our scale, the weights are as follows:
9341M - 154x15x2.8 - 40lbs
9340M - 165x15x2.8 - 43lbs.
We were a little skeptical ourselves on the reported weights until we took delivery.
Between lug design and rotating mass this will definitely be one of the easiest performance upgrades for your mountain sled.
Click image for larger version
ID:	273384   Click image for larger version
Rate this post: Yes | No
  #2
Old 10-15-2016, 09:06 AM
TRACKS USA's Avatar
Default Reference to drivers
Attached are several photos showing driver styles. From left to right: Polaris center drive, Polaris window drive, Arctic Cat & Ski-Doo.
For Polaris you will have two options, you can use the standard center port drive or switch to the window drive (where clips are located). There are pro / cons of each. If you stay with the stock drive setup, the track will have to be run tighter to prevent ratcheting. If you are running a 3.5" pitch Conquer, you will be installing 6 tooth sprockets and you will not have much contact patch between track and sprocket. If deciding to run window drive sprockets, rail tips will need to be trimmed for clearance and an anti-stab kit will be necessary. If the anti-stab kit ever fails, track damage is eminent.
Ski-Doo and Arctic Cat / Yamaha remain similiar to stock.
Name:	Center Port Drive.jpg
ID:	273551   Click image for larger version
Name:	Window Drive.jpg
ID:	273552   Click image for larger version
The Following User Says Thank You to TRACKS USA For This Useful Post:
Teth-Air (11-01-2016)
  #3
Old 11-01-2016, 08:33 AM
gohard123 gohard123 is offline
Currently: Not set.
gohard123 is an unknown quantity at this point
Default
Will stock drivers work on '16 Arctic Cat 153" x 2.8"? or do you have to go to Avid drivers?
  #4
Old 11-11-2016, 03:17 PM
TRACKS USA's Avatar
Default
If you have the 3" lug track, you should have 7 tooth drivers and the 2.8" Conquer will certainly work. If you have the 2.6" powerclaw, you should have 8 tooth drivers and the clearance will be getting tight possibly requiring you to step down to the 7 tooth.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Any 163" owners opting back to a 154" over the new 165"? Thread Starter — lostinaction Forum — Ski-Doo: REV Gen 4 Replies — 8 Last Post — 02-25-2016 12:58 AM
Thread — NEW 155" & 163" Polaris Tracks $400 Thread Starter — Carls Cycle Forum — Tracks (Swapmeet) Replies — 6 Last Post — 01-02-2011 10:57 PM
Thread — 2 Ski-Doo 154" x 16" tracks Thread Starter — Snoclo Forum — Tracks (Swapmeet) Replies — 2 Last Post — 03-01-2010 06:33 PM
Thread — 153" & 136" Tracks For Sale in Canada Thread Starter — uzeste Forum — Tracks (Swapmeet) Replies — 15 Last Post — 10-27-2008 12:25 PM
Thread — Leave it stock or "set it up" for the 1st trip, that is the question....08 XP 154" Thread Starter — JLeosnow Forum — Ski-Doo Replies — 14 Last Post — 12-16-2007 08:30 PM
no new posts
