Upgrade to Premium
Arctic Cat: TURBO Turbo discussion for Arctic Cat aftermarket turbo sleds
Reply
  #1
Old 08-12-2016, 06:48 AM
westbound1 westbound1 is offline
Currently: Tree magnet
Basic Member
westbound1 is an unknown quantity at this point
Default 07 M8 OVS turbo kit need advice
Currently installing an OVS race gas kit on my 07 M8. The kit came complete with everything I need, but Im having an issue with the head. Currently have an RK Tek head with high elevation domes which I don't believe will work, so my question, is there a certain year stock M8 head that I could get for cheap that will lower the compression enough? Or just suck it up, RK wants 230 bucks for a new set of domes.
Rate this post: Yes | No
  #2
Old 08-12-2016, 03:35 PM
Ricks 32 Ricks 32 is offline
Currently: Not set.
Ricks 32 has a reputation beyond reputeRicks 32 has a reputation beyond reputeRicks 32 has a reputation beyond reputeRicks 32 has a reputation beyond reputeRicks 32 has a reputation beyond reputeRicks 32 has a reputation beyond reputeRicks 32 has a reputation beyond reputeRicks 32 has a reputation beyond reputeRicks 32 has a reputation beyond reputeRicks 32 has a reputation beyond reputeRicks 32 has a reputation beyond repute
Default
I had a 2010 M8 with OVS Race gas kit. I used the lower compression head from an '09 for the first season, and then switched back to the higher compression the second season. I'd look for a stock '07 to '09 head to start with. I'd recommend calling Garr at OVS directly.
Good luck
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to Ricks 32 For This Useful Post:
westbound1 (08-16-2016)
  #3
Old 08-16-2016, 07:44 PM
mk2g60's Avatar
mk2g60 mk2g60 is offline
Currently: Not set.
mk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond repute
Default
Have your stock head remachined for the elevation you ride. OVS did both 600 & 800 heads for our race sleds zero issues.
  #4
Old 10-09-2016, 09:50 PM
Vertical-Extreme's Avatar
Vertical-Extreme Vertical-Extreme is online now
Currently: Braaaaap
Vertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond repute
Garage
Default
Use a stock head or get Brent at Arctic Edge to cut a stock 07 head for you.
__________________
The ultimate Stock Bore M8000 PC: Full Jaws Set up - Reaper Hood - Custom Cold Air Intake - BD Fuel Control - Arctic Edge Clutching - Arctic Edge Tuning-TKI Belt Drive W/ oil delete - Gripper Skis - 3" C3 post forward kit, PHC 7 deg. bars '16 front end.
  #5
Old 02-18-2017, 08:29 AM
Hardass's Avatar
Hardass Hardass is offline
Currently: Not set.
Hardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond repute
Default
09 head is what you want
__________________
M 1000 modded but no turbo no way Uh well maybe
  #6
Old 02-18-2017, 10:18 AM
Snowmow's Avatar
Snowmow Snowmow is online now
Currently: Not set.
Snowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond repute
Default
What elevation, how much boost you want to run and what fuel your running??
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — M8 OVS rg turbo kit Thread Starter — Hillclimbpro Forum — Turbos/Superchargers (Swapmeet) Replies — 0 Last Post — 01-03-2015 12:02 PM
Thread — OVS turbo kit for polaris 800 cfi 4. complete kit Thread Starter — sledneck700 Forum — Turbos/Superchargers (Swapmeet) Replies — 7 Last Post — 03-29-2012 07:18 PM
Thread — M6 M7 M8 OVS Turbo Kit Thread Starter — Atwitch Forum — Turbos/Superchargers (Swapmeet) Replies — 2 Last Post — 10-22-2010 05:02 PM
Thread — M7 OVS Turbo Kit Thread Starter — Muff Man Forum — Turbos/Superchargers (Swapmeet) Replies — 13 Last Post — 10-17-2008 08:46 AM
no new posts
