Upgrade to Premium
Ski-Doo: S-2000 and older 1998 and older, all models in the S-2000 chassis and older chassis models
Reply
  #1
Old 05-25-2016, 01:35 PM
BeetleKill BeetleKill is offline
Currently: Not set.
Basic Member
BeetleKill has a reputation beyond reputeBeetleKill has a reputation beyond reputeBeetleKill has a reputation beyond reputeBeetleKill has a reputation beyond reputeBeetleKill has a reputation beyond reputeBeetleKill has a reputation beyond reputeBeetleKill has a reputation beyond reputeBeetleKill has a reputation beyond reputeBeetleKill has a reputation beyond reputeBeetleKill has a reputation beyond reputeBeetleKill has a reputation beyond repute
Default Replacement Skis
I just picked up a 97 Formula 500 deluxe for my son to ride.
The sled is all stock and in good shape but I would like to put some more modern skis on it.
Has anyone put skis from a newer skidoo on one of these? Did you need to customize the mount/saddle?
I would like to put a single keel/ runner type one. My son will be 8 by next season. I would like to use a ski that keeps the steering effort kinda light.
Thanks for any suggestions.
I'm looking forward to going sledding with my son!!
Rate this post: Yes | No
  #2
Old 05-25-2016, 10:44 PM
Reg2view Reg2view is online now
Currently: Not set.
Reg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond repute
Default
Most modern plastic skis will offer a saddle for those spindles, it was a very standard spindle/saddle design used through at least 2008 on certain models. Both the original doo plastic single runner and dual runners will also work (I've had a long line of doos, including S-2000 chassis 97 440 MXZx's, and every chassis from Formula through XP, swapped skis among them with simple saddle changes.) So will Simmons. No need to mod the spindle, just rubbers and ski saddles. I'm assuming it has the original 1-ton OEM metal skis now. My kids did well with the doo dual runners on the S, ZX, and Freestyle chassis's, still can be had at swap meets. Low dart, easy steer, good bite. Good luck.
The Following User Says Thank You to Reg2view For This Useful Post:
BeetleKill (05-26-2016)
  #3
Old 07-14-2016, 12:47 PM
caproskis's Avatar
caproskis caproskis is offline
Currently: Skis for Mountain, Trail, Crossover and Race
caproskis has a reputation beyond reputecaproskis has a reputation beyond reputecaproskis has a reputation beyond reputecaproskis has a reputation beyond reputecaproskis has a reputation beyond reputecaproskis has a reputation beyond reputecaproskis has a reputation beyond reputecaproskis has a reputation beyond reputecaproskis has a reputation beyond reputecaproskis has a reputation beyond reputecaproskis has a reputation beyond repute
Default
Our Trail X (TRX) Skis would be a great option for your son's sled. They work great on the trails and have minimal steering effort.
More details can be found here: https://www.caproskis.net/trx
Our skis come with the mount kits and you will not need to modify the saddle in any way. Feel free to give us a call if you have any questions.
__________________
High Performance Snowmobile Skis
www.caproskis.com
888-321-6789
  #4
Old 09-24-2016, 11:25 PM
AZ800 AZ800 is offline
Currently: Not set.
Basic Member
AZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond repute
Default
Rev dual keel skis are direct bolt on. Forget what I used for the ski rubbers, but I didn't buy any that I recall.
I was able to run them inboard and narrow up the stance by a couple inches, it needs it.
Got a formula 380 for my younger boy, he was riding it when he was 7. Now 10 and should be able to manhandle it a little in the powder now.
136x16x1.25 track was pretty much a bolt in too with rail and tunnel ext of course.
One cool thing that works, if the kid is short, since the tank/seat is so wide, is mount the foot brackets for a 2 up skidoo on the existing running boards. Much better traction and raises the footprints enough to help with the big wide seat.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — M1000 reed replacement;TPS adj; drive shaft bearing replacement; tank replacement Thread Starter — Sledbrain2 Forum — Arctic Cat: M Series Replies — 0 Last Post — 01-16-2016 09:38 PM
Thread — Opinions on Replacement Skis Thread Starter — 900Spartan Forum — Polaris: 900 Replies — 7 Last Post — 02-15-2011 10:15 PM
Thread — Where to get replacement carbides for simmons skis Thread Starter — mtndoo800 Forum — Mountain/Deep Powder Replies — 4 Last Post — 09-22-2009 05:36 PM
Thread — WTB replacement skis for 99 Venture Thread Starter — Shylohdog Forum — Skis (Swapmeet) Replies — 0 Last Post — 02-08-2009 07:00 PM
Thread — simmons skis slp pipes and skis fabcraft holz and a lot more Thread Starter — Osborne Performance Forum — Skis (Swapmeet) Replies — 1 Last Post — 02-18-2008 11:15 AM
no new posts
