Upgrade to Premium
Member Sled Builds A forum for building a project or mod sled.... Not just your common "Mods", but full on sled build projects.
Reply
  #1
Old 04-13-2016, 06:31 PM
mattymac's Avatar
mattymac mattymac is offline
Currently: investing in lead
mattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond repute
Default Old school, big power
Putting together an "Old School" big hp big tq mod triple, no turbo twin here! Plenty of updates to come heres a bit of whats gonna be happening
1500 cat triple (technically 1462cc) two cat 900 twins made into a 3 cyl version (cut and welded cases) bored cyls and running M1000 pistons
Cut and welded cases, two twin cranks built into a 3 cyl version, BB cyls, triple rack carbs, jaws pipes, should be pushing the 300 sea level hp mark with mostly factory parts/factory reliability such as the polaris watercraft motors just with bigger internals, more cc's no high dollar exotic/expensive parts and way more HP/TQ. Holz rear 151 rear skid, ZR 43" wide front end for suspension
motor is going into an 03 151 with a few minor upgrades, basically im wanting this build to be the factory style mod sled cat should have built... more to come!!!
__________________
1200 WC triple
1500 cat triple
impulse apex
900 VE cat
"hey your ski is under your belly pan!"
7 out of 7 members found this post helpful. Rate this post: Yes | No
The Following 24 Users Say Thank You to mattymac For This Useful Post:
freekweet mods (11-09-2018), greencat900 (04-14-2016), hamlin (04-13-2016), higherpower (04-23-2016), Idcatman3 (04-15-2016), Jersleds (11-14-2016), joshkoltes (04-28-2016), Karlstrøm (04-14-2016), kbl6z (04-14-2016), kiliki (04-21-2016), KMOD (04-16-2016), meathooker (12-16-2016), Nickname (11-10-2016), NorthMNSledder (05-16-2016), Norway (04-14-2016), pus1100 (06-06-2016), Reeb (04-20-2016), Scott (04-21-2016), skidawg (04-27-2016), Snow Duck (04-14-2016), snowmobiler (04-13-2016), Solby (04-26-2016), Suregom (10-16-2016), volcano buster (04-14-2016)
  #2
Old 04-15-2016, 09:51 PM
Idcatman3's Avatar
Idcatman3 Idcatman3 is offline
Currently: Not set.
MODERATOR: Premium Member
Idcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond repute
Garage
Default
Matty,
I meant to show you this earlier. The mag side rear motor mount that we made for our second one you can see in the picture below. You might think of doing something similar. Then it uses the stock mount on the case. The way I described to you on the phone, you have to monkey with the heat exchanger outlets. This way you don't.
__________________
Arctic Cat 1M and PS Moderator
'04 1M 1500 162" Challenger Extreme, M8 rear suspension, Custom jetting, clutching and gearing
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 04-21-2016, 08:32 AM
mattymac's Avatar
Default
day job is getting in the way of this right now! Getting the carb shafts built, pipes are on the way! Still just gathering parts up!! Should have some new updates in the next few days.
__________________
1200 WC triple
1500 cat triple
impulse apex
900 VE cat
  #4
Old 04-21-2016, 10:05 PM
KMMAC KMMAC is offline
Currently: KEEP AN EYE OPEN WHILE YOU SLEEP
KMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond repute
Default
What ignition are you going to use?
  #5
Old 04-21-2016, 11:21 PM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
ha ha your WC poo has you thinking too hard.
  #6
Old 04-22-2016, 08:26 AM
mattymac's Avatar
Default
thundercat ignition, also using ZRT choke cables, thundercat and king cat parts for the water rail/thermostat housing.
__________________
1200 WC triple
1500 cat triple
impulse apex
900 VE cat
The Following User Says Thank You to mattymac For This Useful Post:
KMMAC (04-23-2016)
  #7
Old 04-24-2016, 12:02 PM
mattymac's Avatar
Default
the fuel pump im gonna be running is the mikuni DF62-702, dual 5/16 outlet 3/8 inlet and flows 65 LPH. I have had great luck with this pump on all my other big triples moves plenty of fuel to keep em happy. Also to the turbo guys you can run this pump in a water to air setup (no electrical draw) for the coolant! The triple rack carbs will have 2 inlets between the carbs so its a perfect pump for what I need.
__________________
1200 WC triple
1500 cat triple
impulse apex
900 VE cat
  #8
Old 04-24-2016, 06:04 PM
Currently: Not set.
Garage
Default
the pump is perfect!
also the motor look good, love the dual water pumps.
put up some pictures of the pipes when your done.
  #9
Old 04-29-2016, 10:04 AM
mattymac's Avatar
Default
had a little bit of time yesterday tinkering with the rear mag motor mount. I was going to do the outboard style like scott did but silencer, recoil room, and recoil rope routing made me go this route. its not done obviously but kind of a rough idea. The best thing is how the stock twin coolant line routes up through from the t-stat housing. the angle of the pix dont show but theres at least a 1/4" of clearance around the mount and bulkhead, it fits perfect! just need to extend the top flat section of the hose for the added length of the motor.
The mount will get welded up along with some triangle gussets on the sides. The rubber factory mount will get bolted to the bulkhead, still some trimming but this is what I figured since the older cat triples had a "pedestal style mount" somewhat of the same idea.
http://thumbs1.ebaystatic.com/d/l225...cYZkOXnVIw.jpg
__________________
1200 WC triple
1500 cat triple
impulse apex
900 VE cat
  #10
Old 04-29-2016, 10:07 AM
mattymac's Avatar
  #11
Old 04-29-2016, 03:48 PM
Currently: Not set.
Garage
Click Here to Register
  #12
Old 04-29-2016, 06:27 PM
mattymac's Avatar
  #13
Old 04-29-2016, 06:33 PM
mattymac's Avatar
  #14
Old 04-30-2016, 06:46 AM
gus bohne gus bohne is offline
Currently: Not set.
Basic Member
gus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond repute
  #15
Old 04-30-2016, 05:51 PM
mattymac's Avatar
  #16
Old 04-30-2016, 05:57 PM
Currently: Not set.
Garage
  #17
Old 04-30-2016, 06:05 PM
mattymac's Avatar
  #18
Old 05-01-2016, 07:28 AM
Idcatman3's Avatar
Currently: Not set.
Garage
  #19
Old 05-02-2016, 06:32 AM
Currently: Not set.
Basic Member
  #20
Old 05-02-2016, 10:57 PM
mattymac's Avatar
  #21
Old 05-04-2016, 05:35 PM
mattymac's Avatar
mountainhorse (05-16-2016)
  #22
Old 05-04-2016, 08:53 PM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
  #23
Old 05-04-2016, 09:02 PM
Idcatman3's Avatar
Currently: Not set.
Garage
  #24
Old 05-05-2016, 08:58 AM
mattymac's Avatar
  #25
Old 05-05-2016, 08:47 PM
Idcatman3's Avatar
Currently: Not set.
Garage
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Driven Elite Backcountry Riding School - Northern Big Horns Thread Starter — Driven Forum — Calendar of Events Replies — 0 Last Post — 01-03-2015 12:03 PM
Thread — big horn power sports, sheridan Thread Starter — joshkoltes Forum — Snowmobile Employment Replies — 0 Last Post — 09-08-2014 04:35 PM
Thread — WTB: Power Addiction Edge Big Block motor plate Thread Starter — vinpie1 Forum — Engine/Engine Parts (Swapmeet) Replies — 1 Last Post — 11-06-2011 09:22 PM
Thread — Anyone running big power without tough boy bearing kit? Thread Starter — strippedhood Forum — Polaris: GEN 2 Replies — 4 Last Post — 12-18-2010 06:04 AM
Thread — D&d 1147 Big Bore Arctic Cat Power Thread Starter — RTI Forum — Engine/Engine Parts (Swapmeet) Replies — 10 Last Post — 06-05-2008 09:35 PM
no new posts
