Upgrade to Premium
Reply
  #1
Old 03-25-2016, 12:06 PM
SLP's Avatar
SLP SLP is online now
Currently: Not set.
SLP has a reputation beyond reputeSLP has a reputation beyond reputeSLP has a reputation beyond reputeSLP has a reputation beyond reputeSLP has a reputation beyond reputeSLP has a reputation beyond reputeSLP has a reputation beyond reputeSLP has a reputation beyond reputeSLP has a reputation beyond reputeSLP has a reputation beyond reputeSLP has a reputation beyond repute
Smile SLP Stage Kits for 2017 Models
No money down, no commitment to buy. Order an SLP Stage Kit of your choice for your 2017 model snowmobile to be delivered when you receive your sled in the fall. Make sure your new sled is prepared for that first ride next season. Simply give us a call and we will put an order in for you. We will bill and ship it to you when you are ready for it. Models that will be available at the time of sled delivery are; Arctic Cat 8000 , Polaris 800 and Ski-Doo 800. We anticipate there will be high demand for Ski-Doo 850 stage kits. Place your order now to get you to the top of that list. These kits will be available later in the season once testing is able to be completed.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to SLP For This Useful Post:
donbrown (05-02-2016), jonasumb (03-25-2016)
  #2
Old 05-09-2016, 09:11 AM
Timbre's Avatar
Timbre Timbre is offline
Currently: Let 'er SNOW!!
Timbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond repute
Default Cracking and Rusting SLP pipes
Did you get the cracking issues solved without using the "bandaid" (extra band) around the pipe?
Also had some pipes get pitted and rusted like the coating was not done well.
Heard they were having trouble getting you all to warranty the rusting pipes.
Hoping the new ones are better this year, as you all have had a pretty good reputation up to this point.
  #3
Old 06-23-2016, 06:17 PM
SLP's Avatar
Currently: Not set.
Default
Yes, we feel we have the cracking issues on the Axys 800 pipe that you refer to solved. On current production pipes, we still use one band clamp to dampen the harmonic vibration like we have used for many years. We also made some other changes that help make the pipe stronger in this area. We tested with these pipes extensively last season without failure, so we are confident that we have the problem solved.
Last year at the first of the riding season, some of our customers had some pipes fail at the probe boss. We immediately went to work to identify the problem and find a suitable solution. We found on those pipes that by placing a second band clamp on the other side of the probe boss that the harmonic resonance that was causing them to crack was eliminated. We sent update clamps out to our customers at no charge in an effort to eliminate failures. What we found was once we did this, the failures all but ceased. We have replaced the pipes that cracked up to this time.
As far as "rusting" pipes go, we inspect them closely to see what caused the issue and verify if it is a coating problem or something else. If it is a coating problem, we re-coat the item or replace it.
A couple of things to keep in mind regarding keeping your sleds in pristine shape are:
1) Keep them out of road chemical spray. This means covering your sleds when trailering on an open trailer or carrying them on a sled deck especially when the weather is bad or you will come in contact with roads treated with Mag-Chloride (the wet chemical most states are now using prior to and during storms). Should you find yourself without a cover and exposed to this, wash the sled immediately upon returning home (I would wash mine even if it were covered as this stuff is extremely corrosive). Remember that you need to also wash it inside the engine compartment to get it off of any under-hood components. One other thing a cover does for you is it keeps debris out of the intake. A sled's intake is not sealed very well as we ride in a fairly clean environment. But the environment we trailer through is anything but clean and we don't really want any of that garbage to be ingested into the engine.
2) If you use an enclosed trailer, you need to dry your sled and trailer out prior to storing your sled back in it until the next ride out. This is important because the inside of your trailer will hold a lot of moisture causing the humidity level to be extremely high. Even when the inside is dry, leave your vents open. I use a RV vent cap that goes over the stock reel up vent and allows the reel up vent to be open all the time. This really helps the trailer breathe and keep humidity levels low. This is actually more important for the inside of the engine than even the cosmetic components as internal engine components rely on oil film to keep them from rusting. If the sled sits for a while, the oil film can dissipate and if humidity levels are high, rust pits will form on items such as rod and main journals and bearings resulting in an engine failure down the road.
We pride ourselves in producing high quality products that perform as advertised. Should you have an issue with one of our products, please contact us so that we can address it properly.
Thanks for the questions,
Jerry Mathews
Starting Line Products, Inc.
4 out of 4 members found this post helpful. Rate this post: Yes | No
The Following 5 Users Say Thank You to SLP For This Useful Post:
980K (01-28-2017), B&M Fabrications (06-23-2016), SkiDooHoser (06-27-2016), Timbre (07-12-2016), xpspenziv (09-12-2016)
  #4
Old 09-12-2016, 07:21 PM
800poodragon's Avatar
800poodragon 800poodragon is offline
Currently: Not set.
800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute800poodragon has a reputation beyond repute
Garage
Default
Jerry Mathews
So there are no differences in the pipes for this year for the Axys than the pipes from last year?
__________________
Hold my beer and watch this....
  #5
Old 09-13-2016, 09:30 AM
Evanbcx's Avatar
Evanbcx Evanbcx is offline
Currently: Waiting for snow
Evanbcx has a reputation beyond reputeEvanbcx has a reputation beyond reputeEvanbcx has a reputation beyond reputeEvanbcx has a reputation beyond reputeEvanbcx has a reputation beyond reputeEvanbcx has a reputation beyond reputeEvanbcx has a reputation beyond reputeEvanbcx has a reputation beyond reputeEvanbcx has a reputation beyond reputeEvanbcx has a reputation beyond reputeEvanbcx has a reputation beyond repute
Garage
Default
What are the prices on the skidoo 850 pipe and can and do u have any pictures of them
  #6
Old 10-03-2016, 09:34 PM
Currently: Not set.
Garage
Default
Is there any way to know which were the earlier pipes with problems and which were the improved ones? Have a chance to buy a new pipe set and I know it is left over from last year. How do I know it is not a defective one?
__________________
The Following User Says Thank You to 800poodragon For This Useful Post:
jethro (10-04-2016)
  #7
Old 10-06-2016, 08:07 AM
SLP's Avatar
Currently: Not set.
Default
Quote:
We made a change to our Axys pipe at the end of December after some customers experienced cracking around the EGT bung. At that time the changes to the pipe involved a "y" shaped weld around the EGT bung plate. We also added a second band to help isolate harmonics and improve pipe life. Since the change to that design, I have only seen one pipe fail.
Through the snow season last year, we continued testing some other ideas for further improving durability. We put in countless hours and miles testing different options to make sure that what we came out with is the best solution and have since implemented it on the pipes we are now selling.
On our current production pipes, there are 2 new weld tie-ins, a new bung location and a new band location (see attached photo).
Also - we are now building a silencer with an integrated cooker mount. And we are now offering 3 different color options for the ceramic coating we use on our pipes and silencers: Black Satin, Silver Satin and Silver Polish.
-Adam
Click image for larger version
ID:	273214   Click image for larger version
  #8
Old 10-06-2016, 08:09 AM
SLP's Avatar
Currently: Not set.
Default
As long as you have 2 bands on the center section of the pipe, you will be fine.
-Adam
  #9
Old 10-06-2016, 09:05 AM
SLP's Avatar
Currently: Not set.
Default
Quote:
Here is a picture of a pipe that is still in prototype form that we are working with for the 850 G4. It looks like we'll be somewhere around 12 pounds on the weight savings. We aren't ready to release horsepower information yet, as we are still working on that project. As more information becomes available we'll let you know.
-Adam
Evanbcx (10-19-2016), tar (12-26-2016)
  #10
Old 11-06-2016, 10:25 PM
FCR112 FCR112 is offline
Currently: Not set.
FCR112 has disabled reputation
Default
Hello,
What year is this axys pipe/can and does it include the additional welds mentioned above under the shield?
Thanks
  #11
Old 11-10-2016, 01:42 PM
SLP's Avatar
Currently: Not set.
Click Here to Register
The Following User Says Thank You to SLP For This Useful Post:
FCR112 (11-11-2016)
Reply
Bookmarks
Tags
2017, 800 arctit cat, 800 axys, 800 e-tec, 850 ski-doo
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2017 Models Thread Starter — Rmkguy Forum — Polaris: AXYS Replies — 61 Last Post — 02-18-2016 03:59 PM
Thread — SLP stage tuning kits? Thread Starter — yamahahaha Forum — Arctic Cat: Proclimb M Replies — 6 Last Post — 08-28-2013 05:16 PM
Thread — SLP Stage 3 & 4 Kits Thread Starter — wolflake06 Forum — Polaris: Pro-Ride Replies — 0 Last Post — 12-24-2011 01:52 PM
Thread — Anyone running SLP stage kits? Thread Starter — yooper 8 Forum — Polaris: Pro-Ride Replies — 8 Last Post — 12-20-2011 07:17 PM
Thread — slp stage 2 kits for a 2010 m8 Thread Starter — Spiced Wafer Forum — Arctic Cat: M Series Replies — 18 Last Post — 10-19-2011 10:33 AM
no new posts
