Upgrade to Premium
Polaris: 900 05-06 Polaris RMK 900
Reply
  #1
Old 03-18-2016, 03:26 PM
SixtySevenGT's Avatar
SixtySevenGT SixtySevenGT is offline
Currently: Building Sleds
SixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond repute
Default Help Me ID Crank 30mm vs 32mm
Bought a used engine, it has been apart because the upper case has been cleaned up with a porting tool.
The person I bought it from said it had one cyl go down. That is obvious. So I got a few good parts.
Trying to id the Cranksaft. No real numbers on it
I don' have any large tape / small taper clutches just laying around.
It has 2 6802 koyo 40mm bearings on the pto end seperated by 2 spacers.
What do I measure to see if is large taper ?
__________________
"Always Drink Upstream from the Herd"
Rate this post: Yes | No
  #2
Old 03-20-2016, 11:11 AM
Default No one can identify a 30mm / 32mm crank ?
You have got to be kidding me.
No one knows the diffrence between a 30mm and a 32mm crankshaft ?
__________________
The Following User Says Thank You to SixtySevenGT For This Useful Post:
Snowmow (03-20-2016)
  #3
Old 03-20-2016, 12:12 PM
LoudHandle LoudHandle is online now
Currently: I'd rather snowshoe than be caught on a SKIDOO! I'm not feminine / gay enough to ride SkiDoo either.
LoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond repute
Default
The size refers to the major diameter "Large end" of the taper. Measure it just before the machined radius. Where the inboard end of the clutch taper sits when torqued.
__________________
ALASKA
  #4
Old 03-20-2016, 12:15 PM
Snowmow's Avatar
Snowmow Snowmow is online now
Currently: Not set.
Snowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond repute
Default
The difference is 2mm
I win.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #5
Old 01-14-2018, 10:04 AM
egefell egefell is offline
Currently: Not set.
Basic Member
egefell is an unknown quantity at this point
Default Primary Clutch Issue
I am dealing with a similar situation.. my sled is deep in the Montana backcountry right now and trying to get a replacement clutch to change out in the field. I realize there is a 30mm and a 33mm taper and would like to try and figure out which one i need without having to go back to my sled w/o the part.
I am on a 2006 RMK 900 159". The only numbers i was able to pull off the clutch was 5630392 08.
Anyone have info on this? The only this i was able to find was that the clutch will be different depending on where it was manufactured?
First sled, first post.
Thanks!
  #6
Old 02-07-2018, 02:35 AM
guidoxpress's Avatar
guidoxpress guidoxpress is offline
Currently: Tearing up Alaskas BOMB POW
guidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond repute
Garage
Default
They are visually diff Lee. Snap a pic of the pto end
Egefell,
Same for you but the clutch cover has a date etched in it. If the date is 2008-up it’s a 32mm.
__________________
"Too much, is not enough"
3 2016 Polaris AXYS.
06 RMK 900
His and Hers 16 badass AXYS builds
The Following 2 Users Say Thank You to guidoxpress For This Useful Post:
05900 (02-07-2018), Snowmow (02-07-2018)
  #7
Old 03-28-2018, 10:21 PM
Default
Measure at the RING on the Crank if used if not used then you can look at the crank casting
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Polaris dragon, Pro 32mm primary clutch (used) Thread Starter — guidoxpress Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 2 Last Post — 10-15-2017 01:20 AM
Thread — Wtb Polaris primary 32mm fixed cutch sheave Thread Starter — tinkerjohnson Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 0 Last Post — 08-31-2013 09:39 PM
Thread — poo 900 32mm clutch.& secondary Thread Starter — heinalanka Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 1 Last Post — 10-27-2011 06:38 PM
Thread — Are all '08 and newer polaris use the 32mm taper clutch/crank? Thread Starter — sno_mo_racer Forum — Polaris: 900 Replies — 20 Last Post — 05-09-2011 11:47 PM
Thread — NIB new polaris 32mm primary clutch Thread Starter — ndsleddealer Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 13 Last Post — 11-22-2009 07:05 PM
no new posts
