Upgrade to Premium
Ski-Doo: ZX Sleds 99-2005, all models in the ZX chassis
Reply
  #1
Old 02-21-2016, 09:35 AM
CatnDoo CatnDoo is offline
Currently: Not set.
Basic Member
CatnDoo is an unknown quantity at this point
Default Failed leak down test on a new 800 build......
Hey All
New 800 / 827 build with re-man BRP crank. Leak down test shows bubbles coming out of the mag side stator bolt holes. I loose 1/2 psi in 3 minutes.
On the 01 800 Crank you have a case to crankshaft seal which completely isolates the Isoflex greased PTO bearing from the internal pressures. When pressure testing the PTO side one should not see any air escaping from the external greasing elbow. Agreed?
But, on the MAG side such a seal does not exist. It appears that the inner MAG side bearing has an internal seal, but nothing to isolate internal pressures from the mag side isoflex bearing like the PTO side.
So when pressure testing the crankcase we have nothing specific to seal the outer circumference of the mag side bearings and the crankcase other than bearing fit to crankcase?
One then would have to ask: What keeps the MAG side isoflex grease from slowly washing out or getting contaminated by the internal engine pressures? Does it boil down to the bearing fit to case tolerances? I've read about many instances where case were opened and little to no isoflex remains in the MAG bearings. One has to ask where did the grease go?
Crank Gurus, please comment on this.
Should I expect my leak test to push slight amounts of air around the unsealed side of the MAG bearings and the crankcase and out the upper stator bolt hole?
Yellow Jacket
Rate this post: Yes | No
  #2
Old 02-21-2016, 02:44 PM
jheitzman's Avatar
jheitzman jheitzman is offline
Currently: Not set.
jheitzman has a reputation beyond reputejheitzman has a reputation beyond reputejheitzman has a reputation beyond reputejheitzman has a reputation beyond reputejheitzman has a reputation beyond reputejheitzman has a reputation beyond reputejheitzman has a reputation beyond reputejheitzman has a reputation beyond reputejheitzman has a reputation beyond reputejheitzman has a reputation beyond reputejheitzman has a reputation beyond repute
Default
Shoot... I could have sold you my '03 159 with a fresh 827... Saved you some time
Josh
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — KK leak down test Thread Starter — WAMort Forum — Arctic Cat: 1M Replies — 0 Last Post — 11-24-2011 09:58 AM
Thread — friend failed a Disa Pre-Employment alcohol test what to do now? Thread Starter — VmaX 600 Forum — Fouled Plug Replies — 33 Last Post — 11-20-2011 01:36 AM
Thread — Leak Down Test? Thread Starter — SpeedWobble Forum — Polaris: Pro-Ride Replies — 9 Last Post — 05-28-2011 10:36 AM
Thread — 07 800R failed the RAV test - what to do next? Thread Starter — akmclean Forum — Ski-Doo: REV Sleds Replies — 2 Last Post — 12-13-2009 02:56 PM
Thread — Leak Down Test ? Thread Starter — JOP Forum — Yamaha Replies — 9 Last Post — 07-26-2009 12:30 PM
