Upgrade to Premium
Yamaha: 4-Stroke Includes all Yamaha 4-strokes, Nytro, Apex, Phazer, etc
Reply
  #1
Old 02-18-2016, 11:25 AM
Boneless Boneless is offline
Currently: Not set.
Basic Member
Boneless is an unknown quantity at this point
Default Yamaha roll over valve parts?
I've got a 2010 nytro and the Yamaha roll over valve tether sticks on when it gets cold. Not sure if it ices up or what, but the plastic plunger doesn't want to go all the way down when the tether is pulled. I can tap it and it will shut off but that doesn't help if I'm not on the machine.
Does anyone know if the tether switch part is replaceable? Is there a better tether switch out there? I'd prefer not to have to replace the whole kit just the switch.
Thanks.
Rate this post: Yes | No
  #2
Old 02-18-2016, 03:52 PM
MTN_VIPER's Avatar
MTN_VIPER MTN_VIPER is online now
Currently: Making roll-over valve kits since 2008
MTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond repute
Default
I answered Boneless's question via e-mail and thought that I would post some info here for others as also.
The Yamaha/MPI ROV kit that was sold in the Yamaha accessories catalog uses a normally open tether switch. It can be replaced with any normally open tether switch of your choice.
To replace it, just cut the two wires going to the old switch and splice in the new switch.
The relays are also replaceable and you can use a standard sealed 5 terminal Bosch relay found at most larger auto parts stores. I prefer to use one in the 15 to 25 amp range as they are more resistant to relay contact oxidation at lower amperage loads.
If you need a shut off valve, I have replacements in stock as well.
HTH
Bill
__________________
Four Stroke Solutions LLC
Patented Roll-Over Valve Systems
ROV kits for M/XF7000/Viper, Sidewinder and King Cat with Quick-prime!
For Arctic Cat and Yamaha Sleds
Patents 8,225,766 8,528,516 9,303,537
http://fourstrokesolutionsllc.webs.com/
e-mail fourstrokesolutionsllc@hotmail.com
The Following User Says Thank You to MTN_VIPER For This Useful Post:
CB.8 (11-15-2016)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 4-Stroke Roll-Over Valve Thread Starter — ShaunBecker Forum — Arctic Cat: TURBO Replies — 1 Last Post — 12-12-2014 11:09 AM
Thread — $10.00 roll over valve? Thread Starter — stingray719 Forum — Nytros! Replies — 10 Last Post — 12-22-2013 10:49 PM
Thread — roll over valve Thread Starter — snowgood Forum — Nytros! Replies — 1 Last Post — 11-28-2013 05:54 PM
Thread — ROLL OVER VALVE ? Thread Starter — sledheadjake Forum — Arctic Cat: 1100 ProClimb Replies — 10 Last Post — 02-28-2013 12:00 AM
Thread — Roll Over Valve Issues Thread Starter — TheYamMan Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 6 Last Post — 02-11-2013 07:49 PM
no new posts
