Upgrade to Premium
Member Sled Builds A forum for building a project or mod sled.... Not just your common "Mods", but full on sled build projects.
Reply
  #1
Old 02-15-2016, 11:10 PM
farmerz24 farmerz24 is offline
Currently: Not set.
Basic Member
farmerz24 has a reputation beyond reputefarmerz24 has a reputation beyond reputefarmerz24 has a reputation beyond reputefarmerz24 has a reputation beyond reputefarmerz24 has a reputation beyond reputefarmerz24 has a reputation beyond reputefarmerz24 has a reputation beyond reputefarmerz24 has a reputation beyond reputefarmerz24 has a reputation beyond reputefarmerz24 has a reputation beyond reputefarmerz24 has a reputation beyond repute
Default Project minimalist tube frame
Going for somewhere close to 300 dry, complete minimalist build 151x15x2 track, rear axle drive, tube frame, Srv 540 fan engine spinning p85 clutches, arctic cat proclimb front suspension. Front swing arm will attach directly to driveshaft with 12+ inches of vertical travel.
Home made 11 inch poly front idlers and extended front arm.
Rear scissor will be external like RUSH to make room for rear chain drive.
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following 3 Users Say Thank You to farmerz24 For This Useful Post:
mountainhorse (02-25-2016), Scott (12-12-2016), Teth-Air (07-14-2016)
  #2
Old 02-16-2016, 12:17 AM
icr icr is offline
Currently: on another forum
Basic Member
icr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond repute
Default
Quote:
What
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 02-16-2016, 12:33 AM
bholmlate bholmlate is online now
Currently: currently looking for work to support my habit
bholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond repute
Default
put the pipe down gently and step away slowly
  #4
Old 02-16-2016, 08:28 AM
jskattum606 jskattum606 is offline
Currently: on the path to success
jskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond repute
Default
lets see a sketch
  #5
Old 02-16-2016, 08:36 AM
volcano buster volcano buster is offline
Currently: Not set.
volcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond repute
Default
With that much effort is the 151 the best track to use?
I'd be leary of too much attack angle.
  #6
Old 02-16-2016, 09:04 AM
Currently: Not set.
Basic Member
Default
Yes. Directly on the driveshaft.
The reason for this is so the chain drive can run directly down from driveshaft to rear front arm mount.
From there a second chain will run to the rear drive axle.
This is done so front chain tension will be constant as the front arm compresses through its foot of travel. front arm will be relocated to 6 inches from track bottom and 2 inches rear of stock. Front arm length will probably be a bit shorter. rails are from a xtra-12 polaris.
Click image for larger version
ID:	266682   Click image for larger version
ID:	266683   Click image for larger version
The Following User Says Thank You to farmerz24 For This Useful Post:
sportsterdanne (02-17-2016)
  #7
Old 02-16-2016, 04:39 PM
Currently: Not set.
Basic Member
Default
Quote:
Pick up the pipe and start thinking outside the box.
Otherwise we would still have bogie wheel suspension and leaf springs.
  #8
Old 02-16-2016, 05:43 PM
meathooker's Avatar
meathooker meathooker is offline
Currently: Making Feethookers!
meathooker has a reputation beyond reputemeathooker has a reputation beyond reputemeathooker has a reputation beyond reputemeathooker has a reputation beyond reputemeathooker has a reputation beyond reputemeathooker has a reputation beyond reputemeathooker has a reputation beyond reputemeathooker has a reputation beyond reputemeathooker has a reputation beyond reputemeathooker has a reputation beyond reputemeathooker has a reputation beyond repute
Default
very interesting. excited to see how this develops.
__________________
Meathooker's Feethookers
www.feethookers.com
We now offer boards for ALL brands!:
Arctic Cat Proclimb, M series / Polaris - Pro, IQ Raw, Edge, IQ, and IQr / Ski doo - XP and XM / Yamaha - Nytro
http://i629.photobucket.com/albums/u...climbgreen.jpg
Price $165-$185
  #9
Old 02-16-2016, 08:52 PM
olymon's Avatar
olymon olymon is offline
Currently: project parts searching
olymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond repute
Default
What are you going to do to keep the track tension goods enough to drive the track. Done kind of compensator like the M-10 had that would move to keep tension while the track compressed.
Sent from my PC36100 using Tapatalk 2
  #10
Old 02-16-2016, 11:32 PM
Wheel House Motorsports's Avatar
Wheel House Motorsports Wheel House Motorsports is offline
Currently: is it winter yet?
Wheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond repute
  #11
Old 02-17-2016, 11:03 AM
sportsterdanne sportsterdanne is offline
Currently: Not set.
sportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond repute
Click Here to Register
  #12
Old 02-21-2016, 09:35 PM
Visi Visi is offline
Currently: Not set.
Visi has a reputation beyond reputeVisi has a reputation beyond reputeVisi has a reputation beyond reputeVisi has a reputation beyond reputeVisi has a reputation beyond reputeVisi has a reputation beyond reputeVisi has a reputation beyond reputeVisi has a reputation beyond reputeVisi has a reputation beyond reputeVisi has a reputation beyond reputeVisi has a reputation beyond repute
  #13
Old 02-21-2016, 11:29 PM
Currently: Not set.
Basic Member
  #14
Old 02-21-2016, 11:34 PM
Currently: Not set.
Basic Member
  #15
Old 02-22-2016, 03:57 PM
M Cat M Cat is offline
Currently: :-)
Basic Member
M Cat has a brilliant futureM Cat has a brilliant futureM Cat has a brilliant futureM Cat has a brilliant futureM Cat has a brilliant futureM Cat has a brilliant futureM Cat has a brilliant futureM Cat has a brilliant futureM Cat has a brilliant futureM Cat has a brilliant futureM Cat has a brilliant future
  #16
Old 02-25-2016, 12:14 AM
Currently: Not set.
Basic Member
M Cat (03-05-2016)
  #17
Old 02-25-2016, 12:17 AM
Currently: Not set.
Basic Member
  #18
Old 02-25-2016, 01:00 PM
NEWDUCK NEWDUCK is online now
Currently: one ski dreams
Basic Member
NEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond repute
  #19
Old 02-25-2016, 06:16 PM
pro1000 pro1000 is offline
Currently: Not set.
Basic Member
pro1000 is an unknown quantity at this point
  #20
Old 02-25-2016, 11:08 PM
Currently: Not set.
Basic Member
  #21
Old 02-27-2016, 07:19 PM
Currently: Not set.
Basic Member
Norway (04-14-2016)
  #22
Old 02-27-2016, 08:15 PM
Currently: Not set.
Basic Member
  #23
Old 02-28-2016, 09:29 AM
Merlin's Avatar
Merlin Merlin is offline
Currently: Where's the snow?
Merlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond repute
  #24
Old 03-17-2016, 11:05 PM
MountainFanatic's Avatar
MountainFanatic MountainFanatic is offline
Currently: Not set.
MountainFanatic has a reputation beyond reputeMountainFanatic has a reputation beyond reputeMountainFanatic has a reputation beyond reputeMountainFanatic has a reputation beyond reputeMountainFanatic has a reputation beyond reputeMountainFanatic has a reputation beyond reputeMountainFanatic has a reputation beyond reputeMountainFanatic has a reputation beyond reputeMountainFanatic has a reputation beyond reputeMountainFanatic has a reputation beyond reputeMountainFanatic has a reputation beyond repute
  #25
Old 07-06-2016, 11:30 AM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Tube Frame for Sale Thread Starter — nos800 Forum — Ski-Doo (Swapmeet) Replies — 10 Last Post — 12-29-2014 08:53 PM
Thread — Rev custom tube frame Thread Starter — kyle28 Forum — Ski-Doo (Swapmeet) Replies — 0 Last Post — 03-17-2014 08:59 PM
Thread — Diamond S Titanium tube frame Thread Starter — Super 69 Bee Forum — Chassis/Tunnel (Swapmeet) Replies — 3 Last Post — 03-05-2014 05:32 PM
Thread — Tube frame pics.. Thread Starter — Modedmach1 Forum — Member Sled Builds Replies — 3 Last Post — 11-07-2010 07:57 AM
Thread — Holtz tube frame sled!! Thread Starter — nos800 Forum — Ski-Doo (Swapmeet) Replies — 14 Last Post — 04-28-2009 07:47 PM
no new posts
