Upgrade to Premium
Reply
  #1
Old 02-15-2016, 12:12 PM
snowrace snowrace is offline
Currently: Not set.
Basic Member
snowrace is an unknown quantity at this point
Default iqr problems fuel?
Started my iqr first time this winter, started first pull idled as it should then went down the bush line 3 minutes into my little rip it died out as if the fuel was shut off, the only way I could get it restated was to put choke on full,then it fired first pull after I took choke off it ran as it should for another 3 minutes and this happened again over and over. Any help would be great
Rate this post: Yes | No
  #2
Old 02-15-2016, 01:20 PM
LoudHandle LoudHandle is offline
Currently: I'd rather snowshoe than be caught on a SKIDOO! I'm not feminine / gay enough to ride SkiDoo either.
LoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond repute
Default
Rebuild / replace fuel pump / check impulse line. When you choke it your refilling the float bowls. They are not refilling on there own, as they should.
__________________
ALASKA
The Following User Says Thank You to LoudHandle For This Useful Post:
snowrace (02-15-2016)
  #3
Old 02-16-2016, 12:46 AM
The Bob's Avatar
The Bob The Bob is offline
Currently: Russians did it!
The Bob has a reputation beyond reputeThe Bob has a reputation beyond reputeThe Bob has a reputation beyond reputeThe Bob has a reputation beyond reputeThe Bob has a reputation beyond reputeThe Bob has a reputation beyond reputeThe Bob has a reputation beyond reputeThe Bob has a reputation beyond reputeThe Bob has a reputation beyond reputeThe Bob has a reputation beyond reputeThe Bob has a reputation beyond repute
Default
Another thing to check would be that your gas cap is venting, go ride it again and remove the cap when it dies and try starting it instead of choking it. You may hear a hiss if its the cap. Most all IQR tanks I have dealt with don't have a separate vent. Had it happen with my 8.8 I had on an older IQR of mine.
__________________
2015 Polaris Pro-RMK Carl's 900 (or RMK standard with much more than the Pro)
2013 Polaris IQR 870 Monoblock conv.
To many dirtbikes to list, a HD Night Train cutup somewhere in the garage.
  #4
Old 05-21-2016, 08:28 AM
RMK-King's Avatar
RMK-King RMK-King is offline
Currently: Polaris Moderator
RMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond repute
Default
Clean carbs and check for fuel flow would be a good starting point.
__________________
"Days get shorter,Snow gets deeper,Life gets better"
'19 Pro RMK 850
'17 SB Assault 800
9 other various older sleds
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Fuel Problems with XM's Thread Starter — Teddysledder Forum — Ski-Doo: XM Sleds Replies — 23 Last Post — 01-18-2016 09:04 AM
Thread — iqr trencing problems Thread Starter — outlaw454 Forum — Polaris: IQR Replies — 16 Last Post — 02-28-2010 08:58 PM
Thread — 08-d8 fuel problems? Thread Starter — POZZY Forum — Polaris Replies — 8 Last Post — 02-02-2009 09:27 PM
Thread — Fuel problems. HELP!!!!! Thread Starter — andy k Forum — Ski-Doo Replies — 0 Last Post — 01-30-2009 05:12 PM
Thread — 800 iqr jetting problems Thread Starter — Hesdale Forum — Polaris Replies — 6 Last Post — 12-27-2008 03:52 PM
no new posts
