Upgrade to Premium
Polaris: GEN 2 1999-2001, all models in the Gen 2 chassis
Reply
  #1
Old 02-11-2016, 12:08 PM
kidwoo's Avatar
kidwoo kidwoo is offline
Currently: schmurrently
kidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond repute
Default 1999 600 gearing for 144 track
I tried searching but got nothing, too many numbers I guess.
I've got a sled that had the 136" track switched for a 144 w/ 2" lugs. Riding is at 6-9k mostly. What's the setup? Does it even matter? Also what's peak rpm on these motors so I can check the current setup?
Thanks!
__________________
www.sierrasnowmobilefoundation.com
Your loud can sounds stupid
Rate this post: Yes | No
  #2
Old 02-19-2016, 01:56 PM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
never had one but I believe its the same chaincase as the first gen 6 and 700s. same target rpm too, 8100.
theres a gear chart in here that should work on yours, make sure you scroll down to the right chaincase - 7.05 center distance (97-98 domestic twins), its a few pages down, right after the older chaincase chart
http://www.vintagesnow.com/Polaris_f..._Brakes_SM.pdf
not sure whats in yours now but id probably shoot for around 2.2 gear ratio, or 18/40 with a 68 pin chain on the chart.
we tried that on a 700 down here at 3000' and found it a hair too low with a SLP pipe. SLP single pipe on those motors pulls stock gearing fine in the mountains.
The Following User Says Thank You to sno*jet For This Useful Post:
kidwoo (02-22-2016)
  #3
Old 02-19-2016, 02:04 PM
Currently: Not set.
Default
i also have some super low gears in a parts sled here that would work for ya 18/41. pm me if your interested.
about the same ratio as the infamous 19/43 ratio everybody with sh!t clutch setups and dayco belts swore by in the day..
kidwoo (02-22-2016)
  #4
Old 02-22-2016, 06:07 PM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
I don't know if I would change anything until you try the stock which is 19:40 gearing. If you find that is too high then go to 18:40.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
  #5
Old 02-22-2016, 09:00 PM
kidwoo's Avatar
Default
Thanks man! Let me get out and ride the thing a bit in some deep snow and see what's up. It's not my sled, a buddy just bought it as his first. He just listened to some nutjob for hours talk about how a 144 is too big for that motor and is all paranoid about it now. Knowing the target rpms helps a lot. We'll be out on it in the next three days. If it seems too loaded, I'll definitely take you up on that.
__________________
  #6
Old 02-22-2016, 11:43 PM
sledhed's Avatar
sledhed sledhed is offline
Currently: I need room in my shop!!
sledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond repute
Default
Quote:
Not too much track for that sled. 151 and 156 were common track lengths people stretched the 700 to in the day. I ran a 144 on my 99 600 RMK which I later put a 700 top end onto and it worked fantastic, would climb most anything I pointed it at... 2008 600's have 155 x 2.4 tracks and work fine...
__________________
Snowest forums member since December 19, 2001...
15 Pro 800 Orange Madness, Kurts gear-down and clutching, Camo Extreme 2.5x155, orange ultimate bumpers, WE clickers with Raptor triple rates, FTX kit, e-start, Ultra-Q can, Holz venting
Member:Missoula SnowgoersMontana Snowmobile Association
  #7
Old 02-22-2016, 11:57 PM
kidwoo's Avatar
Default
Yeah I've got two 2011 rmk 600s with 155s I use in my job that work like a champ. As soon as he told me that, I said never ever listen to a word out of that guy's mouth again.
The last thing I want to do is be teaching a buddy how to ride in real snow on a 136. My back just couldn't take it.
__________________
  #8
Old 02-22-2017, 08:56 PM
FEZ FEZ is offline
Currently: Mechanic for and Advisor to SHR
Basic Member
FEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond repute
Default
I ran 18/41 in my 00' 700 144 for years without issue and it worked Very well.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 1996 Polaris xcr 600 121-144 Gearing Thread Starter — Sledheadryan Forum — Polaris: GEN 1 and older Replies — 13 Last Post — 10-27-2015 07:32 AM
Thread — 1999 Polaris 600 RMK 144" track - $2000 OBO (WA) Thread Starter — heep70 Forum — Polaris (Swapmeet) Replies — 4 Last Post — 08-15-2013 06:33 AM
Thread — 2010 600 iq from 121-144/gearing Thread Starter — wonderxc600 Forum — Polaris: IQR Replies — 0 Last Post — 12-01-2011 05:44 PM
Thread — Whats a good gearing/ clutch set up IQR 600 144" Thread Starter — thehdshocker Forum — Polaris: IQR Replies — 0 Last Post — 10-31-2011 01:52 PM
Thread — 1999 Polaris 700 RMK 144"track $1899 Thread Starter — PMSPOLARIS Forum — Polaris (Swapmeet) Replies — 1 Last Post — 01-29-2010 09:08 PM
no new posts
