Upgrade to Premium
Reply
  #1
Old 02-08-2016, 02:10 PM
christopher's Avatar
christopher christopher is offline
Currently: Husky Powered, Woof Woof
christopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond repute
Garage
Exclamation TURN OFF YOUR CELL PHONE when using your beacon!!!
http://backcountryaccess.com/electro...r-your-beacon/
February 1, 2016
Electronic Noise and What it Means for Your Beacon
Oscilloscope visualization of “random noise” being picked up by a transceiver. The flat-topped signal is from a transmitting beacon, the pointed spikes are from a source of active interference.
If you don’t recognize the phrase “electronic noise,” it’s time to get acquainted. This two-word phrase has a big impact on the performance and accuracy of your avalanche transceiver, the one piece of equipment that absolutely cannot go bad when you or your backcountry partner gets buried.
The rule of thumb that BCA promotes is to keep any possible sources of interference, passive or active, 20cm (about 8in) away from your beacon when it’s in transmit mode and 50cm (about arm’s length) when in search mode. This is particularly important when searching, as interference could impact your beacon’s ability to determine the correct distance and direction of your target. When searching, holding your beacon at arm’s length is a good technique to practice and follow so you can keep your eyes on the bigger picture and make larger brackets during your fine search.
BCA Athlete Tatum Monod illustrates beacon searching. Always keep your transceiver at arm’s length when performing a search, not only is this good technique, but it will ensure no interference from electronics on your body.
HOW IT WORKS
When in transmit mode, every beacon sends out an electromagnetic pulse (emitting at 457kHz). A beacon in search mode receives this pulse and interprets it using built-in antennae. Your digital transceiver takes the information and analyzes the pulse to help you determine distance and direction to the target.
In addition to the target beacon’s transmission, the searching beacon will also pick any radio frequency noise that happens at same frequency, as well as harmonics of this frequency. These garbage pulses are what we call “electronic noise” and could be picked up, even though this additional noise is just “junk” and not, in fact, the beacon you’re looking for. Anything in the 457kHz frequency is interpreted as a possible target beacon, and when the noise gets “loud” enough, interference causes false signals in the form of false or erratic readings on your beacon’s display. If there’s enough background noise, then the “noise floor” can be high enough so your transceiver has a hard time picking the signal out of the noise. This causes a decrease in reduced range or erratic readings on your beacons display.
This shot from our oscilloscope shows a high noise floor, making it difficult for the transceiver to make out the transmit pulse in the center of the screen.
A good analogy is to think of trying to strike up a conversation in a bar. Early in the night before the crowd trickles in, there will be background noise, but you’ll still be able to hear the person sitting across the table from you. Later on with the DJ playing and conversation volume rising a few decibels, you definitely won’t be able to hear the person across the table, and you might not be able to hear the person standing right next to you.
While you probably know the most common sources of interference and electronic noise, some of the less common culprits may surprise you. To learn more, it’s best to start with the two basic. categories of interference: active and passive.
ACTIVE INTERFERENCE
Active interference is caused by electronics that actively transmit frequencies. Pretty much everything with a battery is a potential source of noise. The most common and well-known culprit is probably in your pocket right now: your cell phone.
Your cell, particularly if it’s a smartphone, gives off a significant amount of competing noise when it’s on and the screen is illuminated. If you think that setting your phone to airplane mode is enough to cut noise, think again. Airplane mode does not significantly alter the amount of electronic noise the phone gives off. Hold a phone set to airplane mode too close to a searching beacon, and your numbers will be affected as much as if the phone were fully “on.”
Active interference is caused by electronics that emit radio frequency noise intentionally or unintentionally. Sources include GPS devices, iPods, radios, point-and-shoot cameras, video cameras (like GoPros), snowmobiles, snowbikes, the keyless entry fob on your keychain, and, believe it or not, headlamps. A good rule of thumb to follow is to assume that anything you are carrying that is powered by electricity i is potential source of radio frequency noise.
Headlamps are a particularly interesting example because they beautifully visualize the movement (and potential dangers) of competing frequencies. Set to high, the LEDs in a headlamp emit a strong, constant stream of light. Set to low or medium, however, the headlamp doesn’t turn off LEDs to create a dimmer glow. Instead, the LEDs pulse. The pulse is so fast that the human eye doesn’t register a “flickering” phenomenon. Instead, your eye interprets the pulse as less light and a dimmer beam. The photo above was taken at night with a long exposure, showing the individual pulses from the LED.
Have to perform a search at night? Set your headlamp to high. The full-force, steady beam causes less interference than other settings. Otherwise, turn it off.
Snowmobile spark plugs cause a lot of interference issues, so be sure to park your sled a safe distance away from your search area.
PASSIVE INTERFERENCE
Passive interference comes from sources that partially block or warp transmissions. Passive sources are usually only a problem if they are very close to your beacon, and impact transmissions by affecting antenna performance, usually by slightly weakening the signal or slightly altering the shape of the electromagnetic field, which could cause minor “spikes” or “hiccups” in distance or direction readings. While under normal circumstances passive interference should not be enough to significantly interfere with or ruin a search, BCA does recommend that users stow sources of passive interference (usually metal) 20cm away from the beacon when in transmit mode. This recommendation is made to prevent a situation where a transmitting beacon gets shoved into or against metal during an avalanche.
Metal is the primary problem source in this category, but magnets can also cause problems and should be treated with care. Sources of metal are varied, from the obvious (like your avalanche shovel blade), to the small (your pocket knife), to the surprising (did you know Gu packets are lined with metal?). Aluminum foil, like the thin layer that insulates a Gu packet or the wrapping of your homemade PB&J should be kept well away from beacons, whether that means in a separate pocket or in your pack. Also, be aware of some jackets that use magnets instead of zippers, as these have been known to change modes on some transceivers.
ENVIRONMENTAL INTERFERENCE
Complicating matters is the fact that you will not be able to control and eliminate all potential sources of interference. A number of natural and man-made circumstances and features can increase the level of electronic noise and negatively impact your transceiver’s ability to accurately pinpoint its target.
These uncontrollable sources include thunderstorms, which increase the level of electricity in the air even before any lightning strikes. Overhead power lines, cell and radio towers, and underground power lines for chairlifts can also cause real problems when searching.
All sources of interference, from cameras to power lines, have ambient electronic signals that may reduce search range and slow your beacon processor’s ability to update reliably as you’re moving through your search pattern. This produces readings that are not as accurate as they might otherwise be and can confuse the search party. In those cases when you cannot remove all major sources of electronic noise, the International Commission of Alpine Rescue (ICAR) recommends altering your signal search pattern (the first phase of the search when you don’t yet have a signal) to 30 meters rather than 40 meters, for greater accuracy.
BEST PRACTICES
There is a lot of variation in how much interference a given object gives off. Two identical iPhones, for example, can give off different levels of electronic noise. A certain level of variation comes from minute inconsistencies in the manufacturing process. Even more variation develops as you use and abuse your electronics. Wear, tear, cracks, and water damage all have the potential to increase interference. Which means, unfortunately, that guidelines are never one-size-fits-all.
The best way to mitigate the risk of interference is to follow the rule of “better safe than sorry.” A few key tactics:
  1. Turn unneeded electronics completely off at the start of your tour and stow them in your pack.
  2. Any electronics that you don’t want to turn off should be stowed in a pocket or pack at least 20cm away from your beacon.
  3. Want to stop and take a photo? Take out your phone, snap the picture, then return it to its carrying place at least 20cm away from your beacon.
  4. Keep all sources of metal, from shovel blades to food wrappers, at least 20cm away from your beacon.
  5. When it’s time to search, hold your beacon at arm’s length (50cm) to limit interference and keep your eyes on the big picture.
  6. Park your snowmobiles or snowbikes (and anything else with a spark plug) well away from the search zone.
  7. If you suspect unavoidable interference is negatively impacting your beacon readings, reduce your search strip widths to 30 meters when performing a signal search.
__________________
4 out of 4 members found this post helpful. Rate this post: Yes | No
The Following 6 Users Say Thank You to christopher For This Useful Post:
Bcorn (02-09-2016), orange 1 (02-08-2016), PaulAnd (11-04-2016), recreationist (02-09-2016), Snow Duck (02-08-2016), Xgraphite (02-09-2016)
  #2
Old 02-09-2016, 02:07 AM
bailer bailer is offline
Currently: Busy procrastinating
bailer has a reputation beyond reputebailer has a reputation beyond reputebailer has a reputation beyond reputebailer has a reputation beyond reputebailer has a reputation beyond reputebailer has a reputation beyond reputebailer has a reputation beyond reputebailer has a reputation beyond reputebailer has a reputation beyond reputebailer has a reputation beyond reputebailer has a reputation beyond repute
Default
The thread title is somewhat misleading and contrary to the article info as I read it.
BCA say to keep sources of active interference at least 20cm away from the beacon.
I use my cell as my gps and store it more than 20cm away from the beacon as BCA recommends.
They also say a dedicated gps such as a Garmin etc is an active source of interference which must be kept >20cm away.
The confusion leads some to believe a dedicated gps is safer than a cell phone as a gps. This article helped to dispel that myth.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to bailer For This Useful Post:
christopher (11-04-2016)
  #3
Old 11-04-2016, 07:01 AM
PaulAnd's Avatar
PaulAnd PaulAnd is online now
Currently: gen4 now please
PaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond repute
Default
What about the gps?
Spot and Inreach..
I guess good practice would have these off as well?
  #4
Old 11-04-2016, 12:31 PM
Garage
Default
Quote:
Originally Posted by PaulAnd View Post
What about the gps?
Spot and Inreach..
I mount mine on my SLED, NOT on my body..
In the event of an avalanche, I will almost certainly separate from my sled ensuring my SPOT will not be a source of interference.
__________________
  #5
Old 11-15-2016, 12:51 PM
frntflp's Avatar
frntflp frntflp is offline
Currently: Waiting for snow
frntflp has a reputation beyond reputefrntflp has a reputation beyond reputefrntflp has a reputation beyond reputefrntflp has a reputation beyond reputefrntflp has a reputation beyond reputefrntflp has a reputation beyond reputefrntflp has a reputation beyond reputefrntflp has a reputation beyond reputefrntflp has a reputation beyond reputefrntflp has a reputation beyond reputefrntflp has a reputation beyond repute
Default
Phone off ...... it will be now - check
GPS (Rino) mounted in cradle on the dash - check
Beacon strapped to my chest - check
Like Christopher states above, if I'm caught in a slide, I'm positive that I will be more than 20 cm from the GPS/sled, so not too worried about interference that way.
But again, phone status will be OFF. Time is of the essence during a search, and I don't want it to take any longer than necessary to find/be found !
__________________
FRNTFLP
'18 Axys Pro RMK 800 155 SC
'15 Switchback Assault 800 - 60 th Anniv. Ed
The Following User Says Thank You to frntflp For This Useful Post:
christopher (11-15-2016)
  #6
Old 11-15-2016, 01:48 PM
smokindave's Avatar
smokindave smokindave is offline
Currently: I need a new sled....like bad!
Canada Moderator
smokindave has a reputation beyond reputesmokindave has a reputation beyond reputesmokindave has a reputation beyond reputesmokindave has a reputation beyond reputesmokindave has a reputation beyond reputesmokindave has a reputation beyond reputesmokindave has a reputation beyond reputesmokindave has a reputation beyond reputesmokindave has a reputation beyond reputesmokindave has a reputation beyond reputesmokindave has a reputation beyond repute
Default
Best advice there is is to just conserve your battery on your phone and turn it off.
It would suck being buried and hearing them search over you and not stopping to dig...then expire!
Yes this has happened were they couldn't find the body to retrieve till the victims phones battery expired.
  #7
Old 11-15-2016, 05:15 PM
Garage
Default
Damn.
That would be GRIM..
__________________
  #8
Old 11-15-2016, 05:30 PM
rhalloran rhalloran is offline
Currently: Not set.
Basic Member
rhalloran has a reputation beyond reputerhalloran has a reputation beyond reputerhalloran has a reputation beyond reputerhalloran has a reputation beyond reputerhalloran has a reputation beyond reputerhalloran has a reputation beyond reputerhalloran has a reputation beyond reputerhalloran has a reputation beyond reputerhalloran has a reputation beyond reputerhalloran has a reputation beyond reputerhalloran has a reputation beyond repute
Default
Could you elaborate on that? Source? Beacons involved?
I've done a lot of beacon searches over the years, many with my cell phone in my pocket, never had an issue. I've also played "hide and seek" with my kid - I turn on a beacon, go "hide," she searches for me - cell phone on, in pocket, <20cm from beacon.....she always finds me.
It is not news that cell phone/electronics can interfere with beacon functionality, but that example seems unlikely to me - I've not experienced EVERY scenario, but I've done LOTS of beacon searches over the years, not once have I noticed significant interference from other electronic devices. It is entirely possible that I would have picked up signal sooner had there been no electronic devices, but I don't know that. Not sure I'm buying that one, frankly.
Could you share where you heard that?
Thanks!
The Following User Says Thank You to rhalloran For This Useful Post:
dooman92 (11-15-2016)
  #9
Old 11-16-2016, 09:54 AM
Snow Junkie Snow Junkie is offline
Currently: Looks like I'm in for another year of praying the Dragon stays together.
Snow Junkie has a reputation beyond reputeSnow Junkie has a reputation beyond reputeSnow Junkie has a reputation beyond reputeSnow Junkie has a reputation beyond reputeSnow Junkie has a reputation beyond reputeSnow Junkie has a reputation beyond reputeSnow Junkie has a reputation beyond reputeSnow Junkie has a reputation beyond reputeSnow Junkie has a reputation beyond reputeSnow Junkie has a reputation beyond reputeSnow Junkie has a reputation beyond repute
Default
At the Mike Duffy avy class I just went to, I believe he said that the cell phone doesn't effect the ability of the beacon to transmission but the ability of the beacon to pick up the signal of a transmitting beacon by about 50%. This would be easily verified with a quick test.
So with that information the only benefit of turning your phone off at the beginning of the ride would be that you dont have to remember to turn it off if someone is buried. This may be reason enough.
Here is an article that provide the same information.
http://unofficialnetworks.com/2013/1...lanche-beacons
The Following 2 Users Say Thank You to Snow Junkie For This Useful Post:
christopher (11-16-2016), frntflp (11-22-2016)
  #10
Old 11-16-2016, 12:39 PM
Garage
Default
Do Cell Phones Interfere With Avalanche Beacons?
VIDEO SHOWING CELL PHONE INTERFERANCE!
https://www.facebook.com/ebertssnow/...6165648239683/
Gallatin National Forest Avalanche Center (GNFAC) brings us this reminder to turn off your phones in the backcountry.
Do phones interfere with avalanche beacons?
YES. Portable electronics like phones, radios, GPS, cameras, etc. will interfere with an avalanche beacon (aka avalanche transceiver). Is it a problem? The interference is significant and may prevent you from finding a buried partner. These electronic devices typically need to be turned on to cause interference. Snowmobiles with running motors and electrical circuits will also cause interference.
Most solid, non-electrical, objects will not cause interference. These objects include snow, trees, rocks, clothing, skis, etc. Another common object is a RECCO reflector which is often built into jackets, and this object will not cause interference.
Studies have shown there is little interference with a transmitting beacon. If you’re buried and you forgot to turn off your iPhone, don’t worry. Just to be safe keep your iPhone or other device about 8 inches away from your beacon. Interference mostly occurs when beacons are in search mode.
“The x-axis represents the various beacons at distances of 0, 10, 20, 30, and 40 cm from the electrical device. The y-axis is the “Theta” value, which is the difference between that beacon’s normal effective receive range and the effective range it got with the electrical device 0, 10, 20, 30, and 40 cm away. If the colored lines are low on the y-axis, that means that transceiver is less susceptible to noise than the beacons on either side of it on the x-axis. So the Tracker DTS is the least susceptible to noise and the Pieps DSP is the most susceptible.
You’ll also notice that the iPod (orange line) and the GPS (red line) are the biggest culprits in creating interference, which is consistent with our experience.” – backcountryaccess.com
Recommendations:
  1. Turn off all electronics and put them in your backpack.
  2. If you need to keep a phone or radio on your body, keep it 8 inches from your beacon. Keep the phone in “airplane mode” if possible
  3. If conducting a search and you suspect interference, simply extend your arm to get your beacon about 1.5 feet away from any electronic devices.
By, Todd Eberts Back Country Free Ride Avalanche Instructor
__________________
The Following User Says Thank You to christopher For This Useful Post:
  #11
Old 11-17-2016, 10:56 AM
Pro-8250's Avatar
Pro-8250 Pro-8250 is offline
Currently: Have fun while you can
Pro-8250 has a reputation beyond reputePro-8250 has a reputation beyond reputePro-8250 has a reputation beyond reputePro-8250 has a reputation beyond reputePro-8250 has a reputation beyond reputePro-8250 has a reputation beyond reputePro-8250 has a reputation beyond reputePro-8250 has a reputation beyond reputePro-8250 has a reputation beyond reputePro-8250 has a reputation beyond reputePro-8250 has a reputation beyond repute
Click Here to Register
The Following User Says Thank You to Pro-8250 For This Useful Post:
christopher (11-17-2016)
  #12
Old 11-18-2016, 12:10 PM
Pro-8250's Avatar
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Cell phone ? Thread Starter — lost Forum — General Snowmobiling Replies — 4 Last Post — 08-12-2014 08:47 PM
Thread — smart phone app to turn phone into real gps? Thread Starter — Sledbrain2 Forum — General Snowmobiling Replies — 25 Last Post — 02-03-2014 12:04 PM
Thread — Buying a used cell phone Thread Starter — Pekabu Forum — Fouled Plug Replies — 8 Last Post — 01-02-2009 08:42 PM
Thread — Reverse Cell Phone look up Thread Starter — phatty Forum — Fouled Plug Replies — 23 Last Post — 05-24-2008 08:35 PM
Thread — Lost Cell Phone Thread Starter — E-Storm Forum — General Snowmobiling Replies — 0 Last Post — 01-09-2008 05:01 PM
no new posts
