Upgrade to Premium
Arctic Cat: Powder Special and older 2000 and older, all models in the Powder Special chassis and older chassis models
Reply
  #1
Old 01-29-2016, 06:57 AM
tatlock tatlock is offline
Currently: Not set.
Basic Member
tatlock is an unknown quantity at this point
Default 700 powder special Severe Flooding
hell ladies n gentelmen Mark here Got a Question for any or all who may be able to help . ok here goes bought this old sled drained all the old fuel outta it put in new high test she fired up ran not to bad . Did pop n backfire a few times but when driving it hard had no problems. But heres the kicker after sitting a few days the cylinders filled with fuel . so pulled the carbs off (flat sided ones ) tore them apart one float the screws were loose so checked the needle and seats they both work good open and closed .So is it possible that the fuel pump is sucking gas into the crankcase this is the one thing that i have not checked yet . Any or all advice will be greatly appreciated Thanks A Whole Bunch Mark AKA Tatlock
Rate this post: Yes | No
  #2
Old 01-29-2016, 07:51 AM
olymon's Avatar
olymon olymon is offline
Currently: project parts searching
olymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond repute
Default
Bad fuel pump would only let fuel into the side of the crank case that has the impulse line in it. Plugged vent line in a warm garage may make enough pressure to flow past the needle and seat. Sure sounds like the needle and seats though even though you say you checked them.
Sent from my PC36100 using Tapatalk 2
  #3
Old 01-29-2016, 02:47 PM
Idcatman1's Avatar
Idcatman1 Idcatman1 is offline
Currently: Not set.
Idcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond repute
Default
The fuel pump would be my best guess too, but even though the floats are moving freely and the needles appear to be closing there may still be a bit of something preventing one or both from sealing completely. Also the center seal in the crankcase is not a complete seal like the outside crank seals. It is more like piston rings with a little end gap. It will allow gas to leak from one side to the other over time.
  #4
Old 02-15-2016, 11:25 PM
phess2 phess2 is offline
Currently: Not set.
Basic Member
phess2 is an unknown quantity at this point
Default
Well if it is not an Efi, I have a spare fuel pump from a 2000 700 powder special for sale.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — WTB: 94/95 ZR 700 or 99-2000 Powder Special 700 cylinder Thread Starter — vinpie1 Forum — WTB (Swapmeet) Replies — 0 Last Post — 11-22-2011 08:36 AM
Thread — 99 Powder Special 700 LE Thread Starter — grabbit Forum — Arctic Cat (Swapmeet) Replies — 26 Last Post — 09-17-2008 06:48 PM
Thread — 00, Powder Special 700 Thread Starter — jeremyb Forum — Arctic Cat (Swapmeet) Replies — 0 Last Post — 04-07-2008 03:36 PM
Thread — 99 powder special 700 Thread Starter — roughcountry Forum — Arctic Cat (Swapmeet) Replies — 0 Last Post — 02-20-2008 09:13 PM
Thread — Advice on 99' 700 powder special Thread Starter — 2litre Forum — Mountain/Deep Powder Replies — 15 Last Post — 02-01-2008 04:27 AM
no new posts
