Upgrade to Premium
Arctic Cat: Powder Special and older 2000 and older, all models in the Powder Special chassis and older chassis models
Reply
  #1
Old 01-17-2016, 10:50 PM
shoulder2shoulder shoulder2shoulder is offline
Currently: Not set.
Basic Member
shoulder2shoulder has a reputation beyond reputeshoulder2shoulder has a reputation beyond reputeshoulder2shoulder has a reputation beyond reputeshoulder2shoulder has a reputation beyond reputeshoulder2shoulder has a reputation beyond reputeshoulder2shoulder has a reputation beyond reputeshoulder2shoulder has a reputation beyond reputeshoulder2shoulder has a reputation beyond reputeshoulder2shoulder has a reputation beyond reputeshoulder2shoulder has a reputation beyond reputeshoulder2shoulder has a reputation beyond repute
Default Thundercat to 1M drop and roll measurements
Hi all,well i got myself quite a project going on at the wrong time of the year. I purchased a bunch of 2003 mountain cat pieces to drop and roll my 2001 thundercat chaincase.I'm told the chassis bulkhead is close enough to being the same that it is do able. Can anyone give me some measurements to align proper?, I don't wanna swiss cheese the sled if I can help it.
Rate this post: Yes | No
  #2
Old 01-18-2016, 09:04 AM
Currently: Not set.
Basic Member
Default
I should add this is for a New England hillcross build,we don't have any real mountains out here,I only get to watch you guys's youtube vid's.
Not to sure yet if I'm going 136,or 141,probly 1.5 with 2.0 studs,reason for the drop,and I'm going 10t for less roll resistance. Someone needs to put Doo Boy Daly in his place,lol.
  #3
Old 01-18-2016, 09:30 AM
Idcatman1's Avatar
Idcatman1 Idcatman1 is offline
Currently: Not set.
Idcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond repute
Default
Do you have a good 1m tunnel and bulkhead? If so I would use them and then all you would need is the driven clutch side motor mount and jackshaft bearing mount from a 1m 600 and your T Cat engine will bolt right in. I have put an older tunnel on a 1m bulkhead and it works well enough but you have to drill almost all the rivet holes to do it and also the holes for the driveshaft bearings on both sides.
  #4
Old 01-18-2016, 09:03 PM
Currently: Not set.
Basic Member
Default
Not many 1m's in these parts,I can't even google up any bulk head pic's.I've got the 1m 600 jackshaft support and tunnel plate already,And Am cutting and fitting that this week.Looks like I will have to shorten up the tunnel coolers also,may have to notch rh footwell too.I'm old and slow and measure a lot but try not to hack up things.Using factory parts it should look like it came that way from cat when done.
  #5
Old 09-14-2016, 07:50 PM
Currently: Not set.
Basic Member
Default
finished this project last march,a bit off trial and error but it's finished with a clean look,I laid it out on the stock tunnel,then added aluminum plate to the insides and just drilled through to the new holes,worked slick,bought a air riveter to help with all the riveting.1m chain case rock plate fits well to the t/cat bellypan,they are hard to find cat discontinued them.
3 out of 3 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to shoulder2shoulder For This Useful Post:
Reeb (09-21-2016)
  #6
Old 09-23-2016, 10:41 AM
Idcatman3's Avatar
Idcatman3 Idcatman3 is offline
Currently: Not set.
MODERATOR: Premium Member
Idcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond repute
Garage
Default
Sounds good! Get us some pictures when you get a chance.
__________________
Arctic Cat 1M and PS Moderator
'04 1M 1500 162" Challenger Extreme, M8 rear suspension, Custom jetting, clutching and gearing
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Drop n roll Thread Starter — sportsterdanne Forum — Polaris: Pro-Ride Replies — 10 Last Post — 03-10-2015 12:02 PM
Thread — WTB drop pan for an extended chaincase or drop and roll kit Thread Starter — DragonSlayer1 Forum — WTB (Swapmeet) Replies — 0 Last Post — 03-31-2014 08:39 PM
Thread — drop and roll Thread Starter — joshkoltes Forum — Performance/Modified Replies — 14 Last Post — 11-28-2009 11:57 PM
Thread — drop and roll Thread Starter — yanush Forum — Polaris: 900 Replies — 1 Last Post — 11-26-2009 01:17 PM
Thread — Drop and Roll Thread Starter — extremedesigndave Forum — Polaris: EDGE Replies — 4 Last Post — 10-01-2009 06:56 AM
no new posts
