Upgrade to Premium
Polaris: GEN 2 1999-2001, all models in the Gen 2 chassis
Reply
  #1
Old 01-16-2016, 06:19 AM
TKrug21 TKrug21 is offline
Currently: Not set.
Basic Member
TKrug21 is an unknown quantity at this point
Default Strange thing I haven't seen before.
2000 550 touring fan, been sitting a few years.
Cleaned carbs, got it running, no idle. Cleaned the idle circuits and it seemed to run fine. Held up the back and spun the track, looking good. Then suddenly it died and will not start again, even with spray.
Put the test light on the spark plugs and it's flashing. Let it sit for a day and pulled it over with the plugs out, just in case it was flooded, nothing. No cough, no sputter, nothing.
Put some old plugs back in, test light not flashing. Put the new plugs back in and here is the weird part. The test light flashes until I put some spray in the carbs, then it quits. So the plugs will only fire when there is little/no fuel in the cylinder. Never seen this before, has anyone else?
Rate this post: Yes | No
  #2
Old 01-18-2016, 09:40 AM
sled_guy's Avatar
sled_guy sled_guy is offline
Currently: In limbo
sled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond repute
Default
I've seen coil packs that were nearly dead that when compression came up in the cylinders they wouldn't fire. But I never used one of those testers, I just pull a plug and lay it on top of the motor to check for spark.
sled_guy
__________________
"Sorry, I thought you could ride"
  #3
Old 01-27-2016, 05:29 PM
Currently: Not set.
Basic Member
Default Thanks for the input.
Thanks for the input. After further testing I'm pretty sure it's electrical because spark is mostly gone now. It was just a strange co-incidence that it would go away whenever I put some spray in.
Just bought a M1100T and I have been so busy riding it that I haven't had time to work on this one.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Haven't seen this for awhile Thread Starter — XFIRE800 Forum — General Snowmobiling Replies — 1 Last Post — 10-21-2010 07:08 AM
Thread — I haven't seen this one before! Thread Starter — justadude Forum — General Snowmobiling Replies — 6 Last Post — 07-24-2009 06:28 AM
Thread — If you haven't done it already.... Thread Starter — Ex-Member Forum — Fouled Plug Replies — 1 Last Post — 11-04-2008 10:06 PM
no new posts
