I have a 1999 RMK 700. Bought it 4 years ago and it has never given me grief until this year. In short, it seems like it isn't getting enough fuel. When I pulled it out of summer storage it would only run if i pumped the primer. Then I cleaned the carbs up, didn't see much for junk in them, and it seemed to idle fine, but would sputter and backfire if you gave it more than half throttle. It ran like this for a bit, then eventually quit altogether again. I went out to work on it today, and after letting is idle for 2 minutes, I took it out and it ran perfect....yet I don't expect that to last. Here is what I have done thus far...
-Cleaned up carbs
-Checked fuel pump, fuel shoots out of fuel lines when turned over so it must be good.
-Fuel filter looks good.
-Fuel lines look fine on outside
-Stored with avgas over the summer and added some 91 octane a month ago.
-Pumped some gas out of tank, looks fine.
I was thinking next I would replace all the fuel lines (they are the rubber ones and I'm thinking they might be restricting the fuel if swollen inside)
Also another thing a friend recommended was checking vacuum line to fuel pump.
Any ideas? Thanks!
-Cleaned up carbs
Any ideas? Thanks!
