#1
Right now I have a 136 x 2" track on the sled, I'm wondering how long I can go without having cooling issues. Thanks
#2
long as you want, depending on your budget
#3
A real common length back in the mid 2000's was to put a 151" under that sled ('97-02 700 RMK)...all it took was a 151" track, rail extensions, a tunnel extension, longer coolant hoses (only for '00-02 sleds), and a some rivets and/or small bolt/nut combos to attach the tunnel extension. You could even reuse your rear bumper. It was a 4 hour job (some guys could do it in a couple hours and some would take 8) and the cost was very reasonable. In my opinion, this is the best balance of track length with simplicity of installation. Plus the horsepower of the 700 motor makes the stock chaincase gearing just fine.
I did this to a '97 700 RMK (which I have since given to buddy) and a '98 700 RMK that I still have around with exactly that combination (except the hoods are the wedge style as opposed to the gen2 of your '99). I also have a '00 800 RMK (very similar to your '99) that I run stock Polaris 151" rails (from a '01-02 RMK) and set back the rear suspension roughly 4" to run a 159" track. The work I did to the '00 is quite a bit more involved than had I just put the 151" under it but I like it so much it is still my backup sled. A used 151"x2" track is reasonably priced as are the rail and track extensions. If you are a savvy buyer you should be able pick up the used package for under $500. Hammered |
#4
I did a 1999 Polaris RMK 700 suspension mod from 136 to a 159.
I used the track and skid from an rmk 900 and with 7 tooth drivers was able to use the original front mounting hole for the front of the skid. Then with a tunnel extension and some fabrication for a new rear mounting bracket I was set. I left the gearing in the chain case stock and it will almost out climb my 09 dragon 800 with a 163. It does still lack a little power for such a long track but as it sits it is very impressive. If anyone wants pics just let me know. |
#5
I would definitely like to see pictures from your build. Thanks
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Thread — 1999 Ski Doo Summit 700 136/RMK 700 144 | Thread Starter — dubeffect | Forum — Ski-Doo (Swapmeet) | Replies — 3 | Last Post — 11-18-2013 12:01 PM |
Thread — 1999 Polaris 700 RMK 144"track $1899 | Thread Starter — PMSPOLARIS | Forum — Polaris (Swapmeet) | Replies — 1 | Last Post — 01-29-2010 09:08 PM |
Thread — Pol 700 xcsp track extension | Thread Starter — Garand | Forum — Mountain/Deep Powder | Replies — 2 | Last Post — 01-29-2008 07:41 PM |
Thread — 1999 700 RMK in Alberta, newer motor/track, many extras | Thread Starter — U turn | Forum — Polaris (Swapmeet) | Replies — 0 | Last Post — 11-29-2007 06:14 PM |
