Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 01-06-2016, 09:51 AM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
Lightbulb SnoWest-Forums - AXYS-MOUNTAIN TECH LINKS
So that we don't have a bunch of "Stickies" for tech threads and information.
I'm pulling them all together here in one place which will eliminate a lot of searching and put the info within easy reach.
If you have a favorite tech Threads or parts-source threads.
These are for SNOWEST PRO-RIDE Forum threads ONLY> NO outside links and no comments.
If you have something that you want to be put up... Post it up here with:
1) Title of the Thread
2) Description of the contents of the thread
3) Link to that thread.
I will come back here from time to time and move your info into the second post here and will then delete your post... this will keep the thread clean.
Thanks for your help!!
__________________
Signature:
Rate this post: Yes | No
The Following 3 Users Say Thank You to mountainhorse For This Useful Post:
05900 (03-24-2017), AndrettiDog (01-19-2016), rab (03-03-2017)
  #2
Lightbulb
FINALLY: COMPLETE, REASONABLY PRICED, "KIT" FOR LORDS ADHESIVE AND AN ALTERNATIVE
Adhesive kits to use in repair/assembly/modification of your sled
//www.snowest.com/forum/showthread.php?t=328615
GREASING THE PRO RMK... DO IT OFTEN AND USE EXCELLENT QUALITY GREASE
Grease can make a big differnce in how well your suspension works.
//www.snowest.com/forum/showthread.php?t=312674
COOLANT TECH TIP FOR THOSE REBUILDING OR NEW TOP END OR RUNNING IN COLD / HOT AMBIENT
General discussion of coolant mixtures and coolant performance.
//www.snowest.com/forum/showthread.php?t=406854
The complete list of Axys error codes. (Thanks Snowjunkie/MountainFanatic)
//www.snowest.com/forum/showthread.php?t=404806
TPS check / adjust step by step.
Complete and technical discussion about adjusting the TPS (Throttle Position Sensor) on your AXYS sled (often not adjusted well from factory)
//www.snowest.com/forum/showthread.php?t=404826
Polaris P85 Drive Clutch
Blueprinting and overall maint. info
//www.snowest.com/forum/showthread.php?t=416808
WORTH CHECKING: Belt Deflection Adjuster on '2018 Secondary clutches
https://www.snowest.com/forum/showthread.php?t=438877
__________________
Signature:
The Following User Says Thank You to mountainhorse For This Useful Post:
Mark's RMK (01-16-2017)
  #3
Old 11-20-2016, 09:28 AM
Default
Always looking for more to add to this list.
If you have a good one, weather it is yours or another members, post it up here and I'll add it to the list above.
__________________
Signature:
sumtinwong (01-30-2017)
  #4
Old 01-15-2017, 10:10 AM
cmxuser's Avatar
cmxuser cmxuser is offline
Currently: Not set.
cmxuser has a reputation beyond reputecmxuser has a reputation beyond reputecmxuser has a reputation beyond reputecmxuser has a reputation beyond reputecmxuser has a reputation beyond reputecmxuser has a reputation beyond reputecmxuser has a reputation beyond reputecmxuser has a reputation beyond reputecmxuser has a reputation beyond reputecmxuser has a reputation beyond reputecmxuser has a reputation beyond repute
Default
Axys exhaust valve cleaning.
Not sure if you want this here. Not sure you even want to hear this but I'll offer up my experience. Your milage may vary.
Being careful not to move the adjustment of the cable when removing and replacing the cover for the exhaust valve assembly, I pulled the exhaust valves took them off the assembly one at a time. Cleaned them and replaced them making sure they moved freely in the exhaust valve slots.
Rode the sled pretty hard yesterday and it run great no codes no problems, sled run great. Thought I would throw this out there. Like I said though "your mileage may vary."
Mountainhorse please post this where you think it might need to be. Thanks.
  #5
Old 01-31-2017, 07:00 PM
richracer1's Avatar
richracer1 richracer1 is online now
Currently: Loving my BMP 860
richracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond repute
Default
Here's one that may be suitable for being in here.
//www.snowest.com/forum/showthread.php?t=430757
__________________
0 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to richracer1 For This Useful Post:
doo181 (04-14-2018)
  #6
Old 03-24-2017, 09:09 AM
richracer1's Avatar
Default
As we all know, there is no external fuel filter on the Axys RMKs, there is a filter in the tank that's part of the fuel pick-up unit.
The part number is: 2205618
At Babbits (online), it costs around $123 + shipping for the pick-up unit which includes the filter.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — SnoWest-Forums - PRO RMK TECH LINKS Thread Starter — mountainhorse Forum — Polaris: Pro-Ride Replies — 1 Last Post — 09-26-2014 05:49 PM
Thread — PRO-CHASSIS TECH/INFO LINKS Thread Starter — ullose272 Forum — Polaris: Pro-Ride Replies — 5 Last Post — 02-03-2014 08:15 PM
Thread — SNOWEST FORUMS: SnoWest Online Thread Starter — admin Forum — SnoWest Announcements Replies — 4 Last Post — 02-16-2010 04:10 PM
Thread — SNOWEST FORUMS: Coming Attractions on SnoWest. Thread Starter — christopher Forum — SnoWest Announcements Replies — 85 Last Post — 11-11-2009 12:30 PM
Thread — How old are the SnoWest forums? Thread Starter — CROW Forum — General Snowmobiling Replies — 9 Last Post — 12-02-2007 01:13 PM
no new posts
