Upgrade to Premium
Ski-Doo: ZX Sleds 99-2005, all models in the ZX chassis
Reply
  #1
Old 01-01-2016, 01:50 PM
ProSummitX ProSummitX is offline
Currently: Not set.
Basic Member
ProSummitX is an unknown quantity at this point
Default Summit X Mod Questions -
Hey guys,
I have a 98 Summit X that I have put a 151x16x2 track on, along with a 06 rev skid with all idler wheels moved to the inside. I know this in the zx section, but I am hoping some of the zx guys can chime in on my question. I also have removed the sway bar and raised the handlebars with a pivot riser. I am happy with the way that she turns over on her side, and she sidehills like a champ, but I can't seem to get the front the sled to come off the ground.
I want to get pressure off the front of the sled. I have the front springs in the middle due to no sway bar, the middle skid spring is pretty tight and the back blocks on the softest setting. The limiter straps are also all the way out. What else can I do to make the sled feel less front heavy and get it to feel like the weight is more on the back of the sled? Are things like a new lighter muffler and such worth it?
It won't allow me to upload a picture, if anyone knows how, I would be happy to post one for reference. Thanks!
Rate this post: Yes | No
  #2
Old 02-28-2017, 04:43 PM
zl936c zl936c is offline
Currently: Not set.
Basic Member
zl936c is an unknown quantity at this point
Default Ski lift
I don't know if you ever got this figured out or not but by going to an 06 skid you more than likely have to lower where the front arm mounts in the tunnel as it is not sharing its part of the weight transferring your ski lift to the rear arm instead of initiating your lift at the front arm the sleds entire weight now has to be overcome by the power you make at the rear arm and weight and leverage are winning the battle go to the same sled your skid is from and take measurements when it's sitting at rest my bet is that your inches up in the tunnel to far! Other option no saying how it will work tho is try going back to your stock front arm! Worth a shot just to see how it reacts! Good luck
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — 670 Summit X Mod Questions - Thread Starter — ProSummitX Forum — Ski-Doo: S-2000 and older Replies — 6 Last Post — 11-18-2017 11:46 PM
Thread — zx mod questions Thread Starter — summit02 Forum — Ski-Doo: ZX Sleds Replies — 4 Last Post — 07-22-2010 11:58 AM
Thread — '08 M8 Mod Questions Thread Starter — YooperScott Forum — Arctic Cat: M Series Replies — 7 Last Post — 09-26-2009 11:30 AM
Thread — D8 owners... Mod questions... Thread Starter — dub Forum — Polaris Replies — 8 Last Post — 04-09-2008 12:58 PM
Thread — M7 Mod Questions Thread Starter — collom7 Forum — Arctic Cat Replies — 13 Last Post — 02-01-2008 09:40 PM
