Upgrade to Premium
Ski-Doo: S-2000 and older 1998 and older, all models in the S-2000 chassis and older chassis models
Reply
  #1
Old 12-16-2015, 01:06 PM
1997formulazM-10 1997formulazM-10 is offline
Currently: Not set.
Basic Member
1997formulazM-10 is an unknown quantity at this point
Default 583 big bore
Hey guys I am putting my dads old race sled back together for him as a surprise. It's a 583 with fast twin pipes, he has told me the only Modification he had done was shave the head and run a thicker base gasket to make the pipes work better and jetting. i am going to run a 78 mm wiseco piston and have the raves cut down to match my question is how do I determine how much the head was shaved and what base gasket to run I can't see any markings on it
Rate this post: Yes | No
  #2
Old 05-23-2016, 05:18 PM
rotaxrules rotaxrules is offline
Currently: wishing for more snow
Basic Member
rotaxrules is an unknown quantity at this point
Default
yes there is markings on the base gasket on the back side between the two cylinders there is a series of holes punched in it like 5 holes or 6 holes they are different thickness I know alot of them used 5 hole gaskets with milled heads
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — best can bore big bore who's tryed a bunch what works Thread Starter — madmini660 Forum — Ski-Doo: XP Sleds Replies — 11 Last Post — 10-26-2012 04:24 PM
Thread — PSI Big Air 42mm Big Bore Carbs setup for 925 Thread Starter — vinpie1 Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 4 Last Post — 06-24-2011 07:56 PM
Thread — compleat intake for 600 700 800 big block in iqr chassis big bore 42mm carbs Thread Starter — brent9k Forum — IQR Parts Replies — 0 Last Post — 11-28-2010 12:03 AM
Thread — WTB: RK Tek 734 Big bore for 600H.O. or Other Big Bores Thread Starter — shiftx23 Forum — Engine/Engine Parts (Swapmeet) Replies — 3 Last Post — 11-14-2008 05:40 PM
Thread — 700 big block with 754 big bore kit pipes ? Thread Starter — treefarmer Forum — Performance/Modified Replies — 7 Last Post — 02-25-2008 07:24 PM
no new posts
