Upgrade to Premium
Polaris: IQ 2005-Current, all models in the IQ and IQ Raw chassis
Reply
  #1
Old 11-21-2015, 07:39 PM
smitfire smitfire is offline
Currently: Not set.
Basic Member
smitfire is an unknown quantity at this point
Default 2008 Polaris dragon 700 starts hard cold
I have a 2008 dragon 700 absolutely will not start outside. Put it in the shop and warm it up and then it starts. Not as good as it should be. This is an electric start model.
So my last time out last year my voltage regulator went out. Replaced with updated one. Put it away for the year.
Now I'm having the hard starting issues as mentioned above.
Did I smoke the ECU too? Would that make it start hard?
Rate this post: Yes | No
  #2
Old 11-23-2015, 04:16 PM
retiredpop retiredpop is online now
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
Does it have fresh fuel instead of last years fuel with stabilizer? I've heard of a faulty stator causing this kind of problem as well.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
  #3
Old 11-23-2015, 05:43 PM
Currently: Not set.
Basic Member
Default
Yeah fresh fuel
  #4
Old 11-23-2015, 08:22 PM
gtwitch gtwitch is offline
Currently: Not set.
gtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond repute
Default
I have a 07 700 Dragon and it has always been hard to cold start, but since I got it Christmas of 08, I have learned some tricks #1 Let the boys in their 40's start it!!! Seriously, It is not electric start so I just grab the rope and pull it through slowly about 10 or 12 rope pulls before I get agressive , It loosens it up and that seems to partially get the Capacitor charged up and the machine will go with two to five agressive pulls. You might have the capacitor checked and check/replace the fuel filter, if that is partially plugged or restrictive, could be a problem, also check the injector to reed Bellows/rubber for any sort of loose clamps, torn to cause a vaccum leak. I think that if I were still riding mine a lot, (it's my wifes machine now and she only goes on warm days) I would get in McMasters Carr and get a glue on silicon heat pad 45 to 90 watts and put it on the case, and plug it in if possible. I know a couple of guys have done this with the early Dragons to include the 900's. Just some thoughts here!
gtwitch in wyoming
  #5
Old 11-23-2015, 08:40 PM
Currently: Not set.
Basic Member
Default
Something is wrong with mine and probably yours. Mine has always started easy 3 pulls max. Sitting out in the cold. I have electric start too.
Now it takes 8 to 10 in the heated shop, won't start outside. Just funny it starts hard after the voltage regulator went out. Something needs attention, brought it to the local shop today as I think it's above my skill level.
I'm 24 years old and I will not buy a sled without electric start and reverse. Period!
  #6
Old 11-11-2016, 08:10 AM
Mat700 Mat700 is offline
Currently: Not set.
Basic Member
Mat700 is an unknown quantity at this point
Default
Did you fix the hard start? Im having the same problems
  #7
Old 11-14-2016, 06:15 PM
doobied23 doobied23 is offline
Currently: Not set.
Basic Member
doobied23 is an unknown quantity at this point
Default
Prime your fuel pump at the connector close to the front of the hood with a 12 volt battery... Prime for about 20 seconds get the fuel going through the fuel rail. Should start on 1 pull max 2
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to doobied23 For This Useful Post:
doobied23 (11-23-2016), snoboy (02-14-2018)
  #8
Old 01-12-2017, 11:38 PM
longvalley longvalley is offline
Currently: Not set.
longvalley has a brilliant futurelongvalley has a brilliant futurelongvalley has a brilliant futurelongvalley has a brilliant futurelongvalley has a brilliant futurelongvalley has a brilliant futurelongvalley has a brilliant futurelongvalley has a brilliant futurelongvalley has a brilliant futurelongvalley has a brilliant futurelongvalley has a brilliant future
Default
I was just having a hard starting issue and finally took to Polaris dealer. They found that the lines in the tank that feed the fuel pump had basically degraded and had actually broken in two. This was allowing fuel pump to suck air and or let the prime go back in the tank. They installed a new pump and lines. That's the only way Polaris sells it. Now it start in 2 to 3 pulls max.
  #9
Old 02-14-2018, 02:14 AM
snoboy snoboy is offline
Currently: getting it together
snoboy has a reputation beyond reputesnoboy has a reputation beyond reputesnoboy has a reputation beyond reputesnoboy has a reputation beyond reputesnoboy has a reputation beyond reputesnoboy has a reputation beyond reputesnoboy has a reputation beyond reputesnoboy has a reputation beyond reputesnoboy has a reputation beyond reputesnoboy has a reputation beyond reputesnoboy has a reputation beyond repute
Default
Can you describe this connector? Do I simply apply 12 volts for say 10 seconds? Is this due to the pump losing it's prime from sitting over the summer?
Mike
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — cold starts are killing me... Thread Starter — BikerPepe` Forum — Arctic Cat: 1M Replies — 7 Last Post — 05-28-2014 12:40 PM
Thread — 2008 polaris Dragon starts hard... Thread Starter — Toddstud2003 Forum — Polaris: IQ Replies — 8 Last Post — 12-30-2012 02:12 AM
Thread — Low Idle When Warm And Hard Cold Starts Thread Starter — rugbynitro Forum — Polaris: Pro-Ride Replies — 5 Last Post — 01-23-2012 11:36 PM
Thread — 2007 600 switchback bog and hard cold starts Thread Starter — Dave4441 Forum — Polaris Replies — 1 Last Post — 02-26-2009 10:07 PM
Thread — '03 700 RMK hard starting when cold Thread Starter — iceburg Forum — Polaris Replies — 0 Last Post — 03-04-2008 09:45 PM
no new posts
