Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 10-18-2015, 06:22 AM
GoBigParts's Avatar
GoBigParts GoBigParts is online now
Currently: Not set.
GoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond repute
Arrow SPI FIX-IT-KIT PISTON KIT AND STRAIGHTLINE KIT
Just wanted to let everyone know because I have not seen this before is we now have available the SPI Polaris CFI 800 Fix-it kits. What I like about this kit is the use of cast SPI T-moly coated pistons which are like what the oem uses except these have longer skirts with the spacer under cylinders. So expansion differences while warming up will not be as big of an issue as the forged pistons. I have used SPI's in the past on other Polaris and Ski-doo motors with no issues. Also like the price.
Also, we have added the Straightline Performance Fix-it kit to our site. This is a nice kit with an anodized spacer and Wiseco pistons with titanium coated rings, and longer skirts.
Both kits should be an improvement over stock with replacing pistons and increase case volume for an additional 2-3 HP addition.
You can order securely and safely here: http://www.gobigparts.com/FIX-IT-KITS-PISTONS.html
Please contact me with any questions.
UPDATE!!! I added the Hyperdrive pistons as a selection on the SPI fixit kit. Also, I added direct replacement SPI pistons to the link as well. So if you don't feel the need to do the spacer and longer pistons skirts but you just want to replace your pistons with an OEM style you can order those with a very cost effective T-moly or Hyperdrive kit.
I most admit any pro-ride with a 800CFI motor should get new pistons or at least check them by 2400 miles. This is just my experience.
__________________
randy@gobigparts.com
We Offer Skinz, Slydog, 509, WRP, SLP, Boss, True Adventures Gear, Powermadd, Sportech, VForce, Holtzman Eng, HMK, ROX and much more.
Rate this post: Yes | No
The Following 2 Users Say Thank You to GoBigParts For This Useful Post:
mountainhorse (10-18-2015), mtncat1 (10-17-2016)
  #2
Old 10-18-2015, 11:21 PM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: Riding the R6 TS LT and building the ZX6R 636
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
Default Fit it
Fit it kits are the best!!!
Lol.
That grammar police will get ya.
__________________
Try again
  #3
Old 10-19-2015, 05:57 AM
GoBigParts's Avatar
Currently: Not set.
Default
Yeah, I noticed that after posting and don't see anyway you can edit the title. Anyone know of a way?
__________________
  #4
Old 10-19-2015, 12:16 PM
Default
Quote:
Buzzfeedhorse can do it.
__________________
Try again
The Following 3 Users Say Thank You to Sheetmetalfab For This Useful Post:
GoBigParts (10-20-2015), mountainhorse (10-19-2015), NapaMatt (01-27-2016)
  #5
Old 10-20-2015, 05:33 AM
GoBigParts's Avatar
Currently: Not set.
Default
Thanks MH.
__________________
  #6
Old 10-29-2015, 03:47 PM
GoBigParts's Avatar
Currently: Not set.
Default
Anyone use either of these. I'm not sure if it is a complete fix but if I had higher milage or saw the need to replace mine due to visual wear, now that mine is out of warranty, I would certainly give them a try for the price.
__________________
  #7
Old 01-27-2016, 07:33 AM
GoBigParts's Avatar
Currently: Not set.
Default
SPI uses the tmoly cast pistons so should be at stock specifications and heat up like the stock ones.
__________________
  #8
Old 02-01-2016, 05:18 PM
bkpa's Avatar
bkpa bkpa is offline
Currently: Not set.
bkpa has a reputation beyond reputebkpa has a reputation beyond reputebkpa has a reputation beyond reputebkpa has a reputation beyond reputebkpa has a reputation beyond reputebkpa has a reputation beyond reputebkpa has a reputation beyond reputebkpa has a reputation beyond reputebkpa has a reputation beyond reputebkpa has a reputation beyond reputebkpa has a reputation beyond repute
Default
What is the part number of the SPI piston?
  #9
Old 02-06-2016, 09:57 AM
starrsleds's Avatar
starrsleds starrsleds is offline
Currently: Not set.
starrsleds has a reputation beyond reputestarrsleds has a reputation beyond reputestarrsleds has a reputation beyond reputestarrsleds has a reputation beyond reputestarrsleds has a reputation beyond reputestarrsleds has a reputation beyond reputestarrsleds has a reputation beyond reputestarrsleds has a reputation beyond reputestarrsleds has a reputation beyond reputestarrsleds has a reputation beyond reputestarrsleds has a reputation beyond repute
Default
I can look tonight when I get home I just did an spi kit but they just use an 2010-2011 arctic cat 800 piston says so rite on the box
  #10
Old 02-06-2016, 10:36 AM
GoBigParts's Avatar
Currently: Not set.
  #11
Old 02-23-2016, 11:48 AM
Fredrik Fredrik is online now
Currently: Not set.
Fredrik is an unknown quantity at this point
Click Here to Register
  #12
Old 03-27-2016, 07:13 AM
GoBigParts's Avatar
Currently: Not set.
  #13
Old 10-07-2016, 06:55 AM
GoBigParts's Avatar
Currently: Not set.
  #14
Old 10-17-2016, 06:03 AM
GoBigParts's Avatar
Currently: Not set.
  #15
Old 10-19-2016, 01:58 PM
luggnut luggnut is offline
Currently: 2016 M8000 162 Helium Sidekick turbo
Basic Member
luggnut has a reputation beyond reputeluggnut has a reputation beyond reputeluggnut has a reputation beyond reputeluggnut has a reputation beyond reputeluggnut has a reputation beyond reputeluggnut has a reputation beyond reputeluggnut has a reputation beyond reputeluggnut has a reputation beyond reputeluggnut has a reputation beyond reputeluggnut has a reputation beyond reputeluggnut has a reputation beyond repute
The Following User Says Thank You to luggnut For This Useful Post:
GoBigParts (10-20-2016)
  #16
Old 11-21-2016, 11:06 AM
GoBigParts's Avatar
Currently: Not set.
  #17
Old 12-04-2016, 05:53 AM
GoBigParts's Avatar
Currently: Not set.
  #18
Old 01-31-2017, 03:05 PM
GoBigParts's Avatar
Currently: Not set.
  #19
Old 08-22-2017, 05:06 PM
GoBigParts's Avatar
Currently: Not set.
  #20
Old 08-23-2017, 12:25 PM
gtwitch gtwitch is offline
Currently: Not set.
gtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond repute
  #21
Old 08-24-2017, 08:09 AM
Speed Shop Inc.'s Avatar
Speed Shop Inc. Speed Shop Inc. is offline
Currently: Not set.
Speed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond reputeSpeed Shop Inc. has a reputation beyond repute
  #22
Old 08-24-2017, 11:53 AM
Currently: Not set.
  #23
Old 08-26-2017, 07:42 AM
GoBigParts's Avatar
Currently: Not set.
  #24
Old 11-08-2017, 06:34 AM
GoBigParts's Avatar
Currently: Not set.
  #25
Old 05-25-2018, 06:41 AM
GoBigParts's Avatar
Currently: Not set.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 11+ Yamaha Fit Kit FS/FT Need 12+ Honda Fit kit Thread Starter — SLDHVN Forum — Snowbikes & Parts (Swapmeet) Replies — 1 Last Post — 09-25-2013 11:37 AM
Thread — Timbersled 121" Kit with Fit Kit New $5200 Shipped Thread Starter — snowbikekits.com Forum — Snowbikes & Parts (Swapmeet) Replies — 0 Last Post — 01-04-2013 07:52 PM
Thread — Brand new: Wiseco Piston Kit to fit skidoo - good price! Thread Starter — Broseph Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 10-09-2012 10:00 PM
Thread — RK Tech Drop in Piston Kit compared to PMS Polaris Fix Kit Thread Starter — tdorval Forum — Polaris: Pro-Ride Replies — 26 Last Post — 02-14-2012 01:02 PM
no new posts
