Upgrade to Premium
Reply
  #1
Old 10-13-2015, 08:28 AM
WhiskeyTee's Avatar
WhiskeyTee WhiskeyTee is offline
Currently: Pull my finger
WhiskeyTee has a reputation beyond reputeWhiskeyTee has a reputation beyond reputeWhiskeyTee has a reputation beyond reputeWhiskeyTee has a reputation beyond reputeWhiskeyTee has a reputation beyond reputeWhiskeyTee has a reputation beyond reputeWhiskeyTee has a reputation beyond reputeWhiskeyTee has a reputation beyond reputeWhiskeyTee has a reputation beyond reputeWhiskeyTee has a reputation beyond reputeWhiskeyTee has a reputation beyond repute
Default Transmit only beacon?
Is there transmit only beacon out there anywhere? Reason I ask is my two dogs go snow shoeing with us frequently and I would like to put a beacon in their packs, was hoping for a lower cost alternative that didn't receive.
Rate this post: Yes | No
  #2
Old 10-13-2015, 08:47 AM
inspector01 inspector01 is offline
Currently: Not set.
inspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond repute
Default
Pieps makes one, but I think you need a pieps beacon also to use it.
http://www.amazon.com/Pieps-TX600-Do.../dp/B007W52JS2
  #3
Old 10-13-2015, 10:31 AM
sledhead685's Avatar
sledhead685 sledhead685 is offline
Currently: Winter!
sledhead685 has a reputation beyond reputesledhead685 has a reputation beyond reputesledhead685 has a reputation beyond reputesledhead685 has a reputation beyond reputesledhead685 has a reputation beyond reputesledhead685 has a reputation beyond reputesledhead685 has a reputation beyond reputesledhead685 has a reputation beyond reputesledhead685 has a reputation beyond reputesledhead685 has a reputation beyond reputesledhead685 has a reputation beyond repute
Default
The only thing with a transmit only beacon is that if someone gets buried and one or more of these are not you will have to get to them and turn them off before performing the search, or you will be chasing multiple signals. Perhaps those transmitters for dogs made by Pieps are a different frequency and won't interfere with normal ones, which is why you would need a Pieps beacons to use with it, good idea.
  #4
Old 10-13-2015, 06:32 PM
nregistered nregistered is offline
Currently: Not set.
nregistered has a reputation beyond reputenregistered has a reputation beyond reputenregistered has a reputation beyond reputenregistered has a reputation beyond reputenregistered has a reputation beyond reputenregistered has a reputation beyond reputenregistered has a reputation beyond reputenregistered has a reputation beyond reputenregistered has a reputation beyond reputenregistered has a reputation beyond reputenregistered has a reputation beyond repute
Default
The Pieps TX600 transmits on a different frequency and can only be found with a searching Pieps DSP Pro.
If you put the normal frequency onto your dogs or onto your sled, then in a multiple burial situation, you and/or other rescuers won't know who is who or what is what.
  #5
Old 10-24-2015, 09:15 AM
WhiskeyTee's Avatar
Default
I think I have found a better solution that wouldn't interfere with the rescue of a person. Let me know what you think.
Www.skiretriever.com
  #6
Old 11-19-2015, 05:06 PM
SnowBigDeal's Avatar
SnowBigDeal SnowBigDeal is offline
Currently: Deploying Avalanche Airbags!
SnoWest Paid Sponsor
SnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond repute
Garage
Default
There is a pieps backup transmitter that works on a different frequency.
http://www.snowbigdeal.com/pieps-bac...ansmitter.html
__________________
THE AVALANCHE AIRBAG EXPERTS
Avalanche Airbags
Avalanche Beacons
509 Helmets & Goggles
Snowmobile Clothing
1-877-SNOW-BIG (1-877-766-9244)
  #7
Old 11-19-2015, 08:11 PM
Currently: Not set.
Default
That one operates on the 457 frequency and should only be worn on a person who also has a regular beacon. The TX600 is the one that operates on a different frequency: http://www.pieps.com/en/product/pieps-tx600
Unfortunate that they look so similar, because their purpose is quite different.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — S.O.S. Beacon Thread Starter — Master Forum — Communications Replies — 3 Last Post — 10-24-2011 08:57 PM
Thread — beacon help Thread Starter — 65pony123 Forum — Utah Replies — 2 Last Post — 12-11-2010 10:43 AM
Thread — S1 for a first beacon? Thread Starter — dgreet77 Forum — Avalanche Beacons Replies — 18 Last Post — 01-11-2010 08:43 PM
Thread — ABS Freeride Pack, Tracker Beacon, F1ND Beacon and SOS-SB Beacon for Sale in Alberta Thread Starter — oldkootrmk Forum — Communications Replies — 6 Last Post — 01-18-2009 11:31 PM
Thread — what beacon to buy...beacon vs. abs Thread Starter — sledr4life Forum — Avalanche Beacons Replies — 7 Last Post — 01-02-2008 01:27 PM
