Upgrade to Premium
Ski-Doo: S-2000 and older 1998 and older, all models in the S-2000 chassis and older chassis models
Reply
  #1
Old 09-22-2015, 08:39 PM
Boulderbronco Boulderbronco is offline
Currently: Not set.
Basic Member
Boulderbronco is an unknown quantity at this point
Default 98' Summit 670 Problems
Long story short, last year I overheated it. Took the top end apart and replaced all the seals. The pistons and cylinders had some moderate scoring. I figured I would put it back together and see how it did. Well I never got it running right. I did get it running ok but it was a bitch to start and seemed to struggle at the mid range. Then it would start stalling. I have not touched it since.
Today I did a compression test and had 110psi (+/-3) on each cylinder. I can't get the thing started. It's got spark and it's got tons of fuel (flooding). I blew it out and pulled another 50 times. Not even a cough. Is 110 to low to get the necessary compression to fire the cylinders? Thinking of rebuilding it but not sure I have the time. Maybe just sell it as is.
Anyway, is my engine pretty much toast and that's why it won't start? Thanks
Rate this post: Yes | No
  #2
Old 09-23-2015, 06:28 AM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
What elevation are you checking compression?
That doesn't seem low enough to keep it from running and might be normal if you are at high elevation.
Is it flooded/wet plugs? Is it the X or standard Summit?
  #3
Old 09-23-2015, 09:21 AM
Currently: Not set.
Basic Member
Default
It's the X. Yes, the plugs get soaked with fuel. It seems to be just fuel and not oil so I don't think it's pumping to much oil in. Right now I'm at about 5400' so that is where I am checking compression. I ride at 8-12K, sometimes higher.
  #4
Old 09-23-2015, 02:09 PM
Currently: Not set.
Basic Member
Default
More info. Used some gas directly into the chambers and it fired right up, for 1 second. So now thinking it's actually not getting fuel and or my fuel is bad (I'm leaning toward the not getting fuel). What I see on the plugs as far as them being soaked must be oil. I removed the air box and primed the hell out of it. I can see fuel dumping into the carbs. But after 20-30 more pulls, nothing. I just cleaned the carbs and put fresh gas in at the end of last year. Gas lasts much longer than people think so thats not it. Maybe I'll go through the carbs again. Any other suggestions?
Oh. There is air in the two blue primer lines to the carbs. When I prime it there are a bunch of bubbles. I'm thinking not a big deal since the main lines look fine and it's obviously getting fuel when I prime it.
Thanks
  #5
Old 12-11-2015, 03:01 PM
line8's Avatar
line8 line8 is online now
Currently: Not set.
line8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond repute
Ever figure this out?
have a 99 and has the same issue....except, I can eventually start it but it just won't stay without a shot of prime. I'm thinking not enough compression to keep it running or to get it running.
Sent from my telephone
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Are 99 SummitX 670 cylinders the same as a 97 Summit 670 Thread Starter — wags19 Forum — Ski-Doo: S-2000 and older Replies — 5 Last Post — 10-20-2013 08:07 PM
Thread — 1999 Summit X 670 air/ fuel problems Thread Starter — wags19 Forum — Ski-Doo: S-2000 and older Replies — 0 Last Post — 01-02-2013 11:05 PM
Thread — HELP...Ski Doo 670 problems!!! Thread Starter — powderhead Forum — Ski-Doo Replies — 11 Last Post — 01-20-2009 08:31 AM
Thread — 97 Summit 670 Thread Starter — bomber670 Forum — Ski-Doo (Swapmeet) Replies — 0 Last Post — 09-07-2008 09:42 PM
no new posts
