Upgrade to Premium
Yamaha: 4-Stroke Includes all Yamaha 4-strokes, Nytro, Apex, Phazer, etc
Reply
  #1
Old 09-02-2015, 11:47 AM
christopher's Avatar
christopher christopher is online now
Currently: Husky Powered, Woof Woof
christopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond repute
Garage
Default New Yamaha YXZ-R Side by Side
While this is NOT a snowmobile.
Its yet another interesting little tidbit of where Yamaha Motor Sports is going...
http://www.dirttoysmag.com/2015/09/y...llnew-yxz1000r
Yamaha Introduces All-New YXZ1000R
First and only pure sport side-by-side solidifies Yamaha leadership in powersports performance
Published online: Sep 01, 2015 Powersport News Viewed 794 time(s)
Kennesaw, GAYamaha Motor Corp., USA, introduces the all-new YXZ1000R, the world’s only pure sport side-by-side (SxS) vehicle. Boasting a high-performance 3-cylinder 998cc engine with a class-defining 5-speed sequential shift manual transmission, the two-seat YXZ1000R provides a superior driver-connected experience in the dunes, desert or on the trail.
“The YXZ1000R redefines the sport side-by-side category and solidifies Yamaha as the leader in powersports performance,” said Mike Martinez, Yamaha’s Recreational Vehicle (RV) group Vice President. “In the YXZ1000R, Yamaha has combined industry-first technology and performance with the durability and fit-and-finish SxS enthusiasts have been craving, and we’re confident the YXZ1000R will exceed all expectations.”
All-New Three-Cylinder, 998cc Side-by-Side Engine
The YXZ1000R’s 3-cylinder, 12-valve, DOHC, liquid cooled, 998cc engine puts out the most reliable and durable power of any 1,000cc-class machine. As the industry’s first sport 3-cylinder engine, it boasts an aggressive 11.3:1 compression ratio and 10,500 rpm redline to provide a true sport SxS experience.
With broad, linear torque, the YXZ1000R responds to driver input with exciting sport performance power from low- to high-rpm range, and the triple throttle bodies provide a more direct connection between driver throttle input and engine response.
A high-mounted, high-volume clean air inlet provides maximum airflow, while dual air filters—one oiled foam and wet pleated paper type—provide maximum filtration and superior engine performance in even the harshest riding environments. The durable and reusable foam filter features tool-free access for simplified maintenance.
The YXZ1000R incorporates an all-new high volume stainless steel exhaust system, complementing the vehicle's aggressive styling. The three-into-one YXZ1000R exhaust is tuned for maximum power output and meets EPA/CARB regulations with a muffler mounted integrated honeycomb catalyzer and removable spark arrestor.
Industry First Sequential Manual Side-by-Side Transmission
The YXZ1000R features the industry’s first fully manual 5-speed sequential shift transmission in a SxS vehicle, delivering a direct connection between driver and machine for superior performance, confidence and the first and only true pure sport SxS experience.
The 5-speed sequential shift is manually operated via a clutch pedal and short-stroke shift lever for smooth, secure gear engagement. With the YXZ1000R’s direct-drive transmission, driveline efficiency is increased, supplying optimal engine power directly to the rear wheels, while cam dampers on both the input and output shafts keep shifting smooth and precise.
The YXZ1000R’s all-new clutch design is optimized for the vehicle’s class-leading engine output, providing a smooth and connected shifting feeling with reliable power. The all-new sport-inspired foot-pedal operated hydraulic clutch system provides light, consistent and natural feeling feedback to the driver, increasing confidence in challenging off-road terrain.
Unmatched Handling and Performance
The YXZ1000R is born of true Yamaha performance DNA serving up unmatched handling characteristics, resulting in the vehicle’s features being perfectly positioned and integrated into a single, seamless package working as one.
Strategically mounted low and longitudinally in the chassis, the engine placement affords the YXZ1000R long rear wheel and suspension travel for superior sport SxS performance. A single shaft, one-axis balancer reduces engine vibration by 25 percent for a more comfortable ride while also allowing a rigid engine mount to reduce weight and offer a more direct throttle/engine feel for the driver.
The vehicle’s front differential incorporates Yamaha’s proven On-Command 2WD, 4WD and 4WD full diff-lock—a driver-controlled system that eliminates the hesitation or slipping experienced in computer-engaged systems. An automotive-style 4WD dial is intuitive and conveniently located on the center console, and provides simple and seamless transitions between the 2WD, 4WD and 4WD full diff lock settings.
The YXZ1000R employs Yamaha’s proven Electric Power Steering (EPS). Set in a new, more compact and lightweight EPS unit, the optimized steering ratios provide precise handling through the best balance of assist and positive feedback from the terrain. This combination creates maximum comfort and confidence in rough off-road conditions. The steering wheel is located in an optimal position and features a steel armature, soft grip over-mold, and driver tilt adjustability for maximum cabin comfort, fit and feel.
Critical for premium handling is strong, smooth and predictable stopping power, and the YXZ1000R accomplishes this by featuring four-wheel hydraulic disc brakes with twin piston calipers at all corners. The resulting unmatched brake “feel” delivers added confidence during aggressive driving. Large 245mm rotors were adopted for enhanced cooling and reduced brake noise.
Massive FOX 2.5 Podium Shocks Standard
The YXZ1000R boasts massive long travel FOX 2.5 Podium Shocks with 16 inches of travel in front and 17 inches out back. The piggyback reservoir shock absorbers provide top performance, confidence and comfort for driver and passenger.
The YXZ1000R front suspension catches the eye as it protrudes upward through the hood of the vehicle, making their top end visible from outside and inside the cockpit, projecting an aggressive, defiant image. The fully adjustable front and rear FOX shocks feature adjustable hi- and low-speed compression, adjustable rebound, and adjustable preload settings. The rear shock utilizes a FOX Bottom Out Cup (BOC) technology that helps maintain ongoing comfort while reducing the chance for bottoming out in extreme conditions.
The vehicle’s color matched, rigid bushing pivot double A-arm design is uniquely configured and provides superior handling and a comfortable, confidence-inspiring planted feeling in tough terrain, over deep whoops, and throughout all-day off-road punishment. The front A-arms have optimized castor, bump steer and Ackerman—throughout the travel and steering angle—to achieve the best cornering ability and positive steering feedback with light effort.
The rear double A-arm design is uniquely configured to provide superior handling and a comfortable, confidence-inspiring planted feeling. Spherical bearings ensure accurate tire alignment and the rear shocks are mounted as far out as possible, providing the longest and optimum stroke. The rear suspension design provides superior straight line stability with minimal camber variance throughout the entire range of travel.
All-New Styling and Design
The YXZ1000R boasts all-new styling, embodying Yamaha’s passion for pure sport performance and the SxS enthusiasts’ independent, confident, and aggressive attitude.
A sleek and nimble appearance plants the driver and passenger in the vehicle, creating a total man-machine integration and connection. The YXZ1000R features sharp lines and angles, jaw-dropping suspension projecting through the vehicle’s hood, and stylized wheels and tires.
The front fender gets a unique and aggressive look complementing the vehicle’s overall high-performance styling and enhanced visibility, and showcasing its massive front suspension. The newly designed front grill and carry bar continue the aggressive theme outlining the ominous four-eyed LED headlight system for high-performance illumination.
The rear fender features a unique, durable and functional design, also with an aggressive, compact look and an efficient, highly visible LED taillight. The lightweight and durable cargo bed provides the best combination of function and durability for high-performance sport SxS performance. The fixed position bed is rated to carry up to 300 pounds and features a water resistant sealed storage compartment, plus four steel tie-down points welded to the frame for strong and secure storage.
The standard YXZ1000R sun top has sharp styling and is seamlessly integrated into the chassis, complementing the entire design. All-new color-matched doors incorporate inset handles that are convenient, durable and easy to operate with two-stage automotive style latches and coil style door return springs.
Cab and Ergonomics
The YXZ1000R’s sporty two-seat chassis features a cockpit-like cab with comfortable and convenient ergonomics, plush contoured high-back, cut-and-stitch seats, sliding adjustable driver’s seat, and a soft-grip, tilt adjustable steering wheel with 147mm of vertical travel.
The cabin allows for quick and easy access to functional items for both the driver and passenger. A first for the sport SxS segment, the YXZ1000R features throttle, brake, and clutch pedals for true sport driving performance. The vehicle’s floorboards are positioned for maximum legroom, while maintaining a planted feeling in tough terrain, with dedicated closed-in floorboards for both driver and passenger.
Three-point seat belts, integrated shoulder bolsters and passenger hand-holds provide optimal support and occupant comfort, while the driver’s side features a new and durable 8 position (90mm) adjustable seat that smoothly slides by a convenient lever, quickly locking into the preferred location without any tools necessary.
The YXZ1000R dash layout balances functional features with intuitive ergonomics for both driver and passenger. A hybrid digital-analog multi-function meter features speedometer, tachometer and shift light, providing critical information with sport-inspired styling. The center console incorporates a parking brake handle, headlight switch, On-Command dial, and the all-new sequential manual shift lever. A convenient center storage tray and passenger-side latching glove box offer quick and secure storage options, while a center-mounted 12V outlet powers accessories and personal items.
Industry Leading Durability and Reliability
Yamaha SxS vehicles are known to be the most durable and off-road capable, and the YXZ1000R continues that tradition bringing an all-new level of reliability to the sport SxS segment.
The YXZ1000R’s all-new sport-inspired frame was built to provide the industry’s most durable and reliable performance with nimble handling and a comfortable, secure-feeling pure sport SxS experience. Its optimized frame dimensions result in the best handling sport SxS ever.
Full underframe protection covers the bottom of the vehicle from front-to-back and side-to-side while still incorporating easy access to service points. Yamaha employed lightweight and extremely durable Thermoplastic Olefin to provide the best impact resistance, flexibility and wear reduction, while also allowing the vehicle to easily glide over obstacles encountered on the trail.
All New 27-Inch Tires and Cast Aluminum Wheels
The YXZ1000R features Yamaha-exclusive 27-inch Maxxis Bighorn 2.0 radial tires with standard 14-inch cast aluminum wheels, providing the best combination of styling, durability, ground clearance and handling. The tires’ 6-ply radial construction allows for optimum traction, durability, comfort and steering precision, and the standard 14-inch cast aluminum rims have a unique, durable and functional design.
The all-new YXZ1000R is assembled at Yamaha’s U.S. factory in Newnan, Georgia for worldwide distribution. MSRP starts at $19,799 and color options include Yamaha Racing Blue/White, Blaze Orange/Black, and Yamaha’s 60th anniversary celebration Yellow-and-Black. Arriving at dealerships first, the 60th anniversary Special Edition (SE) model adopts Yamaha’s heritage color and graphic scheme and a true bead lock rim.
Follow Yamaha at http://facebook.com/yamahamotorusa, http://twitter.com/yamahamotorusa, and https://instagram.com/yamahamotorusa/.
#YAMAHA #YXZ1000R
Specifications:
Engine Type 998cc liquid-cooled DOHC inline three-cylinder; 12 valves
Bore x Stroke 80.0mm x 66.2mm
Compression Ratio 11.3:1
Fuel Delivery Yamaha Fuel Injection (YFI); three 41mm Mikuni throttle bodies
Ignition TCI: Transistor Controlled Ignition
Starting System Electric
Transmission 5-speed sequential manual external transmission; wet multiplate clutch, external flywheel
Final Drive Yamaha On-Command; 3-way locking differential; selectable 2WD and 4WD with diff lock; shaft drive
Suspension/Front Independent double wishbone w/anti-sway bar, fully adjustable FOX 2.5 Podium RC2 Shocks; 16.2-in travel
Suspension/Rear Independent double wishbone w/anti-sway bar, fully adjustable FOX 2.5 Podium RC2 Shocks; 17.0-in travel
Brakes/Front Dual hydraulic disc
Brakes/Rear Dual hydraulic disc
Tires/Front Maxxis MU09 27 x 9.00R-14
Tirres/Rear Maxxis MU10 27 x 11.00R-14
L x W x H 122.8 in x 64.0 in x 72.2 in
Wheelbase 90.6 in
Turning Radius 236.2 in
Maximum Ground
Clearance 12.9 in
Fuel Capacity 9.0 gal
Wet Weight 1510 lb
Bed Capacity 300 lb
Warranty 6 Month (Limited Factory Warranty)
Color Racing Blue/White w/Suntop; Blaze Orange/Black w/Suntop
*** Wet weight includes the vehicle with all standard equipment and all fluids, including oil, coolant (as applicable) and a full tank of fuel. It does not include the weight of options or accessories. Wet weight is useful in making real-world comparisons with other models.
__________________
Rate this post: Yes | No
  #2
Garage
Default
__________________
  #3
Old 09-02-2015, 12:35 PM
thamax thamax is offline
Currently: Not set.
Basic Member
thamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond repute
Default
so its gonna be 20k? turbo kit will be super easy with the exhaust and intake setup!
  #4
Old 09-02-2015, 01:32 PM
Sharp Sharp is offline
Currently: Not set.
Basic Member
Sharp has a reputation beyond reputeSharp has a reputation beyond reputeSharp has a reputation beyond reputeSharp has a reputation beyond reputeSharp has a reputation beyond reputeSharp has a reputation beyond reputeSharp has a reputation beyond reputeSharp has a reputation beyond reputeSharp has a reputation beyond reputeSharp has a reputation beyond reputeSharp has a reputation beyond repute
Default
Yet snowest didn't fail to mention the New ACE and several time the RZR. I'm just saying.
  #5
Old 09-02-2015, 01:48 PM
Thistledoo's Avatar
Thistledoo Thistledoo is offline
Currently: Bring on the POW!! and dont be shy!!!
Thistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond repute
Default
This could be a kickass unit...cant wait to see or try one
__________________
MCX BOV springs to make the BOV actually work proper...pm me for details
Copper exhaust doughnuts for rear mount yamahas...pm me for details
  #6
Old 09-02-2015, 04:21 PM
Garage
Default
Quote:
Say whatever you want, we published this in our magazine as a MAJOR feature article and on the FaceBook page.
__________________
  #7
Old 09-02-2015, 04:33 PM
Bocephus Bocephus is offline
Currently: Rye whisky Rye whisky Rye whisky I cry
Bocephus has a reputation beyond reputeBocephus has a reputation beyond reputeBocephus has a reputation beyond reputeBocephus has a reputation beyond reputeBocephus has a reputation beyond reputeBocephus has a reputation beyond reputeBocephus has a reputation beyond reputeBocephus has a reputation beyond reputeBocephus has a reputation beyond reputeBocephus has a reputation beyond reputeBocephus has a reputation beyond repute
Default
if all you want to see is polaris stuff, here ya go
http://www.rzrforums.net/
http://www.polarisatvforums.com/
http://www.rangerforums.net/
http://www.slingshotforums.com/forum/
http://www.aceforums.net/
__________________
17G4X165
SNOWMOBILE THEMED DOG COLLARS SKIDOO, CAT, POLARIS here ----> https://www.snowest.com/forum/showth...81#post4098281
  #8
Old 09-02-2015, 06:14 PM
BigFish BC's Avatar
BigFish BC BigFish BC is offline
Currently: Time to start breaking $hit theres snow on the ground.
BigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond repute
Default
looks like the vector motor,that thing will be a beast with a turbo kit
__________________
08 nytro with a bunch of boost -it parts
2015 boost-it viper & a couple of parts.
  #9
Old 09-02-2015, 06:42 PM
turbo800's Avatar
turbo800 turbo800 is offline
Currently: GOT BOOST???
turbo800 has a reputation beyond reputeturbo800 has a reputation beyond reputeturbo800 has a reputation beyond reputeturbo800 has a reputation beyond reputeturbo800 has a reputation beyond reputeturbo800 has a reputation beyond reputeturbo800 has a reputation beyond reputeturbo800 has a reputation beyond reputeturbo800 has a reputation beyond reputeturbo800 has a reputation beyond reputeturbo800 has a reputation beyond repute
Default
Quote:
MPI, is already on it
Click image for larger version
__________________
Toy Box
'17 Summit SP 850 165 x 3"- MPI 200HP turbo
'09 Summit X 800R 163 (Blk/Blu)- Stocker
'05 Summit X RT1000 - CS1240 Big Bore Kit 174"
CR500AF / '14 Timbersled 120 ST - Snowbike
'98 YZ 250 - Setup for single track trails
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to turbo800 For This Useful Post:
christopher (09-02-2015)
  #10
Old 09-02-2015, 08:58 PM
RACINSTATION's Avatar
RACINSTATION RACINSTATION is offline
Currently: Working on 2018 Proclimb mods
RACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond repute
  #11
Old 09-02-2015, 10:06 PM
Currently: Not set.
Basic Member
Click Here to Register
  #12
Old 09-02-2015, 11:21 PM
  #13
Old 09-03-2015, 07:34 AM
NEWDUCK NEWDUCK is offline
Currently: one ski dreams
Basic Member
NEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond repute
  #14
Old 09-03-2015, 10:59 AM
Turbo11T Turbo11T is offline
Currently: EVOLVING
Turbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond repute
  #15
Old 09-03-2015, 11:50 AM
madmax's Avatar
madmax madmax is offline
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
  #16
Old 09-03-2015, 12:10 PM
bholmlate bholmlate is offline
Currently: currently looking for work to support my habit
bholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond repute
  #17
Old 09-03-2015, 12:48 PM
  #18
Old 09-07-2015, 03:12 PM
BigFish BC's Avatar
  #19
Old 09-07-2015, 05:56 PM
fredw fredw is offline
Currently: 850 blown up before Breakin over
Basic Member
fredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond repute
  #20
Old 09-08-2015, 04:46 PM
BigFish BC's Avatar
  #21
Old 09-20-2015, 10:19 PM
Shred4Ever Shred4Ever is offline
Currently: Not set.
Shred4Ever has a reputation beyond reputeShred4Ever has a reputation beyond reputeShred4Ever has a reputation beyond reputeShred4Ever has a reputation beyond reputeShred4Ever has a reputation beyond reputeShred4Ever has a reputation beyond reputeShred4Ever has a reputation beyond reputeShred4Ever has a reputation beyond reputeShred4Ever has a reputation beyond reputeShred4Ever has a reputation beyond reputeShred4Ever has a reputation beyond repute
  #22
Old 09-20-2015, 10:23 PM
Currently: Not set.
  #23
Old 09-21-2015, 04:20 AM
Basic Member
  #24
Old 09-21-2015, 07:35 AM
Currently: Not set.
  #25
Old 09-30-2015, 06:53 PM
baapex baapex is offline
Currently: Not set.
Basic Member
baapex is an unknown quantity at this point
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — yamaha's new YXZ1000R sport side by side Thread Starter — Bocephus Forum — Fouled Plug Replies — 26 Last Post — 11-06-2015 09:51 PM
Thread — wtb Proclimb lower side panel/skid plate exhaust side Thread Starter — B-Ridge Sledder Forum — WTB (Swapmeet) Replies — 0 Last Post — 11-08-2014 11:39 AM
Thread — WTB Polaris PRO Orange Madness side panels, or clutch side silver panel. Thread Starter — dude Forum — Hoods/Windshields/Belly Pans (Swapmeet) Replies — 0 Last Post — 05-17-2012 03:14 PM
Thread — enclosed trailer, road side or curb side front ramp? Thread Starter — STORMY Forum — Trucks and Trailers Replies — 6 Last Post — 12-07-2010 02:50 PM
Thread — M1000 mag side 300 and pto side 700 degrees? Thread Starter — stay tuned Forum — Arctic Cat Replies — 6 Last Post — 02-11-2009 10:45 PM
