Upgrade to Premium
Yamaha: 4-Stroke Includes all Yamaha 4-strokes, Nytro, Apex, Phazer, etc
Reply
  #1
Old 08-31-2015, 11:05 PM
rreukema rreukema is offline
Currently: Not set.
Basic Member
rreukema has a reputation beyond reputerreukema has a reputation beyond reputerreukema has a reputation beyond reputerreukema has a reputation beyond reputerreukema has a reputation beyond reputerreukema has a reputation beyond reputerreukema has a reputation beyond reputerreukema has a reputation beyond reputerreukema has a reputation beyond reputerreukema has a reputation beyond reputerreukema has a reputation beyond repute
Default Skinz concept 38" bushings???
Looking for someone that has this front end.
I bought one off eBay and the seller listed as unknown manufacturer. I could tell they were skinz so I bought them for only $275. I have confirmed that they are indeed skinz.
[IMG] photo 20150828_132520_zpsz8rxqlj1.jpg[/IMG]
The red was chipped so I painted them snow camo.
[IMG] photo 20150831_165018_zps9q9xrtmt.jpg[/IMG]
What are the bushings supposed to look like? They look nothing like the oem yamaha ones. The holes in the bushings (that were solid stationary ones) had a hole just big enough for the bolts to go through unlike the sleeve type yami ones. Tia
Rate this post: Yes | No
  #2
Old 09-01-2015, 12:10 AM
bholmlate bholmlate is offline
Currently: currently looking for work to support my habit
bholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond repute
Default
I know their kit for 2008-09 needed to run a bushing kit that updated to the 2010 style bushings. They list the OEM part number under the concept a-arm kit for the Nytro. they designed the kit around 2010 nytro. i would just call skinz and talk with them. its tough to tell but they might be the oilite bushing kit you can buy. I don't have the front end sorry cant be more help
  #3
Old 09-01-2015, 06:15 PM
Currently: Not set.
Basic Member
Default
Sent a text to skinzprotectivegear, turns out they aren't concept arms. Anyone have an idea of who's arms these are?
  #4
Old 09-11-2015, 06:41 PM
off trail mike off trail mike is offline
Currently: Have snow...have sled.!!!
off trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond repute
Default
Wow......Yeah, not SPG. They are similar, but definitely not the same.
Not aware of any other a-arm manufacturers that look similar. Z-Bros very different. Maybe proto Timbersled, but they don't look like those either.
OTM
  #5
Old 09-11-2015, 09:29 PM
BigFish BC BigFish BC is offline
Currently: Time to start breaking $hit theres snow on the ground.
BigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond repute
Default
i cant remember there name but there was a shop in the usa that made a chromo nytro kit it came with diff spindles or could be a older set of cr racing arms.
  #6
Old 09-12-2015, 12:16 AM
MTN_VIPER's Avatar
MTN_VIPER MTN_VIPER is online now
Currently: Making roll-over valve kits since 2008
MTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond repute
Default
As others mentioned before they are very similar to Skinz arms, but Skinz arms do not have the gussets on the lower control arm where the pivot tubes attach to the main tube if I remember correctly.
Because there is no inner sleeve to act as a bearing surface, I'm thinking that they could be a one-off copy of the Skinz arms. Normally production arms will use an inner sleeve instead of having the bushing riding directly on the through bolt. The inner sleeve allows you to torque the control bolts down without having them pinch the sub frame down on the sides of the A arm, which could cause a bind and possibly allow the A arm bolts to work loose.
To use these arms you could have a machine shop ream out the bushings to fit your OEM Yamaha sleeves though.
__________________
Four Stroke Solutions LLC
Patented Roll-Over Valve Systems
ROV kits for M/XF7000/Viper, Sidewinder and King Cat with Quick-prime!
For Arctic Cat and Yamaha Sleds
Patents 8,225,766 8,528,516 9,303,537
http://fourstrokesolutionsllc.webs.com/
e-mail fourstrokesolutionsllc@hotmail.com
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Skinz 42" Concept A-arms Thread Starter — Montgom345 Forum — Suspension/Shocks (Swapmeet) Replies — 3 Last Post — 10-01-2015 07:38 AM
Thread — Skinz Concept 36" front end for XP, XM, or XS Fox Evol R shocks Thread Starter — jumpman23 Forum — Suspension/Shocks (Swapmeet) Replies — 6 Last Post — 02-16-2014 08:49 AM
Thread — Used 39" Skinz Concept A-arms and Evol-R Shocks - $1600 Thread Starter — beeze455 Forum — Suspension/Shocks (Swapmeet) Replies — 0 Last Post — 04-02-2013 07:37 AM
Thread — Skinz 39" Concept A-arms with Fox Evol Shocks Thread Starter — beeze455 Forum — Suspension/Shocks (Swapmeet) Replies — 0 Last Post — 01-28-2013 08:28 AM
Thread — New Concept from SKINZ PROTECTIVE GEAR "BLACK" Thread Starter — Sled Solutions Forum — Yamaha: 4-Stroke Replies — 41 Last Post — 02-10-2012 09:45 PM
no new posts
