Upgrade to Premium
Yamaha: 4-Stroke Includes all Yamaha 4-strokes, Nytro, Apex, Phazer, etc
Reply
  #1
Old 07-01-2015, 12:06 PM
sportsterdanne sportsterdanne is offline
Currently: Not set.
sportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond repute
Default Nytro vs. Apex Oil system.
I have Heard that the Apex models dont puke oil like the Nytro when Rolling over.
if so whats the difference ? just the oil tank or more ?
Rate this post: Yes | No
  #2
Old 07-01-2015, 06:14 PM
bholmlate bholmlate is offline
Currently: currently looking for work to support my habit
bholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond reputebholmlate has a reputation beyond repute
Default
I have never heard of this but I only have experience with the Nytro. if in fact this is the case it might have something to do with the mounting height of the air box in relationship to the breather line outlet from the tank. I don't think the oil tanks are designed any different internally besides the overall shape to work in the different chassis. the breather line still comes out the top just like the nytro.
The air box in the nytro is above the top of the oil tank and the breather line is shorter in length. So when the Nytro is upside down the air box is below the tank breather outlet so the oil has a short straight shot down the breather line into the air box and out.
In the Apex However, the air box is lower in the chassis so the breather line from the tank to the air box is slightly longer in length. When the sled is upside down the breather line outlet into the air box is level or slightly higher than the tank outlet causing the flow of oil is be more horizontal or slightly uphill to flow out. this would obviously cause the oil to flow more slowly and with the added capacity of the longer line there is a better chance for you to get the sled upright before the oil makes it all the way into the air box its just a general observation so i could be way wrong here Regardless both sleds need a roll over valve to protect against the oil draining out when the sled is upside down.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 11-02-2015, 02:33 AM
donbrown's Avatar
donbrown donbrown is offline
Currently: Let it snow !!!
donbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond repute
Default
So what weight and brand of oil are you using on the APEX / Nitro?
0-20 or 0-30 ?
__________________
www.CNSA.NET lifetime member
  #4
Old 11-19-2015, 07:16 AM
julio julio is offline
Currently: thinking fishing while waiting for snow
Basic Member
julio has a reputation beyond reputejulio has a reputation beyond reputejulio has a reputation beyond reputejulio has a reputation beyond reputejulio has a reputation beyond reputejulio has a reputation beyond reputejulio has a reputation beyond reputejulio has a reputation beyond reputejulio has a reputation beyond reputejulio has a reputation beyond reputejulio has a reputation beyond repute
Default oil
they both loose oil if upside down, the nytro looses more. best to put a rollover valve tether on and use it. besides it makes a mess of the engine bay.
julio
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Apex AIS idle system help? Thread Starter — MRFUSION Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 10 Last Post — 11-22-2014 09:57 AM
Thread — MPI Supercharger System Stage 1 APEX Thread Starter — ForcedAir Forum — Turbos/Superchargers (Swapmeet) Replies — 0 Last Post — 02-08-2011 12:31 AM
Thread — Fox Floats with Air Control System for Apex FS Thread Starter — Lake Effect Forum — Suspension/Shocks (Swapmeet) Replies — 4 Last Post — 12-15-2008 11:14 AM
Thread — Apex Boondocker turbo system! Thread Starter — RACINSTATION Forum — Turbos/Superchargers (Swapmeet) Replies — 9 Last Post — 03-10-2008 06:37 PM
no new posts
