Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 03-22-2015, 09:26 AM
MTsled3's Avatar
MTsled3 MTsled3 is online now
Currently: Not set.
MTsled3 has a reputation beyond reputeMTsled3 has a reputation beyond reputeMTsled3 has a reputation beyond reputeMTsled3 has a reputation beyond reputeMTsled3 has a reputation beyond reputeMTsled3 has a reputation beyond reputeMTsled3 has a reputation beyond reputeMTsled3 has a reputation beyond reputeMTsled3 has a reputation beyond reputeMTsled3 has a reputation beyond reputeMTsled3 has a reputation beyond repute
Default Anyone using Gates c12 belt?
In the pro ride forum, it seems like this is the only aftermarket belt worth a darn for the pro rmk's, guys are saying it's better than the stock belt but costs quite a bit less. I recently purchased a pro and I'm gonna be trying one out. My question Is, have any of you guys used one in your edge sleds? My dad has an 04 escape and we are curious if it is worth trying out for his sled too? A Google search found that the part number for the edge version of the belt is 48c4553, is this correct?
Rate this post: Yes | No
  #2
Old 03-24-2015, 10:37 AM
BILTIT's Avatar
BILTIT BILTIT is online now
Currently: Never enough snow!!!
BILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond repute
Default
I am also interested in trying the 44C4553 so i can have one belt for my 4 sleds. Keep us updated.
I am looking into pricing but it doesnt look good compared to the old -080 belts from polaris that i use now on the edge's.
The 48c4553 belts looks to be .8mm wider than the 44c4553 belt. Identical otherwise and same price at rockauto.
__________________
Derek B.
2000 440 xc sp 136 (EDGE)
2003 800 RMK 162
2004 910 PRO-XR 121x1.75", Wheelie Machine!!!
2011 LRod 13.6 800 ProRMK 3"PC KMOD/Raptors kmod 37" arms Ti can
  #3
Old 03-24-2015, 01:14 PM
MTsled3's Avatar
Currently: Not set.
Default
Wow rock auto is way cheaper than everywhere else, looking at about $70 for each + shipping. How much are you paying for your edge belts? I wanna say our dealer sells them for over $100, but it's been a while since I've needed one on my old edge.
  #4
Old 03-24-2015, 01:16 PM
BILTIT's Avatar
Default
edge belts are about $90 canadian and the PRO rmk is $200.
__________________
Derek B.
2003 800 RMK 162
  #5
Old 04-29-2018, 05:09 PM
BeartoothBaron BeartoothBaron is online now
Currently: Not set.
BeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond repute
Default
I know this is an old thread, but I'm wondering if anyone has a definitive answer to the original question. I'm currently running the 3211080; those seem to work well, but aren't especially cheap or durable. I ran a 3211122 belt for a while, but that seems hard on the clutch – I read somewhere it's cut at a slightly different angle, and it was starting to wear a groove in the primary.
Anyway, what I've found on the Gates belts is that they don't list a direct replacement carbon series for the 3211080. The 47G4572 is the standard replacement, but like the 48C4553, it's slightly wider, plus apparently 1/4" longer to boot. It would seem that the 48C4553 BILTIT mention should work, Gates cross-references it to the 3211078 (same as the 080, except it's a low-HP single-cog). Thing is, it's also wider, and 1/8" longer than the 080. The 44C4553, on the other hand, is the same width as the 080 (still 1/8" longer). Given the good reports on the C12s, I'm leaning towards switching to them next season, but it doesn't seem like any of them are a truly correct replacement!
  #6
Old 04-29-2018, 06:36 PM
BILTIT's Avatar
Default
I used a 44c4553 in my edge for a few hundred miles this season. It works fine. I ran the 080 and 1115 prior to this gates. They all worked about the same. (1115 lasted longer than 080).
I have noticed (especially in my 11 pro rmk) the 44c4553 is a tad bit wider than the 1115). I had my primary shimmed for .010 B-S clearance (on a 1115 belt) and the gates doesnt really like that tight. I have to run my belt tension alot on the loose side or the belt actually pulls down the engine rpm at idle.
Sent from my SM-G925W8 using Tapatalk
__________________
Derek B.
2003 800 RMK 162
The Following User Says Thank You to BILTIT For This Useful Post:
BeartoothBaron (04-30-2018)
  #7
Old 04-30-2018, 12:33 AM
Currently: Not set.
Default
Cool, that's good to know; I'll probably go with the 44C4553 since it seems to be the closest. It is interesting that you're finding that belt to be wider than the 115. Supposedly, the 115 is 1.46" wide, while the 44C4552 is 1.438, although the Polaris widths are "projected" (whatever that means). Can't seem to find any details from Gates, their catalog doesn't give measurements.
I'm still pretty confused as to why the 080 direct replacement is showing a different spec than the 080, and why they don't list a carbon series replacement. Pretty sure the 080 was Polaris's performance belt in the early 00s; meanwhile, they show the 48C4553 carbon belt as a replacement for the 078 belt, which apparently was intended for 340-550 models. Could be their cross-reference is garbage, or the measurements I'm finding are off, but it kind of throws off the warm fuzzy feeling about the Gates belts...
  #8
Old 04-30-2018, 06:09 PM
AdrenalineAddict AdrenalineAddict is offline
Currently: Looking Forward To A 0Degree Afternoon!!
Basic Member
AdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond repute
Default
Provided you can find a satisfactory match, the gates C series belts have been working great for me. I can't say they last any longer than a 3211183 but they positively work better in the springtime when underhood temps go through the roof. My OEM Polaris belts would start to color the sheaves brown with compound transfer, when I would see this and feel this (lack of RPM) I put on a gates C series belt and the performance would come back to normal. Subsequent inspections on the clutch faces were clean.
The Following User Says Thank You to AdrenalineAddict For This Useful Post:
  #9
Old 04-30-2018, 11:51 PM
Currently: Not set.
Default
Thanks! As of right now, I'm planning on buying either the 44C4553 or the 47C4572. The second one is the C12 version that Gates cross-references to the 3211080; turns out they do make one, but it wasn't in the catalog I was digging through. The 44C4553 seems to match the 080 specs more closely, but I have a thought that maybe the C12 has a taller top rib, which would account for it having a wider top width and bigger circumference. Think I'll email Gates and see if I can get an answer.
Pretty sure I experienced just what you're talking about regarding heat and RPM loss last time I rode. Temps were in the 50s with sunshine, and I was dropping to around 7500 on longer pulls. My clutching isn't perfect, but still, it wasn't nearly that bad when I rode in the same spot when it was colder. It's not like my 600 is going to tear up any belt that's decent, but one that's more consistent will make it a lot easier to tune the rest. Anyway, I'll report back if I can get an answer on the belt specs.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Gates belt # Thread Starter — m8braaaap Forum — Arctic Cat: Proclimb M Replies — 21 Last Post — 02-12-2017 12:01 PM
Thread — Thoughts on new Gates belt Thread Starter — Bigrock33 Forum — Polaris: Pro-Ride Replies — 0 Last Post — 09-01-2013 06:33 AM
Thread — Does GATES make a belt for the pro? Thread Starter — vdog0531 Forum — Polaris: Pro-Ride Replies — 2 Last Post — 12-19-2012 06:40 PM
Thread — Gates Xtreme belt Thread Starter — Schags Forum — Arctic Cat: M Series Replies — 5 Last Post — 11-16-2009 06:28 PM
Thread — Gates belt to replace the 377 xp belt Thread Starter — mt.sledder Forum — Ski-Doo Replies — 17 Last Post — 02-03-2009 07:05 PM
no new posts
