Upgrade to Premium
Ski-Doo: S-2000 and older 1998 and older, all models in the S-2000 chassis and older chassis models
Reply
  #1
Old 03-20-2015, 03:50 PM
patriots53 patriots53 is offline
Currently: Not set.
Basic Member
patriots53 is an unknown quantity at this point
Default 470 to 583 swap
Hi I have 94 skidoo formula mx 470 i wanted to swap out for a 583. I found a 97 583 motor, i was told it would bolt right in. Im curiois though if the clutch alignment will be correct and if i would have to get a new coil, new carbs, and make some adjustments. Thank you
Rate this post: Yes | No
  #2
Old 03-21-2015, 12:09 PM
nuttyn01 nuttyn01 is online now
Currently: Not set.
nuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond repute
Default
The clutch alignment specs will be the same for the 583. The coils will work. I think the 470 had smaller carbs, depending on year and models. I would run 40mm on the 583 set up for the altitude and temp of your riding. Both are very solid engines.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Motor Swap Steering Swap Thread Starter — SixtySevenGT Forum — Polaris: 900 Replies — 8 Last Post — 03-24-2016 08:33 AM
Thread — ECU swap Thread Starter — jman94 Forum — Polaris: IQ Replies — 0 Last Post — 01-20-2014 09:59 AM
Thread — Haydays new swap space price - will you still swap Thread Starter — Borderstaff Forum — General Snowmobiling Replies — 30 Last Post — 09-13-2009 09:33 AM
Thread — swap 540 fan for 485 fan???anyone?? Thread Starter — xsummitx Forum — Performance/Modified Replies — 0 Last Post — 12-20-2008 09:01 AM
no new posts
