Upgrade to Premium
Reply
  #1
Old 01-31-2015, 06:38 PM
dopey333 dopey333 is offline
Currently: Not set.
Basic Member
dopey333 has a brilliant futuredopey333 has a brilliant futuredopey333 has a brilliant futuredopey333 has a brilliant futuredopey333 has a brilliant futuredopey333 has a brilliant futuredopey333 has a brilliant futuredopey333 has a brilliant futuredopey333 has a brilliant futuredopey333 has a brilliant futuredopey333 has a brilliant future
Default EVO please help
So after everything iv done tcl stage 3 evo cold air rob kit straight pipe my sled today was wprse than before the tcl delete I chewed 2 belts in 3/4 of a day not riding hard at all iv only got 2 rides in and just a little frustrated thought I bullet proofed it.
Rate this post: Yes | No
  #2
Old 01-31-2015, 08:30 PM
Woody67's Avatar
Woody67 Woody67 is online now
Currently: Digging the Alpha One
Woody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond repute
Garage
Default
You could have one or more of several issues causing this.
First the TCL delete will do nothing to help if all of these 4 alignments are not correct.
1. center to center
2. vertical parallelism
3. horizontal parallelism
4. offset
The first three are difficult to measure and correct without the use of OSP tool. If all this is correct, you could have a defective drive part like the primary binding.
We have several high horsepower M1100 guys whose belt life was GREATLY increased with the addition of a Diamond S mesh hood.
Thanks,
Woody
__________________
Woody
Store:360-676-4096
Cell: 360-255-3381
stevewoodward@mtbakermoto.com
www.mtbakermoto.com
The Following User Says Thank You to Woody67 For This Useful Post:
Hotchief (02-04-2015)
  #3
Old 02-01-2015, 06:54 PM
TURBIE TURBIE is offline
Currently: Engineering for cat
TURBIE has a reputation beyond reputeTURBIE has a reputation beyond reputeTURBIE has a reputation beyond reputeTURBIE has a reputation beyond reputeTURBIE has a reputation beyond reputeTURBIE has a reputation beyond reputeTURBIE has a reputation beyond reputeTURBIE has a reputation beyond reputeTURBIE has a reputation beyond reputeTURBIE has a reputation beyond reputeTURBIE has a reputation beyond repute
Default
Quote:
It all depends on what you have done to your sled. If all you did was install the TCL delete bracket and expected it to be bullet proof there are a few things that need to go with this to be bullet proof.
-OSP engine snubber (must have)
-upgraded HD jackshaft (should have)
-upgraded chaincase gears and manual chain tensioner (should have)
  #4
Old 02-01-2015, 11:26 PM
Currently: Not set.
Basic Member
Default
i do have the osp snubber and the hd jack shaft chain im waiting until next year when I do head studs so im really hoping its as easy as just adjusting the alignment but anyother ideas cooling is something im looking into as well just need more cash flow.
  #5
Old 02-02-2015, 12:11 AM
Default
Ok good so I think all you need to do is have your clutch alignment done as per the instructions in your TCL delete kit, you don't have to do it with the OSP alignment bar but makes it easier with a lot less measurements and then check clutch offset for your final measurement.
Also check your clutches for binding as this has also been a big issue too.
  #6
Old 02-02-2015, 11:41 PM
6000fthigh 6000fthigh is offline
Currently: location
Basic Member
6000fthigh has a reputation beyond repute6000fthigh has a reputation beyond repute6000fthigh has a reputation beyond repute6000fthigh has a reputation beyond repute6000fthigh has a reputation beyond repute6000fthigh has a reputation beyond repute6000fthigh has a reputation beyond repute6000fthigh has a reputation beyond repute6000fthigh has a reputation beyond repute6000fthigh has a reputation beyond repute6000fthigh has a reputation beyond repute
Default more info
did you do the tci delete and how was it align
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
