Upgrade to Premium
Polaris: 900 05-06 Polaris RMK 900
Reply
  #1
Old 01-21-2015, 08:12 PM
TrailRebel's Avatar
TrailRebel TrailRebel is offline
Currently: Not set.
TrailRebel has a reputation beyond reputeTrailRebel has a reputation beyond reputeTrailRebel has a reputation beyond reputeTrailRebel has a reputation beyond reputeTrailRebel has a reputation beyond reputeTrailRebel has a reputation beyond reputeTrailRebel has a reputation beyond reputeTrailRebel has a reputation beyond reputeTrailRebel has a reputation beyond reputeTrailRebel has a reputation beyond reputeTrailRebel has a reputation beyond repute
Garage
Default High Idle, Dark Plugs
Hello all,
I'm having an issue with my 06 Switchy. Since the beginning of the season, I've had my 900 idling at 2200 RPMs when it's cold, 1100 RPMs when it's warm (unless I give it a little bit of throttle, then back to 2200 RPMs). I've inspected all the connections, replaced intake boots, reset TPS (and wiggled the pigtail), replaced spark plugs, replaced gas with fresh, and tested for intake leaks by spraying starting fluid with the engine running.
I found nothing, sled still has erratic idle.
I felt safe enough to ride it, it has good power, but "stumbles" when the throttle is held in the same position anywhere above 6000 RPMs. Increase or decrease throttle, and the problem goes away. Next day I checked plugs...it's running pig rich!!! Started looking over wiring harness, and I couldn't find anything. Took off FnI airbox, started fiddling with the Intake Air Temp Sensor...this is where it gets weird...holding the sensor and trying to heat it up, does nothing. But when blown on, idle drops down to 1600 and sounds healthy. Eventually, the idle will come back up to 2200. When the sensor is disconnected, the idle comes back down to 1600, but flashes a check engine light. I never ohm'd it out, but is there a possibility the sensor is bad? I'd hate to buy a $90 sensor, only to find out it's supposed to do that!!! I also read in the service manual that the sensor resistance should be 9.7 - 10.3 KΩ at 77*...but I've read that some people have problems with the sensor within the stated specifications.
Any help or insight is highly appreciated!!!
__________________
'06 Polaris RAW 900 SwitchBack
Rate this post: Yes | No
  #2
Old 01-21-2015, 09:14 PM
Cerialsledder's Avatar
Cerialsledder Cerialsledder is offline
Currently: Flatlanderextraordinaire
SnoWest Badge Maker
Cerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond repute
Garage
Default
if you have already checked everything above then I would start checking PTO crank seal, mag side crank seal, injector seals (o-rings). My switchback was acting like that last year and I ended up having a bad pto crank seal which ended up in me seizing the pto side crank bearings. Not sure if the seal would contribute to that but I'm assuming so
__________________
  #3
Old 01-21-2015, 09:25 PM
slash's Avatar
slash slash is offline
Currently: ahhh back to work
Parts Moderator & Chat Box Cop
slash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond repute
Garage
Default
if your getting a change from the sensor it works but it may not work within the proper range ...works when you blow on it ! but not in place something blocking it's air flow ?
__________________
09 IQ
KMOD
RAPTORS
2.5 CE
MOHAWKS
SLP PIPE
KOOLME KUSTOMS 660 KIT
TATERSPORTING PORTWORK
[IMG]//www.snowest.com//www.snowest.com/i/snowest-forum-logo.jpg[/IMG]
  #4
Old 01-22-2015, 12:26 PM
TrailRebel's Avatar
Currently: Not set.
Garage
Default
Quote:
I checked the seals by running the engine and spraying starting fluid. I couldn't find any spots where the idle would change... The mag and pto seals were replaced early last season, and all of last season there weren't any problems. What gets me, is that the idle is high, yet the plugs definitely indicate rich.
__________________
  #5
Old 01-22-2015, 02:38 PM
SnoWest Badge Maker
Garage
Default
Stuck injectors? Get a bottle of amzoil PI and run it through a tank of gas and see if it helps. If not then I would pull the injectors and have them flow tested and fixed
__________________
  #6
Old 01-22-2015, 04:16 PM
TrailRebel's Avatar
Currently: Not set.
Garage
Default
I thought about that as well, but both side plugs looked the same...It would just be a weird coincidence for two injectors (or more) on different cylinders to go bad at the same time. It's definitely worth a shot, though!!!
__________________
  #7
Old 02-07-2015, 08:34 AM
TrailRebel's Avatar
Currently: Not set.
Garage
Default
So, last weekend, I brought the sled home to my garage so I could do some diagnostics for it. Cleaned throttle bodies, reset TPS from .716 to .710, idle set to .930, replaced the TPS harness up to the ground splice for the coolant temp sensor.
The sled doesn't seem to be as picky about temperature, but now there is no rhyme or reason when it idles up...it's a 50/50 shot whether it idles at 2000 rpm or 1600 rpm. when it's idling high, unplugging any sensor will lower the rpm to 1600 (but flash a corresponding check engine light).
I'm about to go back out and pull the flywheel to check for separation/chaffing.
Any other ideas?
__________________
  #8
Old 02-07-2015, 11:34 AM
NapaMatt's Avatar
NapaMatt NapaMatt is offline
Currently: Stocking shelves, Need Parts??
NapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond repute
Garage
Default
You got a case of CHIPPED REEDS!!!
Take the throttle bodys off and the boots and have a look!!
Betting ur missing more then one pedal!!!
__________________
FOR SALE... SLP Pipe Set For Pro RMK 800... PM. Me for Details BRAND NEW 2013 ASSAULT PIGGY BACK FRONT SHOCKS FOR SALE!! $$650!!! Gas Tank From a 07 Switchback/ Seat Red and Black No tears. Plus fuel lines.
http://www.napaonline.com/
Theye Supply 1-507-533-6610
Auto Parts, Snowmobile, ATV, Truck and Trailer.. and
Shop Local!!
  #9
Old 02-07-2015, 02:03 PM
whetsel.m whetsel.m is offline
Currently: Not set.
Basic Member
whetsel.m has a reputation beyond reputewhetsel.m has a reputation beyond reputewhetsel.m has a reputation beyond reputewhetsel.m has a reputation beyond reputewhetsel.m has a reputation beyond reputewhetsel.m has a reputation beyond reputewhetsel.m has a reputation beyond reputewhetsel.m has a reputation beyond reputewhetsel.m has a reputation beyond reputewhetsel.m has a reputation beyond reputewhetsel.m has a reputation beyond repute
Default
Let us know what you find out!
  #10
Old 02-08-2015, 08:55 AM
TrailRebel's Avatar
Currently: Not set.
Garage
  #11
Old 02-08-2015, 08:56 AM
TrailRebel's Avatar
Currently: Not set.
Garage
Click Here to Register
  #12
Old 02-10-2015, 05:39 PM
TrailRebel's Avatar
Currently: Not set.
Garage
  #13
Old 02-10-2015, 10:29 PM
guidoxpress's Avatar
guidoxpress guidoxpress is offline
Currently: Tearing up Alaskas BOMB POW
guidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond repute
Garage
The Following User Says Thank You to guidoxpress For This Useful Post:
TrailRebel (02-11-2015)
  #14
Old 12-20-2015, 05:28 PM
TrailRebel's Avatar
Currently: Not set.
Garage
  #15
Old 12-20-2015, 11:05 PM
Confusion 900 Confusion 900 is offline
Currently: Not set.
Basic Member
Confusion 900 is an unknown quantity at this point
  #16
Old 12-21-2015, 01:55 PM
TrailRebel's Avatar
Currently: Not set.
Garage
  #17
Old 12-22-2015, 07:19 PM
snobrdrydr snobrdrydr is offline
Currently: waiting for the next ride!
Basic Member
snobrdrydr is an unknown quantity at this point
  #18
Old 12-22-2015, 09:19 PM
TrailRebel's Avatar
Currently: Not set.
Garage
  #19
Old 12-22-2015, 11:52 PM
Basic Member
  #20
Old 12-23-2015, 06:36 AM
SnoWest Badge Maker
Garage
  #21
Old 12-24-2015, 03:13 PM
TrailRebel's Avatar
Currently: Not set.
Garage
  #22
Old 12-24-2015, 03:16 PM
TrailRebel's Avatar
Currently: Not set.
Garage
  #23
Old 01-31-2016, 10:39 PM
Garage
  #24
Old 02-05-2016, 04:56 PM
TrailRebel's Avatar
Currently: Not set.
Garage
  #25
Old 04-22-2017, 12:34 AM
Garage
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — M8 High Idle and No Go Thread Starter — druffel07 Forum — Arctic Cat: M Series Replies — 16 Last Post — 12-15-2013 01:15 PM
Thread — High idle then backfire then normal idle? Thread Starter — Cerialsledder Forum — Polaris: 900 Replies — 0 Last Post — 03-22-2013 01:53 PM
Thread — 2009 rmk 700 fouling plugs and low idle Thread Starter — Minimum91octane Forum — Polaris: IQ Replies — 4 Last Post — 09-10-2012 08:13 PM
Thread — 08 d8 idle too high Thread Starter — MajorDirty Forum — Polaris: IQ Replies — 6 Last Post — 01-24-2012 10:30 PM
Thread — High idle then low idle, and no reverse Thread Starter — Whiz-bang Forum — Polaris: Pro-Ride Replies — 11 Last Post — 01-23-2012 10:51 PM
no new posts
