Upgrade to Premium
Ski-Doo: S-2000 and older 1998 and older, all models in the S-2000 chassis and older chassis models
Reply
  #1
Old 01-18-2015, 07:40 AM
martinktm martinktm is offline
Currently: Not set.
Basic Member
martinktm is an unknown quantity at this point
Default Ski doo 500 formula deluxe no idle, no throttle problem.
Hi, I am from Slovenia so I apologize if my english is not perfect. I have ski sleds ski doo 500 formula delux year 1997. The problem started when the sleds did not have a spark.
After some measurements I figured out that the coil that gives voltage to CDI is not ok (250k ohm measured with multimeter) after rewinding that coil multimeter shows 13 ohms and at starting around 16 volts is generated.
But the sled still did not have spark.Next I ordered CDI from ebay (used) It looked like orginal even cables are the same color. So I connect the CDI to the sleds and still no spark.
After some playing around I figured that if I reverse the wires from pick up to CDI (orginal blue wire to blue and white wire to white, after reversing white wire to blue and blue wire to white) I do get a spark.
Ofcourse after geting the spark I wanted to start the sleds. They did start but where running very poorly and I had to push the fuel with manual pump to keep them alive. The throttle had no effect.
Ok I decide to clean carburators after cleaning I try again but the condition is the same.Then I decide to take apart fuel pump and in membrane I found oil (probably shouldnt be there) so I clean the membrane and try again but still no luck.
Now I dont know what to do any more it is possible that the cdi is not firing at right spot or is it mechanical problem. The sleds where runing fine before no spark problem.
Thanks for your help.
Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Pilot 5.9 skis on a 99 Formula Deluxe 583 Thread Starter — Do-The-Doo Forum — Ski-Doo: S-2000 and older Replies — 2 Last Post — 12-31-2011 10:06 AM
Thread — Need 2001 Skidoo Formula Deluxe 380 wiring info Thread Starter — tdpaxto Forum — Ski-Doo: S-2000 and older Replies — 0 Last Post — 01-19-2010 07:27 PM
Thread — New reverse wiring info - 2000 Formula Deluxe 380 Thread Starter — tdpaxto Forum — Ski-Doo: S-2000 and older Replies — 0 Last Post — 01-18-2010 04:58 PM
Thread — Voltage Regulator on 2000 Formula Deluxe Thread Starter — plcalnan Forum — Ski-Doo: ZX Sleds Replies — 2 Last Post — 01-10-2010 11:57 AM
Thread — would formula stx pipes fit on a deluxe? Thread Starter — skidoo777 Forum — Performance/Modified Replies — 2 Last Post — 02-02-2009 03:26 PM
no new posts
