Upgrade to Premium
General Snowmobiling Snowmobile related topics only
Reply
  #1
Old 11-26-2007, 09:32 PM
Rocky Rocky is offline
Currently: Worthless
Rocky has a reputation beyond reputeRocky has a reputation beyond reputeRocky has a reputation beyond reputeRocky has a reputation beyond reputeRocky has a reputation beyond reputeRocky has a reputation beyond reputeRocky has a reputation beyond reputeRocky has a reputation beyond reputeRocky has a reputation beyond reputeRocky has a reputation beyond reputeRocky has a reputation beyond repute
Thumbs up Enclosed Trailer Flooring Question
I've had a couple enclosed trailers, one with LineX and the other is the new Mirage plastic coated floor. Both worked well, each has differences IMO.
I am looking at a gooseneck race trailer I can use for other hobbies and I notice several have the "black coin rubber flooring". I've seen flooring before in Featherlite Race Car Haulers, etc.and they appeared to hold up well to race fuel, degreasers, brake cleaner, water, dirt, etc..
They say it's layed on the plywood floor in one piece, no seams. I guess a guy could just use SLP skins or ski boots, knowing a carbide would probably cut into the hard rubber. Since it's a gooseneck, I'd have to drag them out the back or use the dolly. Do you think you could hose it out still, broom out the snow and ice, mop it on a warm day etc? It looks really nice and appears to be very durable. I know it's a pricey option, that's for sure.
Anyone seen this used in the snowmobile world? Any thoughts or comments?
I figured somebody on here would surely have an opinion! LMAO
Thanks.
Rate this post: Yes | No
  #2
Old 11-26-2007, 10:24 PM
MtnDoo MtnDoo is offline
Currently: Preparing
Basic Member
MtnDoo has a reputation beyond reputeMtnDoo has a reputation beyond reputeMtnDoo has a reputation beyond reputeMtnDoo has a reputation beyond reputeMtnDoo has a reputation beyond reputeMtnDoo has a reputation beyond reputeMtnDoo has a reputation beyond reputeMtnDoo has a reputation beyond reputeMtnDoo has a reputation beyond reputeMtnDoo has a reputation beyond reputeMtnDoo has a reputation beyond repute
Default
Hey Tim,
If it's rubber/plastic, I'd be concerned that spilling the typical oil/grease etc would create a bananna peel effect.
I've been looking at a marine-grade adhesive gel coat that is used to texture fiberglass boat decks - since it would have some grip, and be easily hosed down. It would definitely require ski boots though.
I think I'm going to end up doing diamond-plate with mats and place some of the clear marine gel-texture in the traction areas.
http://www.modulinecabinets.com/photos/photo187.jpg
Best of luck!
MD.
  #3
Old 11-26-2007, 10:28 PM
Ski-Laxn Ski-Laxn is offline
Currently: I'm back
Ski-Laxn has a reputation beyond reputeSki-Laxn has a reputation beyond reputeSki-Laxn has a reputation beyond reputeSki-Laxn has a reputation beyond reputeSki-Laxn has a reputation beyond reputeSki-Laxn has a reputation beyond reputeSki-Laxn has a reputation beyond reputeSki-Laxn has a reputation beyond reputeSki-Laxn has a reputation beyond reputeSki-Laxn has a reputation beyond reputeSki-Laxn has a reputation beyond repute
Default
The blackdot flooring is very nice and the chemicals arn't the issue the skegs are though and will cut it.
  #4
Old 12-26-2007, 10:47 PM
Dogmeat's Avatar
Dogmeat Dogmeat is offline
Currently: Back in the game!
Dogmeat has a reputation beyond reputeDogmeat has a reputation beyond reputeDogmeat has a reputation beyond reputeDogmeat has a reputation beyond reputeDogmeat has a reputation beyond reputeDogmeat has a reputation beyond reputeDogmeat has a reputation beyond reputeDogmeat has a reputation beyond reputeDogmeat has a reputation beyond reputeDogmeat has a reputation beyond reputeDogmeat has a reputation beyond repute
Default
I know this has been asked 7 billion times before...
but why will Rhino Liner sprayed on thick NOT work?
I mean yeah your carbides will eventually cut it, but is that really a bad thing? I mean even with that mirage flooring eventually my carbides are gonna wear that out ...
I've been towing my parents Charmac the last couple days, and it has the plain wood flooring, and after slipping sliding, having to get running starts just to load the damn sleds, etc, it's making my Mirage look more appealing all the time...
__________________
2018 Polaris Switchback Assault 800 144
2018 Polaris Axys RMK 800 174
  #5
Old 12-26-2007, 10:59 PM
donbrown's Avatar
donbrown donbrown is online now
Currently: Let it snow !!!
donbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond repute
Default
The Rino coating is expensive. The best and most durable deal is a marine-grade fiberglass and add sand for traction. Very durable.
You can buy a truck bed liner for $20 at the junk yard and make tracks or cut out a section the size of a ski and strap it to the ski and slide it around without hurting the carbides or trailer floor.
  #6
Old 12-26-2007, 11:00 PM
Basic Member
Default
Dogmeat - lots of way to do this of course.
I got a quote for $2K to put in Rino lining - and to know that that floor was going to get trashed - forget it. Ski boots do the trick, but get old - especially when it's cold. I don't mind investing in good flooring material, but I'd be more apt to invest if I know it's not going to get trashed.
  #7
Old 12-26-2007, 11:12 PM
2mileshigh 2mileshigh is offline
Currently: Not set.
2mileshigh has a reputation beyond repute2mileshigh has a reputation beyond repute2mileshigh has a reputation beyond repute2mileshigh has a reputation beyond repute2mileshigh has a reputation beyond repute2mileshigh has a reputation beyond repute2mileshigh has a reputation beyond repute2mileshigh has a reputation beyond repute2mileshigh has a reputation beyond repute2mileshigh has a reputation beyond repute2mileshigh has a reputation beyond repute
Default liner
Put rino liner on my enclose, very tuff and easy to clean.
  #8
Old 12-27-2007, 03:16 AM
Bagger's Avatar
Bagger Bagger is offline
Currently: Please help support YOUR riding area! 5 Minutes to write a letter . . . or join SAWS!
Bagger has a reputation beyond reputeBagger has a reputation beyond reputeBagger has a reputation beyond reputeBagger has a reputation beyond reputeBagger has a reputation beyond reputeBagger has a reputation beyond reputeBagger has a reputation beyond reputeBagger has a reputation beyond reputeBagger has a reputation beyond reputeBagger has a reputation beyond reputeBagger has a reputation beyond repute
Default
[QUOTE=I've been towing my parents Charmac the last couple days, and it has the plain wood flooring, and after slipping sliding, having to get running starts just to load the damn sleds, etc, it's making my Mirage look more appealing all the time...[/QUOTE]
DM, I've got a Charmac and was tired of the exact same things. This summer I spent 50 bucks for a two part epoxy garage floor paint kit. It's light grey.
A couple of buddies donated old truck bed liners they had laying around, and I cut runners out of it.
I've already spilled oil and gas on the floor , no problems, and the sleds load so much easier with the bed liner it just about makes me laugh everytime I load them!
Total was about three afternoon of work. Sure was worth it! Bagger
__________________
WSSA/SkiBenders
Best Mod to date: Back Country Basics Clinic!
"Laws control the lesser man. Right conduct controls the greater one."
  #9
Old 12-27-2007, 05:48 PM
Default
Thanks for the input. I ended up buying a trailer that has the front/cabinet area in the grey dot floor. I'm going to just put rubber backed mats here, as this is the area we're in/out of the most. The remainder of the trailer was done in diamond plate flooring. I'm going with marine grade gray carpet for this year. I'm thinking of having it LineX'd over the summer. I think it will bond with the aluminum and should wear just fine. Agree?
I got too good of a deal on this brand new gooseneck, only thing wrong is the floor for sledding.
  #10
Old 12-27-2007, 08:42 PM
Sunridge Sledhead's Avatar
Sunridge Sledhead Sunridge Sledhead is offline
Currently: Let it snow!!!!
Sunridge Sledhead has a reputation beyond reputeSunridge Sledhead has a reputation beyond reputeSunridge Sledhead has a reputation beyond reputeSunridge Sledhead has a reputation beyond reputeSunridge Sledhead has a reputation beyond reputeSunridge Sledhead has a reputation beyond reputeSunridge Sledhead has a reputation beyond reputeSunridge Sledhead has a reputation beyond reputeSunridge Sledhead has a reputation beyond reputeSunridge Sledhead has a reputation beyond reputeSunridge Sledhead has a reputation beyond repute
  #11
Old 12-27-2007, 09:50 PM
Beels Beels is offline
Currently: There's NOTHING free or basic about me
Basic Member
Beels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond repute
Click Here to Register
The Following User Says Thank You to Beels For This Useful Post:
M-Head (01-02-2017)
  #12
Old 12-27-2007, 10:55 PM
ndmtnsledder ndmtnsledder is offline
Currently: Not set.
ndmtnsledder has a reputation beyond reputendmtnsledder has a reputation beyond reputendmtnsledder has a reputation beyond reputendmtnsledder has a reputation beyond reputendmtnsledder has a reputation beyond reputendmtnsledder has a reputation beyond reputendmtnsledder has a reputation beyond reputendmtnsledder has a reputation beyond reputendmtnsledder has a reputation beyond reputendmtnsledder has a reputation beyond reputendmtnsledder has a reputation beyond repute
  #13
Old 12-28-2007, 12:50 PM
Dogmeat's Avatar
  #14
Old 12-30-2007, 03:20 AM
Mortgage Paul Mortgage Paul is offline
Currently: Looking at the snow
Mortgage Paul has a reputation beyond reputeMortgage Paul has a reputation beyond reputeMortgage Paul has a reputation beyond reputeMortgage Paul has a reputation beyond reputeMortgage Paul has a reputation beyond reputeMortgage Paul has a reputation beyond reputeMortgage Paul has a reputation beyond reputeMortgage Paul has a reputation beyond reputeMortgage Paul has a reputation beyond reputeMortgage Paul has a reputation beyond reputeMortgage Paul has a reputation beyond repute
  #15
Old 12-30-2007, 10:58 AM
dmkhnr dmkhnr is offline
Currently: Winter was over before it started
dmkhnr has a reputation beyond reputedmkhnr has a reputation beyond reputedmkhnr has a reputation beyond reputedmkhnr has a reputation beyond reputedmkhnr has a reputation beyond reputedmkhnr has a reputation beyond reputedmkhnr has a reputation beyond reputedmkhnr has a reputation beyond reputedmkhnr has a reputation beyond reputedmkhnr has a reputation beyond reputedmkhnr has a reputation beyond repute
  #16
Old 12-30-2007, 11:07 AM
Wyoming T/A Wyoming T/A is offline
Currently: Camaro has arrived
Wyoming T/A has a reputation beyond reputeWyoming T/A has a reputation beyond reputeWyoming T/A has a reputation beyond reputeWyoming T/A has a reputation beyond reputeWyoming T/A has a reputation beyond reputeWyoming T/A has a reputation beyond reputeWyoming T/A has a reputation beyond reputeWyoming T/A has a reputation beyond reputeWyoming T/A has a reputation beyond reputeWyoming T/A has a reputation beyond reputeWyoming T/A has a reputation beyond repute
  #17
Old 12-30-2007, 11:59 AM
thinksnow thinksnow is offline
Currently: On the mend-neck surgery
thinksnow has a reputation beyond reputethinksnow has a reputation beyond reputethinksnow has a reputation beyond reputethinksnow has a reputation beyond reputethinksnow has a reputation beyond reputethinksnow has a reputation beyond reputethinksnow has a reputation beyond reputethinksnow has a reputation beyond reputethinksnow has a reputation beyond reputethinksnow has a reputation beyond reputethinksnow has a reputation beyond repute
  #18
Old 12-30-2007, 04:00 PM
  #19
Old 12-30-2007, 05:15 PM
johndeere8420 johndeere8420 is offline
Currently: Ready for SNOW
Basic Member
johndeere8420 is on a distinguished roadjohndeere8420 is on a distinguished roadjohndeere8420 is on a distinguished road
  #20
Old 12-30-2007, 08:44 PM
Treebender Treebender is offline
Currently: Not set.
Basic Member
Treebender will become famous soon enoughTreebender will become famous soon enoughTreebender will become famous soon enoughTreebender will become famous soon enoughTreebender will become famous soon enoughTreebender will become famous soon enoughTreebender will become famous soon enoughTreebender will become famous soon enoughTreebender will become famous soon enoughTreebender will become famous soon enoughTreebender will become famous soon enough
  #21
Old 01-03-2008, 01:06 AM
BigRed118 BigRed118 is offline
Currently: Not set.
Basic Member
BigRed118 has a reputation beyond reputeBigRed118 has a reputation beyond reputeBigRed118 has a reputation beyond reputeBigRed118 has a reputation beyond reputeBigRed118 has a reputation beyond reputeBigRed118 has a reputation beyond reputeBigRed118 has a reputation beyond reputeBigRed118 has a reputation beyond reputeBigRed118 has a reputation beyond reputeBigRed118 has a reputation beyond reputeBigRed118 has a reputation beyond repute
  #22
Old 01-03-2008, 03:20 AM
trailtoy1993 trailtoy1993 is offline
Currently: Doing snow dance
Basic Member
trailtoy1993 has a reputation beyond reputetrailtoy1993 has a reputation beyond reputetrailtoy1993 has a reputation beyond reputetrailtoy1993 has a reputation beyond reputetrailtoy1993 has a reputation beyond reputetrailtoy1993 has a reputation beyond reputetrailtoy1993 has a reputation beyond reputetrailtoy1993 has a reputation beyond reputetrailtoy1993 has a reputation beyond reputetrailtoy1993 has a reputation beyond reputetrailtoy1993 has a reputation beyond repute
  #23
Old 01-03-2008, 08:52 AM
weantright weantright is offline
Currently: Not set.
Basic Member
weantright is an unknown quantity at this point
  #24
Old 01-03-2008, 10:36 AM
Dunatic's Avatar
Dunatic Dunatic is offline
Currently: Not set.
MODERATOR: Paid Premium Member
Dunatic has a reputation beyond reputeDunatic has a reputation beyond reputeDunatic has a reputation beyond reputeDunatic has a reputation beyond reputeDunatic has a reputation beyond reputeDunatic has a reputation beyond reputeDunatic has a reputation beyond reputeDunatic has a reputation beyond reputeDunatic has a reputation beyond reputeDunatic has a reputation beyond reputeDunatic has a reputation beyond repute
  #25
Old 01-04-2008, 09:09 AM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
