Upgrade to Premium
Ski-Doo: S-2000 and older 1998 and older, all models in the S-2000 chassis and older chassis models
Reply
  #1
Old 12-26-2014, 11:47 AM
Thunderguy BOOSTED Thunderguy BOOSTED is offline
Currently: NOT SET
Thunderguy BOOSTED has a reputation beyond reputeThunderguy BOOSTED has a reputation beyond reputeThunderguy BOOSTED has a reputation beyond reputeThunderguy BOOSTED has a reputation beyond reputeThunderguy BOOSTED has a reputation beyond reputeThunderguy BOOSTED has a reputation beyond reputeThunderguy BOOSTED has a reputation beyond reputeThunderguy BOOSTED has a reputation beyond reputeThunderguy BOOSTED has a reputation beyond reputeThunderguy BOOSTED has a reputation beyond reputeThunderguy BOOSTED has a reputation beyond repute
Default 740 UB based off 670
Hey~!
doing an engine swap into a 05 Rev chassis with my 740 Uning bay engine!!! My question is, anyone ever run this engine on a singe pipe? What worked? Custom???
please get back
Rate this post: Yes | No
  #2
Old 01-18-2015, 09:09 AM
letrbuck letrbuck is offline
Currently: riding and fixing
letrbuck has a brilliant futureletrbuck has a brilliant futureletrbuck has a brilliant futureletrbuck has a brilliant futureletrbuck has a brilliant futureletrbuck has a brilliant futureletrbuck has a brilliant futureletrbuck has a brilliant futureletrbuck has a brilliant futureletrbuck has a brilliant futureletrbuck has a brilliant future
Default
I have heard of guys running the psi 670 single pipe on them I know there were others building a fatty single style back then like to hear how it turns out just put a new top end in my 740 last week still makes lots of power
  #3
Old 01-22-2015, 08:30 PM
nuttyn01 nuttyn01 is offline
Currently: Not set.
nuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond repute
Default
I've run a few different pipes on that engine. Crank Shop twins are fun at 8600rpm if the engine is built around those pipes. Stock works great too. The best all around one IMHO is the PSI center dump single. Stock rpm and it was an aftermarket single that actually made more power. Oh and i happen to have one left if there's any interest. PM me for details.
  #4
Old 02-18-2015, 11:24 AM
1997formulazM-10 1997formulazM-10 is offline
Currently: Not set.
Basic Member
1997formulazM-10 is an unknown quantity at this point
Default
hey guys I just got off the phone with Kurt at FTX I'm trying to gather the info I need to do my own 740. I just finished assembling my m-10 and my bulkhead and tunnel are out for blasting. Kurt said I can run a few diff pistons, one is Pro-X which I've never run and any input is accepted, the other an OEM 720 sea doo piston which will be more expensive but price is really no option. the hard part is the jugs from what I hear, what sleeves are you guys running to accept the 82mm bore, or where can I be pointed to have the jugs bored and sleeved in 1 shot vs. bouncing around, the company union bay used to use no longer exists. Also I've spoken with the Crank Shop about porting as well as Dyno port, I've used Dyno port for all my other motors but the crank shop has more experience with the 740 so I'm leaning towards them. this is going to be a multi purpose sled so it needs to be somewhat reliable (keyword somewhat) but also climb like its life depends on it, and lastly carbs the Crank shop did my last ones on my 617, what mm bore are you running as well as jets. I know its a lot but I've been on the forum since I was 14 and I know this is the right place to get what I need. Thanks, Tony.
  #5
Old 02-21-2015, 08:42 PM
Currently: Not set.
Default
The Pro-X pistons are a very good choice for that application. I've used SPI pistons as well. You can buy the sleeves from LA Sleeve. I have the part numbers for them ill try to get for you tomorrow. I've used stock 44mm round slides and stock 40mm carbs. Any jetting I could give you would be based off the Summit X with DPM working. The cranks were keyed different on the X/HO motors compared to the standard motors. I know Union Bay didn't like using the X/HO cranks for the 720/740s. The last one I built I had over 7000 miles on it. The RV timing needs to be tweaked some too obviously on any RV motor. Mine aas set up using the PSI center dump single but with some Crank Shop twins and 8600-8800 RPM I've seen the 740 scream like mad. Shoot me a pm with your number and I can give you any information I have.
  #6
Old 02-21-2015, 10:29 PM
Default
just put a new top end on mine this year took pro x pistons out put new 50 over pro x pistons back in they are the 720 xp pistons and I believe the sleeves are 720xp ports opened up to match cylinders 670 crank and rods jaws twins on mine
  #7
Old 02-23-2015, 01:43 PM
Currently: Not set.
Default
The part number on the sleeves is 6031FB for a 670OB-748cc. The pistons are just off the shelf watercraft pistons for the Sea-Doo XP. I've used the WSM pistons too with good luck. The sleeves have a lot of meat for over bores past the standard watercraft bore. The top of the case will need machined for the larger OD on the sleeves and obviously recutting the combustion chambers. Or do a sleeper head with removable domes if you can still get any. Crank Shop should have these. Open up the case with some tunnel porting too on the intakes.150-160hp is very achievable with these in trail form. I've seen them spun way up in RPM with twins for more power and were still very reliable. They just don't last as long at 8600-8800 RPM.
  #8
Old 02-13-2016, 05:14 PM
HANDSOME HANDSOME is offline
Currently: Not set.
HANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond repute
Default
Any idea how much power with stock pipe ? I'm getting a 93 Mach 1 and would like to get some power out of it.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — NEED HELP ASAP! REV BASED ENGINE IN XP! Thread Starter — christ740 Forum — Ski-Doo: XP Sleds Replies — 1 Last Post — 03-01-2010 07:47 PM
Thread — WTB Big Bore 670 based cylinders Thread Starter — clintonmotor Forum — Engine/Engine Parts (Swapmeet) Replies — 1 Last Post — 09-17-2008 06:39 PM
Thread — Home based business? Thread Starter — Duddin Forum — Fouled Plug Replies — 23 Last Post — 08-29-2008 11:19 AM
Thread — PSI 890 (Cat 700 based) Thread Starter — Bearcat Forum — Arctic Cat Replies — 10 Last Post — 06-17-2008 08:42 PM
Thread — jetting help 670-based 720 Thread Starter — Aldrich Forum — Ski-Doo Replies — 1 Last Post — 01-10-2008 10:23 PM
no new posts
