Upgrade to Premium
Polaris: GEN 1 and older 1998 and older, all models in the Gen 1 Indy chassis and older chassis models
Reply
  #1
Old 12-22-2014, 11:42 AM
Rattlin_Ram Rattlin_Ram is offline
Currently: Not set.
Rattlin_Ram has a reputation beyond reputeRattlin_Ram has a reputation beyond reputeRattlin_Ram has a reputation beyond reputeRattlin_Ram has a reputation beyond reputeRattlin_Ram has a reputation beyond reputeRattlin_Ram has a reputation beyond reputeRattlin_Ram has a reputation beyond reputeRattlin_Ram has a reputation beyond reputeRattlin_Ram has a reputation beyond reputeRattlin_Ram has a reputation beyond reputeRattlin_Ram has a reputation beyond repute
Default Xtra 10 under '92 Indy 500 Done!
Saturday night finished up my Son's ride for the year. It is a '92 Indy 500 with about 5000 miles on it. We took the Xtra 10 front and rear out of a wrecked '97 Indy 440, moved the rear brackets, and bolted it all up. Also put a new(used) set of SLP SLT Skis on it. Also added a 2" riser. Then we put a newer secondary clutch/spring/helix in it, and new Polaris light blue primary spring. Should run pretty good for his lil '95lb butt on it! Now it just a bath.... and SNOW... damn rain...
Click image for larger version
Name:	Ty Sled Done.jpg
Rate this post: Yes | No
The Following 4 Users Say Thank You to Rattlin_Ram For This Useful Post:
550iq (12-22-2014), cowboy181d (12-23-2014), Merlin (12-26-2014), volcano buster (12-22-2014)
  #2
Old 12-23-2014, 07:58 PM
cowboy181d cowboy181d is offline
Currently: BOOSTED 2 STROKES RUINED ME
cowboy181d has a reputation beyond reputecowboy181d has a reputation beyond reputecowboy181d has a reputation beyond reputecowboy181d has a reputation beyond reputecowboy181d has a reputation beyond reputecowboy181d has a reputation beyond reputecowboy181d has a reputation beyond reputecowboy181d has a reputation beyond reputecowboy181d has a reputation beyond reputecowboy181d has a reputation beyond reputecowboy181d has a reputation beyond repute
Default
Good lookin build!
  #3
Old 02-20-2015, 12:20 AM
stomper stomper is offline
Currently: Not set.
Basic Member
stomper has a reputation beyond reputestomper has a reputation beyond reputestomper has a reputation beyond reputestomper has a reputation beyond reputestomper has a reputation beyond reputestomper has a reputation beyond reputestomper has a reputation beyond reputestomper has a reputation beyond reputestomper has a reputation beyond reputestomper has a reputation beyond reputestomper has a reputation beyond repute
Default
Looks good. Was the front suspension a straight bolt up or did you have to modify anything. I'm looking at doing the exact same thing to a 91 400 with a 97 xcr 600 front end.
  #4
Old 07-29-2015, 04:00 PM
Currently: Not set.
Default
Late response but I haven't been on here much since last winter... It was pretty straight forward other than moving rear brackets. Trailing arms from a XCR should work. However since the XCR has CRC the tie rods won't. My donor sled didn't have CRC (the rack n pinion style steering) so they worked fine. I did find out there are minor differnces in how the radius rods bolt up in certain trailing arms. I thought all X10 non crc fronts where the same. I had to replace one cuz it was bent, bought one from ebay, the radius rod mounts where different so I sold it and bought the right one. It would have worked if I had two of them matching but I didn't.....
  #5
Old 11-24-2017, 10:48 AM
VTMTcowboy VTMTcowboy is offline
Currently: Not set.
VTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond repute
Default
Looks awesome! Put a 136 xtra lite into my 90 Indy 500 a while back. Those 488 motors are rock solid.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Xtra 10 Front suspension into 92 indy 650? Thread Starter — firebird Forum — Polaris Replies — 6 Last Post — 02-28-2010 11:59 PM
Thread — 1988 indy 400 xtra 10 swap? Thread Starter — yamadog666 Forum — Polaris: GEN 1 and older Replies — 4 Last Post — 01-26-2010 07:59 PM
Thread — trailing arms: xtra 10 to xtra 12 Thread Starter — mod2000sks700 Forum — Polaris: GEN 2 Replies — 2 Last Post — 10-27-2009 10:59 PM
Thread — Extended Xtra 10 or Xtra-lite? Thread Starter — Nolimits Forum — Polaris Replies — 11 Last Post — 02-24-2009 05:32 PM
Thread — Xtra Lite vs. Xtra 10 Differences? Thread Starter — VTMTcowboy Forum — Polaris Replies — 2 Last Post — 02-14-2008 07:17 PM
no new posts
