Upgrade to Premium
Member Sled Builds A forum for building a project or mod sled.... Not just your common "Mods", but full on sled build projects.
Reply
  #1
Old 12-18-2014, 10:36 PM
mike_s mike_s is offline
Currently: Progress is fourthcoming!
mike_s has a reputation beyond reputemike_s has a reputation beyond reputemike_s has a reputation beyond reputemike_s has a reputation beyond reputemike_s has a reputation beyond reputemike_s has a reputation beyond reputemike_s has a reputation beyond reputemike_s has a reputation beyond reputemike_s has a reputation beyond reputemike_s has a reputation beyond reputemike_s has a reputation beyond repute
Default Project cat-poo: because, why not?
After way too much time spent on this damn thing, it finally got to see some snow today.
I finally decided it was time to retire the old 850 ultra engine, so decided to go with a Suzuki motor in the form of 900 mountain cat to repower my poo IQ chassis. This turned out to be more project then I initially planned, mostly due to my inability to compromise. Lol!
First initial mock up I discover that throttle bodies are wider than carbs on this engine, no factory steering post will clear, and I'm simply not willing to accept a post that leans as far as would be required to clear this big *** motor. Something new had to be created.
Decided that this chassis doesn't easily allow for a vertical post with over-engine steering, so the post would have to go around the engine instead. Using 2 universal joints in the steering post became necessary to keep the flat vertical post I wasn't willing to compromise on. This brought about a few other problems, in that I had to stabilize the upper post independently due to the fact it was no longer tied to the bulkhead as a solid shaft anymore. A few brackets and triangulation was in order. Also had to fabricate a secondary idler and drag link to tie into factory steering without destroying the correct geometry.
Steering complete, now we finally start looking at the engine again. Surprisingly, the factory cat wiring harness from the donor fit almost perfectly, both chassis and engine harnesses.
Engine mounting became interesting due to the steering post being so far to the right, had to build a custom mount that tied in diagonally, similar to the way some edge chassis mounts were.
Exhaust was surprisingly easy as well, as the dimensions of the cat pipe, and a poo 800 CFI engine are nearly the same, except for an extra 2" of length in the belly of the pipe. A swap of the bell on the inlet, new outlet to for the can I had, and a 2" section added to the center and exhaust is done.
Click image for larger version
ID:	244919   Click image for larger version
ID:	244920   Click image for larger version
ID:	244922   Click image for larger version
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to mike_s For This Useful Post:
joshkoltes (12-19-2014), mountainhorse (03-09-2015)
  #2
Old 12-18-2014, 10:49 PM
Default
Fueling was somewhat simple. A tank and pfa from a 900 rmk was acquired, and an external regulator added. Found out that the pump driver circuit in the cat ECM will not drive the Polaris pump, draws to many amps. So, the stock cat pump was retrofitted into the rmk pfa.
Intake was a pain. I had decided, after way too many years of using intake socks and dealing with steam ingestion and temperamental jetting that I was going to have a system that tied into the Polaris hood plenum. Made a small throttle body plenum, similar to what you'd see on a turbo, and tied it into the stock hood foam. Thanks to Shaun of MTNTK for the aluminum bosses to fit these throttle bodies!
ID:	244925   Click image for larger version
ID:	244926   Click image for larger version
ID:	244928   Click image for larger version
joshkoltes (12-19-2014), Suregom (03-11-2015)
  #3
Old 12-18-2014, 10:58 PM
Default
Couldn't fit a stock oil tank (again, due to my "custom" steering post ), and premix is not an option on a cat efi due to it's fueling algorithm, so o had to build an oil tank to fit. Ended up holding just under 3 quarts. Should be way plenty.
Picked up a holz skid for cheap, and after quite a bit of rebuilding (it was rode really hard and put away wet way too many times) I had a good skid to put in place of the dragons torsion suspension.
Sent From God Knows Where...
ID:	244930   Click image for larger version
ID:	244931   Click image for larger version
ID:	244934   Click image for larger version
The Following User Says Thank You to mike_s For This Useful Post:
  #4
Old 12-18-2014, 11:04 PM
Default
So out on the snow finally, and I seriously surprised myself as I think I nailed the clutching first try. Can't find much info on this engine with a team clutch, so I was shooting in the dark with what I had. Stock cat setscrew weights for this engine with a "custom" spring in the primary, and a 58/40 .36 progressive helix with a red/black spring in the secondary and full tilt rpm is spot on. Don't have much snow, or any hills to test back shift yet, so time will tell if it's gonna work.
  #5
Old 12-19-2014, 01:52 AM
joshkoltes's Avatar
joshkoltes joshkoltes is offline
Currently: TOO MANY PROJECTS!
joshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond repute
Garage
Default
nice job, your intake up pipe might need to be a little bigger but I guess you ran it and it works! ive always built them to not be any smaller than the combined sizes of the intakes. be best to make it as big as possible for deep days when the intake screen gets plugged there is more volume to draw from. no facts involved in my theory
__________________
Snow
  #6
Old 12-19-2014, 07:33 AM
j()()se j()()se is offline
Currently: staring at a pile of sled parts
Basic Member
j()()se has a reputation beyond reputej()()se has a reputation beyond reputej()()se has a reputation beyond reputej()()se has a reputation beyond reputej()()se has a reputation beyond reputej()()se has a reputation beyond reputej()()se has a reputation beyond reputej()()se has a reputation beyond reputej()()se has a reputation beyond reputej()()se has a reputation beyond reputej()()se has a reputation beyond repute
Default
Awesome job! Love seeing these motors dropped into other sleds. When I put a cat BB in my rev I used a cat roller secondary, but was thinking I would try the team this year. Just wasn't sure where to start for clutching.
  #7
Old 12-19-2014, 08:41 AM
Idcatman3's Avatar
Idcatman3 Idcatman3 is offline
Currently: Not set.
MODERATOR: Premium Member
Idcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond repute
Garage
Default
Quote:
To match the combined area of the intakes, the pipe needs to be just over 2.75". We did do the math to make sure he's got enough area. At the air flow he should be seeing through the motor at top RPM, there will be negligible pressure drop through the pipe due to size. There will be some due to the direction changes, but nothing to be done about that.
Quote:
The only issue with using the cat secondary is that the Poo jackshaft is splined, and the roller secondaries are keyed. Not an impossible hurdle, but an unnecessary one.
__________________
Arctic Cat 1M and PS Moderator
'04 1M 1500 162" Challenger Extreme, M8 rear suspension, Custom jetting, clutching and gearing
  #8
Old 12-19-2014, 09:46 AM
Default
I agree with you, bigger is almost always better, but there are constraints I had to deal with due to this chassis. If I remember right, we calculated roughly .4 pressure drop from atmosphere in this setup. Plus, if you've seen inside the cat air box, with the dinky little velocity stacks, then it starts to look not so small. Thanks for the compliments though guys! It was a fun project to build, now the other fun part is enjoying it!
  #9
Old 12-19-2014, 01:21 PM
Basic Member
Default
My doo jackshaft is splined, I machined a key way into it to run the cat roller secondary.
  #10
Old 12-19-2014, 02:19 PM
  #11
Old 12-19-2014, 05:52 PM
Merlin's Avatar
Merlin Merlin is offline
Currently: Where's the snow?
Merlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond repute
Click Here to Register
  #12
Old 02-08-2015, 11:05 PM
Reeb (02-09-2015)
  #13
Old 03-02-2015, 11:11 AM
NytroNorm's Avatar
NytroNorm NytroNorm is offline
Currently: Not set.
NytroNorm has a reputation beyond reputeNytroNorm has a reputation beyond reputeNytroNorm has a reputation beyond reputeNytroNorm has a reputation beyond reputeNytroNorm has a reputation beyond reputeNytroNorm has a reputation beyond reputeNytroNorm has a reputation beyond reputeNytroNorm has a reputation beyond reputeNytroNorm has a reputation beyond reputeNytroNorm has a reputation beyond reputeNytroNorm has a reputation beyond repute
  #14
Old 03-08-2015, 10:59 PM
  #15
Old 03-09-2015, 01:47 AM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
  #16
Old 03-02-2016, 06:03 PM
msvcrt3000 msvcrt3000 is offline
Currently: Not set.
Basic Member
msvcrt3000 is an unknown quantity at this point
  #17
Old 03-02-2016, 06:12 PM
Currently: Not set.
Basic Member
The Following User Says Thank You to msvcrt3000 For This Useful Post:
Reeb (04-20-2016)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Project X - SnoWest's 2012 Project Sled Officially Unofficial Thread -Ride pix UPDATE Thread Starter — fourthmeal Forum — General Snowmobiling Replies — 83 Last Post — 03-02-2012 07:31 PM
Thread — SnoWest's 2011 project sled - Project Mid-Life Crisis (Update- MTN TAMER install) Thread Starter — fourthmeal Forum — General Snowmobiling Replies — 198 Last Post — 03-30-2011 10:51 PM
Thread — little project ! Thread Starter — POLZIN Forum — Polaris: IQ Replies — 14 Last Post — 02-12-2010 12:18 PM
Thread — xc project Thread Starter — xc_rider08 Forum — Polaris (Swapmeet) Replies — 12 Last Post — 08-30-2009 07:50 PM
Thread — A little project Thread Starter — nathaniel11 Forum — Ski-Doo Replies — 5 Last Post — 10-10-2008 11:58 AM
no new posts
