Upgrade to Premium
Reply
  #1
Old 12-12-2014, 08:28 PM
monster900 monster900 is offline
Currently: Not set.
Basic Member
monster900 is an unknown quantity at this point
Default M1100 turbo misses and backfires at half throttle
Need help. Sled missed and backfires at half throttle (6000)rpm. Tried new pickup valves and still the same problem. And is and where is the fuel pressure regulator. Sled has the high jacker 2.0 and 3 inch pipe. Thanks
Rate this post: Yes | No
  #2
Old 12-12-2014, 08:47 PM
Turbo11T Turbo11T is offline
Currently: EVOLVING
Turbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond repute
Default
Any codes on the dash? Does it do it just cruising at half throttle? What setting is the hyjacker on? Does it change if you change the hyjacker settings?
  #3
Old 12-12-2014, 08:59 PM
Currently: Not set.
Basic Member
Default
Shows no codes or wrench. And soon as I hit half throttle it starts missing. Took box off today and put back to stock and same problem. Thinking regulator or tps. Ran great last year.
  #4
Old 12-12-2014, 09:31 PM
RACINSTATION's Avatar
RACINSTATION RACINSTATION is offline
Currently: Working too much
RACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond repute
Default
Replace and gap your plugs.
__________________
The Racin Station
60 South 1st Street Driggs, Idaho 83422
Ph: 208-354-2777 E-Mail: racinstation@hotmail.com
The Racin Station is your TURBO MOD HEADQUARTERS
for Arctic Cat Proclimb 8000/1100 and Yamaha Vipers and Sidewinders!
TIMBERSLED FULL LINE DEALER!!!
Proclimb Carbon Fiber Vents
Your MDS weight headquarters
Team ProClimb secondary complete setups ready!
Reman M6,M7,M8 and M1000 cylinders in stock.
Jaws M8 Singles for the 2012-2017 in stock!
Jacobsen Rollover valves in stock for M1100Turbo and Viper/M7000!!
Camoplast 3" and 3.2" 174, 162 and 156 x15 tracks on hand now
  #5
Old 12-13-2014, 12:00 AM
R44guy's Avatar
R44guy R44guy is offline
Currently: Waiting for Snow!
R44guy has a reputation beyond reputeR44guy has a reputation beyond reputeR44guy has a reputation beyond reputeR44guy has a reputation beyond reputeR44guy has a reputation beyond reputeR44guy has a reputation beyond reputeR44guy has a reputation beyond reputeR44guy has a reputation beyond reputeR44guy has a reputation beyond reputeR44guy has a reputation beyond reputeR44guy has a reputation beyond repute
Default Spark Plugs
Quote:
I agree you need to replace your plugs and close the gap should take care of your problem.
__________________
09 Poo D8 RMK 155
13 AC PC M1100T Ltd SP 162
14 SD Summit X 154
15 SD Summit X T3 163
  #6
Old 12-16-2014, 12:14 AM
JustBoostIt's Avatar
JustBoostIt JustBoostIt is offline
Currently: Enjoying the builds
JustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond repute
Default
I did it on my own sled this weekend. If happened to be at 6800 but the symtoms are the same.
Fuel regulator is on the left side of the throttle body, but almost 100% it will be the plugs.
__________________
Evolution Powersports Canadian Distributor
We stock all Evo parts in Canada and reflash on site
Evo Sidewinder Stage 5 and Stage 6 Big Chute kits coming soon!
Evo Sidewinder relashes and Maptuner options in stock
Evo Sidewinder boost hoses, BOVs, CAIs, and I/C grills in stock
Stereo sleds….Yup that's us!
1100t Single and VmAp ECU mountain reflashes!
Dealer and customer inquires welcome to gene@allgo.ca
  #7
Old 12-22-2014, 06:26 PM
Currently: Not set.
Basic Member
Default
new plugs and gapped to .022. Still getting a pop mid throttle. Tried adding fuel and subtracting fuel in mid RPM with box. Little bit better but not totally.
  #8
Old 12-23-2014, 12:39 AM
Default
I would get it to run correctly stock first.
Do you have an a/f gauge on it? I have seen boost reference lines get kinked at the regulator starving it for fuel. I personally haven't seen a bad fuel regulator but it's possible. Haven't had a bad pump either but fuel pressure is critical, did have one act like that with a fuel filter clogged up. Are the bolts tight at the header/turbo connection?
__________________
  #9
Old 12-23-2014, 07:22 PM
0neoldfart 0neoldfart is online now
Currently: rigging instad of riding
0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute
Default What plugs are you running?
I use NGKCR9EB plugs gapped to .020" - only way I could prevent flame out with the big chute turbo on 100 octane under heavy load.
The Following User Says Thank You to 0neoldfart For This Useful Post:
Sage Crusher (12-24-2014)
  #10
Old 12-23-2014, 11:42 PM
Default
I guess we should have specified the cr9eb plugs, not the stockers. They don't like getting regapped to 20. Some sleds require that plug with 93 octane reflashes, others don't. We gap those at 25.
6000 rpm is where the stock turbo starts to make boost so my guess is if the plugs don't fix you that you are going lean. Lack of fuel somehow....easy to see if that's the case with a/f gauge.
__________________
  #11
Old 12-26-2014, 06:04 PM
Currently: Not set.
Basic Member
Click Here to Register
The Following User Says Thank You to monster900 For This Useful Post:
Bradley T (01-06-2015)
  #12
Old 12-26-2014, 08:02 PM
Currently: EVOLVING
  #13
Old 12-26-2014, 08:42 PM
Currently: Not set.
Basic Member
  #14
Old 12-29-2014, 09:39 AM
Currently: EVOLVING
  #15
Old 01-11-2015, 01:15 PM
1Liter 1Liter is offline
Currently: Not set.
Basic Member
1Liter is an unknown quantity at this point
  #16
Old 01-12-2015, 12:10 AM
donaldej donaldej is offline
Currently: Not set.
donaldej has a reputation beyond reputedonaldej has a reputation beyond reputedonaldej has a reputation beyond reputedonaldej has a reputation beyond reputedonaldej has a reputation beyond reputedonaldej has a reputation beyond reputedonaldej has a reputation beyond reputedonaldej has a reputation beyond reputedonaldej has a reputation beyond reputedonaldej has a reputation beyond reputedonaldej has a reputation beyond repute
  #17
Old 07-04-2017, 05:53 AM
Nickhagen1 Nickhagen1 is offline
Currently: Not set.
Basic Member
Nickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud of
  #18
Old 12-20-2017, 07:57 PM
MR.T MR.T is offline
Currently: Not set.
Basic Member
MR.T has a brilliant futureMR.T has a brilliant futureMR.T has a brilliant futureMR.T has a brilliant futureMR.T has a brilliant futureMR.T has a brilliant futureMR.T has a brilliant futureMR.T has a brilliant futureMR.T has a brilliant futureMR.T has a brilliant futureMR.T has a brilliant future
  #19
Old 12-30-2017, 03:07 PM
powerstroke 350,700's Avatar
powerstroke 350,700 powerstroke 350,700 is offline
Currently: Looking to get more HP!
powerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 04 mcat 900 efi half throttle bog Thread Starter — gunnertrav Forum — Arctic Cat: 1M Replies — 2 Last Post — 03-27-2011 01:55 PM
Thread — 809 misses after 1/4 throttle. Please help Thread Starter — Rowdy1132 Forum — Performance/Modified Replies — 8 Last Post — 03-03-2010 08:15 AM
Thread — 809 misses after 1/4 throttle. Please help Thread Starter — Rowdy1132 Forum — Ski-Doo: S-2000 and older Replies — 0 Last Post — 02-22-2010 10:36 AM
Thread — m1000 bogging bad at half throttle Thread Starter — jenboy Forum — Arctic Cat Replies — 9 Last Post — 04-09-2008 09:17 PM
Thread — m7 backfires when under throttle engine light flashes Thread Starter — Ken Climb Forum — Arctic Cat Replies — 22 Last Post — 03-01-2008 04:03 PM
no new posts
