Upgrade to Premium
Reply
  #1
Old 11-09-2014, 08:18 PM
1badcat 1badcat is offline
Currently: Not set.
Basic Member
1badcat is an unknown quantity at this point
Default Fuel pressure regulator
Having an issue with fuel leaking from the regulator while system is pressurizing.
Though it was the hose clamp on the bottom but replaced and still leaking. Next pulled the regulator off the fuel rail and checked the o-ring. All looked good. Any thoughts? Could the regulator be bad?
Rate this post: Yes | No
  #2
Old 11-09-2014, 08:22 PM
slash's Avatar
slash slash is offline
Currently: ahhh back to work
Parts Moderator & Chat Box Cop
slash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond repute
Garage
Default
any vac controlled regulator can fail
__________________
09 IQ
KMOD
RAPTORS
2.5 CE
MOHAWKS
SLP PIPE
KOOLME KUSTOMS 660 KIT
TATERSPORTING PORTWORK
[IMG]//www.snowest.com//www.snowest.com/i/snowest-forum-logo.jpg[/IMG]
The Following User Says Thank You to slash For This Useful Post:
1badcat (11-09-2014)
  #3
Old 11-10-2014, 09:59 AM
madmax's Avatar
madmax madmax is offline
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
Default
Replace it, last thing you need is an under hood fire.
__________________
19’ Alpha 800 turbo
18, MC 153 stock
18’ axys 155 stock
17’ Cat 800 snow pro 153 alpha skid
  #4
Old 11-10-2014, 11:50 PM
Currently: Not set.
Basic Member
Default
New one on the way! Found defect in the crimp. Thanks!
  #5
Old 02-19-2018, 07:46 PM
Nickhagen1 Nickhagen1 is offline
Currently: Not set.
Basic Member
Nickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud of
Default
Bad crimp!
I actually had the above happen to me! Had a sled fire from a backfire and on the rebuild start up, found that the pressure regulator was leaking at the crimp! Cat had a back order of like 2 months so I ordered an adjustable one from turbo dynamics. Great product! Works great and holds good pressure. No current issues with it.
Hope this helps even tho its a little late
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Fuel Pressure Regulator Thread Starter — Monty Forum — Polaris: Pro-Ride Replies — 6 Last Post — 11-06-2014 07:27 AM
Thread — Fuel pressure regulator Thread Starter — Maul Forum — Polaris: TURBO Replies — 10 Last Post — 11-25-2013 07:37 PM
Thread — BMP Fuel Pressure Regulator Thread Starter — Devilmanak Forum — Misc. Sled Parts Replies — 0 Last Post — 04-28-2011 12:31 PM
Thread — Fuel Pressure Regulator-----> BDX V. BMP Thread Starter — ICLIMB Forum — Performance/Modified Replies — 0 Last Post — 11-19-2009 01:26 PM
Thread — Fuel pressure regulator Thread Starter — GreenArcticcatM7 Forum — Arctic Cat: M Series Replies — 1 Last Post — 11-02-2009 11:13 PM
no new posts
