Upgrade to Premium
Arctic Cat: Powder Special and older 2000 and older, all models in the Powder Special chassis and older chassis models
Reply
  #1
Old 09-30-2014, 03:57 PM
foshizzle foshizzle is offline
Currently: Not set.
Basic Member
foshizzle is an unknown quantity at this point
Default Accidentally a 133"?
I have installed a newer track on my sled, 95 580 Powder Special. After I installed the track, it doesnt seem to want to move at all when I try to move it with my hands, I have installed tracks on this sled before and they seem to be able to move by using my hands after previous installations. Of course I am trying to move the track when the sled is suspended in the air. Its all stock. My question is this, can a 133" actually even fit on a 136" suspension? If so, could I have accidentally gotten a 133" and done a complete installation? Or would the 133" not even let me bolt everything back together? Also, Before installing, I did compare the one I took off the sled to the one I was installing and didnt see a difference in length at all.
Thanks - P
Rate this post: Yes | No
  #2
Old 10-01-2014, 06:30 PM
Currently: Not set.
Basic Member
Default Update
So, Thank you to IDCATMAN1 for help through a PM on this issue. Heres an update: 1, I do have plenty of slack in the track, i just CAN'T seem to move it with my hands when I push or pull on the track, and when it is on the ground, it just drags without moving the track like being in motion. 2. When I turn the Driven clutch it moves the track just fine. Interesting, Anybody else have any thoughts?
Thanks - P
  #3
Old 10-01-2014, 06:52 PM
Currently: Not set.
Basic Member
Default Pic
Click image for larger version
I took a picture of the rear of the track, hopefully it loads, there is this metal bracket that looks to be part of the tension bolt where the rear rollers are. it is touching the track and seems to be creating a larger arc than that of the rollers are suppose to be creating. Maybe I need to tighten those bolts so that the rollers are further back and the track is only ttouching them?
  #4
Old 10-01-2014, 07:06 PM
boondocker97 boondocker97 is online now
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
Default
I would say the track touching that bracket is your problem. It should not touch at all and will damage the track in short order if it does and you run it. Tighten the track some more if you can to get clearance. If you have to over tighten it to get clearance, that's not good either and it won't work. The track will stretch a bit if it is new, but if it is used you won't have that luxury. It looks like that track has a Polaris paddle design and I know they made 133.5" tracks. It's possible you got one.
__________________
Current Sleds:
2014-2018ish BDX Pro-Lite 900, 2005 M7 with upgrades - Ol' Reliable, 1974 Cheetah
Still in the Family:
2009 M1300, 2001 Mountain Cat 800 LE, 1972 Kitty Cat
Gone but not Forgotten:
1999 Powder Special 600 LE, 1998 Powder Special 600, 1993 EXT 550, 1980 JAG 340
  #5
Old 10-30-2014, 01:26 PM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
looks like a polaris 2". that style only came in 136.
  #6
Old 11-02-2014, 03:45 PM
auburn6887 auburn6887 is offline
Currently: Not set.
Basic Member
auburn6887 is an unknown quantity at this point
Default skid track
did you change the skid to a 136?
or did you just do extensions
if you swapped skids
you have to change the front mounting hole postion
  #7
Old 11-14-2014, 11:09 PM
firecat99 firecat99 is offline
Currently: Not set.
Basic Member
firecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond repute
Garage
Default
Got a side pic?
And have you checked clearance in the tunnel?
  #8
Old 12-17-2015, 06:27 PM
Currently: Not set.
Basic Member
Default
Hey guys,
So I was SOOO frustrated with this issue that I had given up on it, and said F*** it, and I didn't ride last year anyways. But now I am ready to get this squared away. I called the guy who sold this track to me, and he is going to look to see if he has a 136" in stock in his garage.
After I had installed in, I noticed that I couldn't screw the tensioner bolts much.
The track is off a Polaris, and it has 1.5" lugs.
I am almost positive it is a 133.5".
  #9
Old 12-17-2015, 06:54 PM
Currently: Not set.
Basic Member
Default
Quote:
Originally Posted by firecat99 View Post
Got a side pic?
Clearance is good, since the lugs are 1.5"
  #10
Old 12-18-2015, 12:44 PM
Currently: Not set.
  #11
Old 12-18-2015, 02:51 PM
Currently: Not set.
Basic Member
Click Here to Register
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — """CHECK IT OUT 1984 FORD F150 ALL ORIGINAL TIME CAPSULE""" Thread Starter — KCM Forum — Truck/Truck Accessories (Swapmeet) Replies — 3 Last Post — 10-02-2012 04:49 AM
Thread — Arctic Cat "OEM" Online Part Number Look-Up 1974 to 2011 "Link Works Now" Thread Starter — KSH Forum — Clutching Replies — 0 Last Post — 10-03-2010 06:41 AM
Thread — Public "Listening Session" About "President Obama’s America’s Great Outdoors" Thread Starter — Dogmeat Forum — Utah Replies — 2 Last Post — 07-22-2010 05:59 PM
Thread — 06 M, accidentally hit kill switch- what you guys doin to to prevent it? Thread Starter — likkerpig Forum — Arctic Cat: M Series Replies — 25 Last Post — 01-14-2010 09:47 PM
no new posts
